Question about Toshiba Satellite Computers & Internet
Laptop sharp edges - Satellite Toshiba Computers & Internet
Lawnmower blades going round but not cutting
It could be two reasons
1: the blade is not sharp enough to cut
2: the bade is set higher than the grass
Mar 17, 2016 | Garden
FILLET Knife sharpening
I use silicone carbide sharping stones , these keep things sharp and cool , as you never want to heat the blade while sharping them, takes the edge right off them (heat)
Jan 30, 2016 | Garden
I want to jump motherboard on n5040
When you say "jump motherboard," are you talking about bypassing a BIOS password?
If you meant something else I would either discourage you because it has sharp edges or suggest you wear thick leather gloves.
Mar 06, 2014 | Dell Inspiron M5030 PC Notebook
My washing machine LG frontload model F1068Qdp is causing holes in some of the shirts and pants.I have noticed one edge of the drum is a bit sharp that might be causing this problem .Is there any solu
Holes are usually caused by overloading the machine - but a sharp edge is a major fault and you need to call the engineers out and or seek a replacement as a repair is a major undertaking.
Feb 01, 2018 | Washing Machines
I am trying to replace the little round lithium backup battery in my laptop but it is help with a clip that I can't remove. I don't want to break it so how do I replace it
Press the clip with a sharp point on the inside edge towards the outside edge and the battery will pop up. You may need to lever the battery up at the same time.
Feb 11, 2012 | Toshiba Computers & Internet
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    Frigidaire ice cubes coming with square edges...
    Get a life, sharp ice cubes? The edges melt and the problem goes away.
    Jun 21, 2008 | Frigidaire FRS6R5EMB Side by Side...
    Computers & Internet Logo
    93 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
