Question about Whirlpool Freezers
Fridge Freezer is blowing out hot air, is this fixable and cheap to fix?
Hi, I have a whirlpool fridge freezer which is just about a year old, however its blowing out hot air instead of cold, is this repairable, also is it a cheapish repair? Thanks so much for any help you can offer! Kind Regards Lisa
    Problem Solver:
  • 9 Answers
Is this under warranty? not a year old? thermostat or low refrigierent in compressor.thermo replace price ok.comp refrig can be expensive. hope this helps
Posted on May 22, 2009
Is there asbestos in every 3 way frigde
Asbestos is not used in any industry without notifications. There is no asbestos in the refrigerator
Mar 22, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Neff fridge/freezer has stopped cooling
pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
Dec 03, 2013 | Neff Freezers
I have a Whirlpool wbm46mw Fridge, the freezer is working ok but fridge not getting cold, any suggestions,Thanks
Empty fridge and if possible put steam down vent behind the cover in the freezer section. or hot water. it will com out in the fridge so be carefull. this unblocks the aif feed from the freezer to the fridge section. also make sure the fan is working.
Oct 04, 2013 | Engel Freezer 22 Qt. Fridge/Freezer
Whirlpool fridge freezer
either the return air grill(small grill on the inside wall of fridge) is blocked with a loaf of bread or something, or it's the freezer drain is blocked, some fridges use the drain as a return air vent,after unpluging it from the power point, defrost the fridge a remove the back wall plate (interior) of the freezer , & push something down the drain line like whipper snipper cord etc. then poor really hot water down it, check the drain at the back of the fridge for water running, reassemble the fridge pug it in & you should be sweet
Jun 02, 2013 | Freezers
I have a Brandt Apollo frost free fridge freezer which is malfunctioning, it is about four years old. The fridge section is dead whilst he freezer funtions. I noticed also that the interior light had got...
it may be repairable. setting the freezer aside for a moment, check to see if the fans come on when you first plug it in. make sure the vents dont have food debris in front of them. If the fans do not come on, you may be able to simply replace the fan or fans that pull warm air and blow cool air into the fridge. they get there cooling from the same coils and the freezer is working, so must be fans or fan relay
Nov 18, 2009 | Freezers
We've got a GE American Fridge Freezer. 12 years
time to get a new freezer. check the floor under the freezer for coolant leakage, if none the compressor is ready to deep 6...
Nov 07, 2009 | General Electric Chest Freezer FCM5SU
Whirlpool fridge freezer alarm s20D RSB33AG-B
Hi, you have a common problem with your control boards; there is a cheap fix if you can use a soldering iron or you can have your modules repaired.
Let me know
bb
Aug 31, 2009 | Whirlpool Freezers
Whirlpool fridge freezer tripping the electric
PLEASE CALL PENINSULA ENGINEERING & SERVICES
9224699796 , BASED IN MUMBAI 24 HRS SERVICES 100 % JOB SATISFACTORY
Sep 03, 2008 | Freezers
Dandy 8.8 fridge not working but freezer does
freezer works but fridge wont cool
Aug 29, 2008 | Freezers
Whirlpool FRS Side by Side Fridge Freezer
Hi Simon I saw that problem because you have a hole in the bottom of the freezer connecting directly on the wall of the fridge you need to block it ... because the air flow directly from the freezer 2 the fridge . Hope it was helpful.
Francois
Aug 01, 2008 | Whirlpool Freezers
Freezers Logo
341 people viewed this question
Top Whirlpool Freezers Experts
christian nielsen
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
