Humax problems My Humax is not recording any BBC programmes - everything else is fine.
Shuttle83
  • 1139 Answers
SOURCE: problem for humax 5400
This is telling you of a defect in the circuitry since this unit cannot be repaired I would contact my satellite company and have the unit replaced since it is defective.
Posted on Sep 16, 2007
WebTeligent
  • 42 Answers
SOURCE: Humax Tivo will not record to DVD
After the update to 1.15 I had to delete EVERY recording on the unit. After that, any new recordings would burn just fine. However, some have found that same failure even after a hard reboot (repower). Called Humax level-1 support and they suggested a replacement unit so I swapped it out. But I've since learned that TiVo "pushes" a DVD firmware patch (possible supplied by Humax) from 1.08 to 1.15 and that patch is the culprit. That patch is suppose to make the DVD burn at a higher spin rate. After talking with level-2 Humax support they heard of the problem and said "the unit is working as designed", meaning, the DVD drive manufacturer specs say the drive is capable of a faster burn rate. So now I have Humax DTR800 #2 and so-far-so-good, but TiVo hasn't pushed the patch onto the box yet!
Posted on Nov 10, 2007
  • 7 Answers
SOURCE: how to download recordings from humax pvr9200t to pc
Hello liardet,
you could of course use the manufacturers supplied utility !
However, a lot of independent work has been done to produce a whole range of highly effective tools described on http://humaxdisk.wikispaces.com/
See also http://www.hummy.org.uk/forums/showthread.php?t=2009
JamesT
Posted on Dec 18, 2008
SOURCE: Humax Tivo Stuck on the welcome screen
I just had the same problem with mine and found another post that at least fixed mine.
I had a DVD in the unit as it was restarting. I took a flathead screwdriver and opened up the DVD slot by inserting at the top right corner and opening the door. On the inside, at the bottom right, is a button that ejects the DVD player (the eject button on the outside won't work while it's booting up). I ejected the DVD that was in it, unplugged the unit for 30 seconds, and then it rebooted just fine.
Hope it works out for you too...
Posted on Aug 20, 2009
SOURCE: Humax Foxsat HDR sudden Remote Control failure..
Make sure you have pressed the "PVR" button at the top. If you have accidentally pressed on on the others TV, DVD or AUDIO then they will light up when you press another button signifying that the remote is trying to send a signal to them rather than the PVR...which is where you want it to go.
Posted on Nov 21, 2009
I only have one scart outlet on my tv my ariel is in the wall and mthen into my tv but its just picking up tv programmes on my humax recorder and not through my tv
The aerial should first go to the Humax, then from the Humax to the TV. Make sure power-saving is turned off on the Humax, otherwise it will not pass the aerial signal to the TV when the Humax is in standby.
If ypou want to use Humax power-saving, the aerial must be split so that one feed goes to the Humax and another to the TV.
May 19, 2016 | Humax Televison & Video
How do i stop my humax foxsat-hdr recording a series when i only want one?
press to record again the same programme it will give you an option to cancel
Nov 07, 2015 | Humax Televison & Video
Problem with watching normal scheduled TV and recording programmes
If you have an indoor antenna connected to that particular TV, a slight reorientation can make a big difference.
Oct 25, 2015 | Humax Televison & Video
My humax won't;t record bbc channels. I have tried retuning the tv.
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range. The signals for BBC and ITV are among the strongest ones broadcast. If they are now at a point on the aerial's range where they are too strong for the TV then the tuner will over-saturate. The result is the same as no signal.
Have a look online for a Variable Signal Attenuator. It's a device that can be added to a aerial signal cable just before it goes in to the tuner. The adjuster allows the signal level to be reduced. Watch the TV's signal quality and signal level displays if it has them. As signal level (power) reduces you'll actually see signal quality increase. If you go too far then quality will start to go down again. The optimum point is where quality is highest.
Oct 08, 2014 | Humax Televison & Video
The bbc red button service on humax listing not working
You should scan for channels again, as some were changed recently.
Sep 14, 2014 | Humax FOXAT HDR DTV Receiver
I have a Philips 32PFL7562D t.v. connected via a Humax HDR-FOX T2 recorder. When I change back from a recorded programme to the T.V the screen goes blue then breaks up into 'hundreds and thousands. (s
How are you changing from recorded to TV? If you are switching the TV input, it could be because it's looking first for analogue TV stations but there are none any more, so it then reverts to the SCART and shows the Humax satellite station. If you are just pressing STOP on the Humax then you shouldn't have a problem, but if you do have the problem then the Humax must be faulty.
Sep 05, 2014 | Televison & Video
Humax recorder problems
Please provide the model name/number.
This can sometimes happen if there is another recording starting immediately after. You may find the missing part on the front of another recording.
Otherwise there is an option to add a few minutes 'padding' to the beginning and end of each recording.
Mar 11, 2014 | Televison & Video
It stops recording a few minutes before the end of the programme
Hello
A firmware update is necessary with your Humax Foxsat receiver. Get into Humax site and update the device with latest firmware. OK.
Oct 20, 2011 | Humax FOXAT HDR DTV Receiver
Nov 10, 2007 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
Televison & Video Logo
305 people viewed this question
Top Televison & Video Experts
Electro Med Services...
