Question about Craftsman 25cc Gas Line Trimmer
Pull rope is striped
The pull rope round piece is striped
  • 10,865 Answers
Remove the starter housing, usually only 3 or 4 bolts or screws. on the inside should be a large white or black wheel, hold the outer case with one hand and rotate the wheel counter-clockwise with the other as many times as can without force. on the inside of the wheel should be a small hole, rotate the wheel to line it up with rope guide hole on the outer case/housing. use a nail or small screwdriver to help hold in place. feed the start rope through the 2 holes and tie a knot at the end, single or double depending on the size of the hole. if the end of the rope is frayed, use lighter to melt and twist to a point to make it easier to handle. when reassembling you may need to jiggle the handle for realignment. it works on an inner spring coil tensioner system, so if the cable has no tension when rotated or doesn't recoil back, the starter assembly will need to be replaced.
Posted on May 21, 2009
Installing a starter rope
Remove the 3 or so screws that secure the pull rope housing to the top of the motor. Flip it upside down and it should be pretty obvious as to how to remove the spine loaded piece that the rope goes on. Thread the new rope thru the housing and wind it up on the spindle. Make sure before you put it on that the rope pulls out and retracts like it should.
Jul 30, 2016 | Homelite 6796881 308451006 Hilmore Husky...
How to replace starter rope in lawn mower
First assemble the following: Pliers, large vice grips, 'c' clamp or a bench mounted vise and new rope. Remove therecoil housing from top of engine. Turn it over, find the end of the broken rope and on pull it until it is fully extended but do not remove yet. While holding the rope extended place clamp device on the rope housing clamping the spool and housing. Be careful not to put too much pressure on the housing, just enough to hold the two pieces. Carefully remove old rope and thread the new rope through the small hole in the housing and into the slot in the pulley. Tie that end of rope into a knot to prevent rope from coming out. While holding other end of rope, carefully remove the clamp from the housing and slowly let the rope rewind into the housing. Replace rope housing onto top of motor. HOW TO Replace Broken Lawnmower Pull Cord
Sep 01, 2014 | Garden
Pull chord broke off when trying to start it. disassembled it, but don't know how chord should be reinserted. can you help?
if its a newer mower take the top off the engine there will be a round plastic piece twist around till it stops stick a screw driver threw it to hold put the string threw your handles and back threw the cover you should see a hole in the plastic piece put in there and tie a knot hold the rope and pull out screw driver rope should wind itself up
Oct 26, 2013 | Yard Man Garden
Starter rope replacement
recoil spring has slipped out of the hole.pull your starter rope out of the wind up mechanism, insert the spring latch on both ends and put back into housing. with a piece of 3/4 square stock or something the will fit mthe hole start to wind the mechanism spring up tight. with apair vishgrips lock it down so it does not move. insert your starter rope anr release the visegrips. the springwii recoil and pull the rope in.cut off excess rope. good luck
Oct 17, 2012 | Little Wonder 6032 10 Inch Pro Lawn Edger,...
I can't get in to change the starter cord on troybuilt TB90BC. There is a round metal piece which just spins. This will not allow the plastic cover to slide off revealing the starter cord attatched...
The round metal piece is the clutch drum. Deep inside it, screwed into the end of the crankshaft is a Torx # 20 screw. Loosen it counterclockwise (with nice Torx screwdriver). The screw will REMAIN in the clutch drum but allow it to be removed, revealing the clutch. From there, follow these non-patented instructions.
Remove the tube that holds the flex-drive shaft from the front of the motor cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #20 screw. Before you loosen it, ou will have to lock up the engine. Remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-20 screw inside the drum.. It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the bottom of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or something so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place. Reassemble and you are done. Disassembly requires Torx head drivers ranging from T-15 to T-25
Sep 04, 2011 | Troy Garden
I have a mcc1840b pull start wont grab,rope just pulls out easy !
Change the rope pull system.It comes in a one piece and is easy to install.
Oct 13, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Replacing start rope of the b&s model # 120600
Take off the three-four bolts holding on the starter cover and lift it off the engine. Make sure you dont leave the oil dipper attached too.
Remove its bolt at the cover so it doesnt come out of the engine block and make a mess.
