Question about Cell Phones
My phone will not reset!
Every time I try to do a factory reset on my phone I get a blank screen and the lights on bottom blink
    Genius:
  • 1,102 Answers
Try shutting phone off and removing battery & sim,replace them after about a minute.Replace turn on again and try to reset again.Or you can try manually removing contacts etc..remove sim battery replace turn on again and reset.Hope that solves the problem.
Posted on Jan 03, 2014
Factory reset acer aspire 5315 gone wrong
I think you need to reload windows with a operating system disk. Most times the Factory Recovery discs don't work.
Get a windows operating system disk and just reload windows. The disk must match the Certificate of Authentication (COA) sticker on the bottom of her laptop. In other words, don't use a Windows XP Home operating system disk if the COA sticker says Windows XP Professional or you'll never be able to activate windows.
May 06, 2012 | Acer Aspire 5315 Notebook
I was talking to my friend on my Nokia x3 phone, the phone turned off, the screen started blinking. Then I turned it back on, called my friend, the same thing happened. The screen blinks again and again,...
Try to reset to factory settings. from Menu-Settings-Restore factory settings,or something like that i don't know exactly what menu has x3.Good luck
Feb 11, 2011 | Cell Phones
Device comes on but screen is blank...will not load menu
there is a small reset button on the bottom disconect the power hold in the rest button on the bottom of the unit and power it up this will reset it to the factory default
May 09, 2010 | Tomtom ONE GPS Receiver
My Nokia 6300 phone switches off automatically, but the light by the side still blinkes but the screen goes blank, please can u help?
  1. your phone need reset to factory settings by typing the code *#7780#
  2. for this all most full of  ur battery needed
  3.  after that type security code 12345
ur phone will become ok
May 10, 2009 | Nokia 6300 Cellular Phone
Need to restore to factory default but my lappy gives me a blank black screen with a blinking underscore on the top left of the screen.
There might be one step you could try to restore the system to factory specifications. When you turn the laptop on, and you see the Acer splash screen, press the Alt-F10 keys together at the same time, and this should hopefully bring the Acer eRecovery system up, provided that your computer has the built-in recovery partition. If it asks for a password, try using the default of "000000". If that doesn't work, then a password has been entered into the system, and there is no way to reset it, however there is a way to find out what the password is, however it does require the use of the Ubuntu Operating System (which is free to download, here)
May 10, 2009 | Acer Aspire 5050-3242 Notebook
N95 blank screen every 7 secs help?
kindly re upload your software!!!
Apr 25, 2009 | Nokia N95 Cellular Phone
Power/Standby light blinks green then screen goes blank (off) for
I have a similar problem. Just found out a possible solution yesterday. I am waiting for my lamp but here's what you need to do if you have replaced your lamp. Go into self diagnostics mode: Switch of your TV via remote, you will see red standy by light. Now,on the remote press "Display"=>"Channel 5"=>"Volume Up"=>"Power Button". All these keys need to be pressed within 3 seconds. You will now enter the diagnostics mode. Press "Jump" on remote (bottom right) 3 times and then press "Channel 2" 9 times. The screen will display your current lamp hours used.
In order to reset your tv to factory settings and for the new bulb to work you must reset this timer or else your TV will assume you are still using the old bulb and will automatically kick in "over protection mode". So here's what you do once you do on the lamp hours display screen. Press the "Channel 3" button on the remote 3 times then "Mute" then "Press Enter" to reset the timer to zero. Your TV should now work as normal. And remember, whenever a part is replaced all factory settings must be reset to zero. To do this, follow "Display"=>"Channel 5"=>"Volume Up"=> "Power Up" to enter service mode. Finally, press "Channel 8" and then "Enter" to put the TV back to factory settings.
The above mentioned is usually performed by a service technician and they charge somewhere around $95 diagnostic fee. You just saved this charge. If you see flashing red lights count them when they flash in sequence. This is a code for the techs to tell them what is wrong. These flashing red lights sequentially flash from 0 to 10 times to identify a problem. Usually, when the bbulb goes bad the only thing that might need to be replaced would be a "lamp Driver" aka "Power Block Assembly" $116.25 online from Sony, or the ballast. Sometimes, if you do not have a video a Thermal FUse can go bad which only costs $4.80 for the KDF60-XS955 but the techs will charge you over $300. You can do this yourself if you can get your hands on a service manual.
Hope this info helps.
Good Luck to you all.
Jan 20, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blackberry pearl 8100 blank screen & green blinking light
Try performing a hard reset: remove the battery from the device while it is still powered on, leave it out for 30 seconds, then reinsert.
Sep 28, 2008 | RIM BlackBerry Pearl 8100
Blank screen
Try soft reseting your phone. If that doesnt work then try hard reseting.  To soft reset take the stylus pen and push in the little hole on the bottom of the phone. You should feel a little click and then your phone will restart. Wait until your phone  starts up again and if it still isnt working then do a hard reset.
 To hard reset, hold down the green send button and the red end call button at the same time and continue to hold them down as you then push your stylus pen into the hole on the bottom of the phone untill you feel the little click. Your phone should start to reset.  Be warned you will loose any information saved to the phones memory ie: phone numbers, pictures, personal settings. Anything saved to your memory card should be ok.
If your screen remains blank after trying both resets I would suggest taking it back to where you got it and and have them fix it or replace it.
Hope this is helpful.
Feb 12, 2008 | HTC Touch P3450 Smartphone
Moto Slver will not stop blinking hellomoto when i turn it on
try removing the external card if there is one and restart phone without it. if theres no external card, try master reset to factory settings and restart phone, please back up your contacts first before resetting your phone.
Dec 09, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Cell Phones Logo
48 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
