Vauxhall meriva faults - Heating & Cooling
  • 4885 Answers
SOURCE: my vauxhall meriva radio shows
Leave it SWITCHED ON....UNDISTURBED for as long as it takes to automatically reset itself
This may take an hour or more
Posted on Jul 04, 2011
emissionwiz
  • 77169 Answers
SOURCE: where is the fuel pump relay on a 2004 vauxhall meriva
It is on the passenger side of the engine compartment under the wiper panel. its deep in because of the body design. you'll see a relay box. It should click on and then quickly off when the key is turned to run without starting the engine
Posted on Sep 13, 2012
little_shaws
  • 493 Answers
SOURCE: i have a warning light on my vauxhall
Emisions related can be a lot of things. It would have logged a fault code to the computer. You need the vehiclescomputer scaned to reveal the fault. Could be lots of things (O2 sensor in the exhaust, airflow sensor, vacume leak, misfire, etc...) the only way to know will be to have the code extracted.
Posted on Sep 28, 2012
alicantecoli
  • 22258 Answers
SOURCE: allumination light on meriva dash has gone out
you dont you remove the whole panel and as they are LEDs then its a new complete panel i would imagine
Posted on Oct 05, 2012
  • 876 Answers
SOURCE: Vauxhall meriva wont start after changing flat battery.the message safe is showing on dash board
Make sure ignition is switched on, hold down button AS and turn on the stereo. Wait for the beep, then release button AS. Display should now have 4 dashes ----. Enter correct code using the radio preset buttons 1 to 4. Once code is entered, press and hold down button AS again until code is either confirmed or denied. WARNING - you only have a max of 10 attempts to get it right, but if still no luck after the 8th attempt, STOP and contact a Vaux dealer.
or you could buy something from these folks:
http://www.m-99.co.uk/Car_Radio_Decode/car_radio_decode.html
Car radio code calculator Decode Serial Digital mileage adjustment...
Posted on Feb 06, 2015
I have a vauxhall meriva 1.7cdti and yester day i lost power and when i try toget up to full power when moving it go no get up and go
the system is probably in limp mode setting
run the fault codes and fix what is found to be faulty
reset the ECM using a scan tool when the fix is completed
Sep 29, 2016 | Vauxhall Cars & Trucks
What are the torque settings and sequence for a Meriva B 1.4 turbo
What components are you trying to fit? My advice would be to buy a good workshop manual and go from there Vauxhall Opel Meriva Petrol Diesel 03 May 10 03 to 10
Jan 15, 2016 | Vauxhall Cars & Trucks
What does code 258 mean on my Vauxhall meriva?
This is not a Fault Code as such, but a Message Code. Message code are listed in the owners Handbook. Message 258 is telling you that the Park Assist Function is OFF. So don't go backing into anything. You will need to turn On the Park Assist to extinguish the message.
Aug 17, 2015 | Vauxhall Cars & Trucks
Were is the fuse for radio
see red wire with fuse to radio from ignition key,,,otherwise fuse box innerside
May 02, 2015 | 2005 Vauxhall Agila
Could be a range of things. Rich or Lean mixtures
Vacuum Leaks
Exhaust Leaks ahead of Oxy Sensor
High or low fuel pressure
Leaking Injectors / blocked injector
Faulty Air Flow Sensor.
Jan 08, 2014 | Ngk Vehicle Parts & Accessories
Vauxhall meriva fuse box diagram
Fuse box Opel/Vauxhall Meriva fuse box diagram and description
http://www.autogenius.info/en/vauxhall-meriva-a-fuse-box/
Jun 19, 2013 | Cars & Trucks
Heating & Cooling Logo
919 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