Flip the cover over and you should see the pulley the rope rides in. Pull out the broken end piece of the rope from the inside-center of this pulley. Get a new piece of rope from a power equipment store. Make sure you get enough to cover the length needed to make it all the way out to the handle! Snake into the recoil cover from the outside hole into the pulley *(you align the pulley with the hole in the cover) with small needle nose pliers you can pick the rope through the pulley hole and then tie a knot to secure this end of things. A butane lighter is good to use on the frayed end to "melt lock" it. Nothing crazy now...just melt the tip where you see the frayed material.
Then put the t handle on the other end and tie it off too. Also melt the frayed end before pulling the rope into the t handle.
Now that the rope is in place all you need to do is prewind the pulley. This is done by using a small section of the rope near the pulley to turn it in the direction of starting about 6-8 turns and then carefully release the pulley so it winds the rope onto it. You can do this slowly by keeping tension on the T handle and slowly walking it into the starter cover. Be careful. You dont want to get your fingers caught on anything spinning or pulling here. The rope will be twisted so the person holding tension on the rope can help by untwisting the rope so it can rewind smoothly.
That is about it. You can then pull the rope a few times to make sure you put enough prewind on it so the rope doesnt stop pulling even though you have more rope to pull *(this is to prevent causing the recoil spring binding from insufficient prewinding)
Put the recoil cover back on. Put the t handle back into the fixture on the mower handle. Thats it! Start her up and go cut some grass!
Good luck and be careful!
Oct 12, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Need to obtain a new belt and pull rope for my Tiller
you can get a pull rope at wal-mart.measure the belt and any parts store or place that sells lawnmower belts should have one.if the rope broke close to the end knot just pull the end knot with some needle nose pliers.once you have all the old rope out lay the old rope pieces on the ground and cut the new rope to match it as far as length.turn the pulley that the pull rope goes in six turns counerclockwise.then turn the slot the knot was in to the hole the pullrope goes thru and fish it thru then pull it up and out with apaiar of needlnose have someone hold the pulley until you tie a small knot in the end of the pullrope the hold the pullrope and let it pull it in.you might have to cut some off at the handle if its still too long.to do this pull some rope out and tie a quick knot so the rope can't slip back if you let it go.
May 27, 2010 | Mtd Products Yard Machines 158CC Tiller
I 'm trying to pull the rope and it will barely--honda pressure w
The rope may be bound up in the recoil. Take the recoil cover off(the piece where the pull rope goes into) and try to pull the rope with the housing off. If it pulls freely try turning the engine by hand, you may want to remove the spark plug to release the compression. If the unit will not turn over,then the pressure pump may have failed. Best of luck.
Apr 23, 2010 | Honda Karcher G4000RH Pressure Washer
The starter pull cord has pulled off.
EASY,REMOVE TOP COVER OF ENGINE THAT HOUSES ROPE ASSY. LOOK UNDERNEATH PLASTIC PIECE,CUT THE KNOT OFF THAT COMES THROUGH HOLE AND PULL AND EXISTANT ROPE OUT. OK, GET NEW ROPE AND HANDLE TOGETHER,THE END THAT IS OPPOSITE FROM NEW PULL STRING HANDLE YOU ARE GOING TO USE. CAREFULLY WIND UP ROPE HOUSING NICE AND FIRM JUST BY WINDING IT UP WITH HAND IN AS IT SITS IN TOP COVER. WHEN YOU THINK IT HAS ENOUGH TO PULL ROPE IN FEED END OF ROPE IN HOLE AND IN CHANNEL OF ROPE HOUSING,THERE IS A SMALL HOLE TO LINE IT UP WITH,WHEN SEE THE ROPE END FEED IT THROUGH THAT HOLE NOW. MAKE TAKE ANOTHER SET OF HANDS OR A WEDGE TO STOP RETRACTING OF SPRING. PULL ROPE THROUGH AND TIE A DOUBLE KNOT AT END SO IT WONT PULL THROUGH. SLOWLY LET IT PULL ROPE IN,THEN PULL ROPE BY HANDLE FULL LENGTH TO ENSURE ALL KINKS ARE OUT AND IT PULLS BACK IN LIKE IT SHOULD.
Jul 12, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman 25cc Gas Line Trimmer Logo
202 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
