Question about IBM ThinkPad T20 2647 Notebook
CANNOT START BOOT GIVING EROR CODE 0175
My laptop is not booting giving me the error code 0175 bad crc stop post task
  • 53 Answers
This error seems to represent motherboard problems and most likely requires new motherboard. Unfortunately most laptops that are a few years old arent worth fixing, unless you can do it yourself. Try to find a used model same as yours for parts.
Char S.
Posted on May 21, 2009
Error 0175: Bad CRC1, stop post task
ERROR
0175: BAD CRC1, STOP POST TASK.
Firstly, this error is generated due to a couple of different reasons. First, there may actually be a problem with the power circuitry and the CRC function is actually doing it's job reporting the error. There are several tests you can perform to tell if this is the case with your system.
Secondly, this bad CRC error can be generated by sudden power loss to the system, especially if the system loses power during boot up or POST process. Both mean that there could be a problem with the motherboard and it needs replacing.
Try the steps below to determine what is wrong.
1) Start the system and watch the status lights in the LCD hinge or near the power button. They should flash once (some models twice) before the system shows a display. If they flash 3 times or more, you have a power problem.
2) Start the system and allow it to reach the CRC "stop post task" error message. Let it sit at this error for several hours. The system should sit at this error for ever or until user intervention occurs.
3) Some things to watch for while the system is sitting at the CRC error and running for several hours would be: Screen going black, System rebooting, System powering off, ect.. ect.. ANY activity by the system is a warning that power problems exist in the system.
4) Try restarting the system several times consecutively, shut the system down by holding the power button for 5 seconds, then restart keeping an eye on the status lights for any additional flickers.
All the above tests should be done with AC power applied and battery installed. Also ALL drives installed.
Regards.
Jan 19, 2011 | IBM ThinkPad T23 2647 Notebook
ERROR 0175: Bad CRC1, stop POST task message Been using my IBM a30 laptop for some months but was surprised to get this error when i tried putting it on this message pops up ERROR 0175:BAD CRC1 STOP POST...
You obviously didn't read the problem carefully. The machine won't boot, so there is no command line. I have the same problem with a T23. It might be the CMOS battery that needs to be replaced.
Jan 11, 2010 | IBM ThinkPad A30 Notebook
Ibm notbook. how will i solve "bad crc1, stop post task. with an error code 0175?
The POST error code 0175 refers to a CRC (cyclic redundancy check) reading from the EEPROM chip, that data is corrupted, most likely a faulty EEPROM chip. This is a motherboard problem and cannot be fixed except by a motherboard replacement. This is an old laptop and would not be worth fixing, I suggest you put your money towards a new laptop.
You can remove the hard drive and put it into an USB hard drive adapter case and use it as an external USB hard drive.
Jul 12, 2009 | IBM ThinkPad A21e 2655 Notebook
0175:bad CRC1.stop post task the computer will not boot
You could have a faulty BIOS chip or the BIOS battery is nearly flat and giving you this POST error. Replace the BIOS battery with a new one and configure the BIOS settings eg. the Date & Time etc.
Jun 25, 2009 | IBM ThinkPad T20 2647 Notebook
ERROR 0175 BAD CRC1 COMMAND STOP POST TASK
the crc is the cyclic redundance check your bios is corrupt. you will need to flash the bios to bring it back the internal bios bottery will need to be removed for 1 min then replace. it should bring it back if not you bios chip has burnt out. i have never replaced a bios chip but you will have to find one to replace it
Jun 24, 2009 | IBM ThinkPad T60 Notebook
Error 0175 on boot IBM Thinkpad T20
Error code Symptom or error Field replaceable unit or action, in sequence 0175 Bad CRC1, stop POST task. The EEPROM checksum is not correct. System board
Mar 27, 2009 | IBM ThinkPad T20 2647 Notebook
IBM Laptop A22e Display an error 0175
The CRC error (POST = power on startup test) on boot up refers to the BIOS settings. This could be cause by a near flat BIOS battery and it needs to be replaces. If it is not the battery you need go to the BIOS to correct any faulty settings.
Nov 29, 2008 | IBM ThinkPad A22e 2655 Notebook
While booting error " bios shadowed " & 0175: bad crc1, stop post task
sounds like cmos battery flat small battery inside pc to retain cmos setting when pc switched off
Oct 02, 2008 | IBM ThinkPad T20 2647 Notebook
ThinkPad T22 will not boot to windows
I've seen several T20 series with the same problem. A CRC error pertains to a chipset on the motherboard, and the only way I've found to fix a CRC error is to replace the motherboard.
Jul 07, 2008 | IBM ThinkPad T22 2647 Notebook
Stop POST task, bad CRC1 error 0175
There are a couple of possibilities, go to this link for the solutions, but it could be a bad power supply http://www.hardwareanalysis.com/content/topic/31761/
Aug 07, 2007 | IBM ThinkPad A21e 2628 Notebook
IBM ThinkPad T20 2647 Notebook Logo
235 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
