2002 Kia Rio Logo
Joseph Murphy Posted on May 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2002 Kia Rio Timing Belt
I have a 02 Kia Rio, I changed the timing belt at 66 thousand and change. Im up to 126,370 approx. I know the manual states to change the timing belt every 60,000 miles but is that the case? I ask because Im going about 70 miles one way then 70 miles back.
  • 3 more comments
  • Joseph Murphy
    Joseph Murphy May 21, 2009
    I told the repair shop a few weeks ago to check the belts and they told me they are not good but I can change them within a few months. They suggested I change all the belts
  • Joseph Murphy
    Which belts do I need to get? I see from auto stores they have the serpentine belt, but then online stores have the v-belt, multi-rib belt, etc
  • Joseph Murphy
    Yes I do have power steering and a/c. It has auto transmission too.
  • Anonymous Mar 17, 2014
    02 Kia Rio limp mode
  • Anonymous Mar 27, 2014
    I have just reached 90 thousand miles on my Element
Ray Keckeisen
Level 3:
  • Kia Master 599 Answers
  • Posted on May 21, 2009
Ray Keckeisen
Kia Master
Level 3:
Answers
599
Questions
Helped
271666
Points
2229
Yes, this is VERY IMPORTANT, this is an interference engine, meaning the valves and the piston cannot be in the same place at the same time,or it will bend the valves.then you are looking at a major repair job,think or it as insurance on your engine. please rate my fix as i strive to be the best,questions,get back to me
  • Ray Keckeisen May 21, 2009
    yes change all the belts they all have to come off when you change the timing belt,so no extra labor just the price of the other belts
    go to gates.com enter car info and you can get the stock numbers on the belts,it appears that you do not have a serpentine belt,you have to know if you have power steering and a/c as it makes a difference in the belts, please rate my fix
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2501
Points
I have a 2003 kia rio cinco. It just runing,the timming belt did'N BREAK it just stoped and will not crank. no compression at all. help
1helpful
What is cost ofpart and labor timing belt 2002 kia rio
Well, if you had had it changed before it broke it probably would have been around 200-300 bucks for parts and labor, but if it has indeed broke and has bent the valves then you are looking at well over 1000 dollars. I recently did a Chevy Aveo that was close to 2000 due to the cost of parts.
Kia rio not starting
Timing belt should have been changed at 60,000 miles. A loose timing belt or teeth missing from synchronous belt will lose timing. Damage to valves can occur if timing is not correct.
6helpful
2answers
Just curious, timing belt or chain. If belt when to change. Kia sedona 02 V-6. Thank you
Has a timing belt, Kia recommends replacement every 60,000 miles, also this engine in an interference engine, which valve to piston damage most likely will occur in the event of timing belt failure.
3helpful
3answers
What is the mileage of the timing belt.
The timing belt should be changed around 100,000 miles. I hope this is what you are asking.
Good Luck and please rate 4 thumbs up for the free answer
02 kia rio does it have an interferance eng? Think siezed eng may be a timing belt, but aren't sure.
yes it is interference and if belt broke some valves are bent.head removal required
2helpful
I need to know how to replace a timing belt for a 2005 kia rio. i lost the manual and i need to know how to time it correctly
The timing is electronic and non adjustable. If you change the belt and don't have it set up (positioned) exactly right , you will cause major engine damage.
Pistons will hit valves and bend them. Don't do your timing belt unless you are experienced at doing that job.
Change belts on 2002 kia optima
Not sure what engine you have , but I had an 02 rio with the 1.5 L . The serpentine belt did not have a tensioner (spring loaded) pulley , the belt tightness was adjusted by pivoting the alternator mount.
If you are takling about the Timing belt , the tensioner pulley wont move (even though it is on a spring ) untill you loosen the bolt in the center.
3helpful
2answers
2002 Kia Rio runs rough when idling
well spend some change and have a simple tune-up.  Plugs and filters and readjust the idle.
1helpful
Timing belt tensioner
On the Rio 2002, the tensionner is only used to apply pressure to the timing belt (installation) and cannot be adjusted. Once install the tensionner is "auto adjust" using a spring. If you need to adjust it,may be it time to change the timing belt KIT. Around 60,000 M.
Top Kia Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Kia Expert? Answer questions, earn points and help others
