Question about Nikon Coolpix S2600 Digital Camera Accessory Kit. Includes: 16GB Memory Card, Memory Card Reader, Extended Life Replacement Battery, Hard Case, Rapid Travel Charger, Gripster Tripod, LCD Screen Protectors, Cleaning Kit, Table Top Tripod
My camera says lens error and it is very blurry when I turn it. Up
4 Suggested Answers
miket756
  • 2702 Answers
SOURCE: The lens on my camera goes down at an awkward angle with lens err
well its a scrap bin joby now to get this fixed will cost you more than a good camera would it has the lens runners smashed off,,,they realy dont like being droped do they?
Posted on Mar 05, 2010
lock123
  • 6831 Answers
SOURCE: when i turn on the
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Dec 26, 2010
  • 11967 Answers
SOURCE: I have a nikon coolpix
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 20, 2011
I saw error E18. Can only make pictures very blurry but the lens works good. also in the lcd pictures are blurry
It's lens problem. If you can, disassemble your camera and fix your lens. If you finish and the camera saw the same error..change your lens. It same with sony camera that message "Turn The Power Off and On again"
Aug 22, 2009 | Canon PowerShot A410 Digital Camera
Chances are your focus is messed up or damage or the lens motor is i would suggest getting a new camera or getting it fixed at a camera store
Aug 07, 2009 | Casio Exilim EX-S600 Digital Camera
Hi i turn the camera on and have a blurry screen
Zoom motor in lens assembly is jammed and you need to replace complete lens assembly. DSC-T1 is an old camera so oes not worth to repair.
Jun 04, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Lens error and blurry photos
If your images are blurry and the lens wont move smoothly it is very probable that some kind of force on the lens has damaged a gear, barrel or even dislodged an element internally. When the lens detects an obstruction in its movement the camera reports accordingly,"lens error". You should have the camera checked by a service centre, it will most likely need the lens replaced as they are not serviceable.
Apr 14, 2009 | Canon PowerShot A630 Digital Camera
Blurry picture nikon s200
It doesn't say lens error? but it won't focus? it is probably the same as the other people who do have lens error displayed on the screen, the lens is broken is what the repair company told me about my s200 when i told me lens error
Jul 22, 2008 | Nikon COOLPIX S200 Digital Camera
Lens Error
i had the same problem with lens is blurry and lens error message comes up. My solution might sound sillys but it works. tapping on the side of the camera, put some force to it.(with hands only).
Jun 16, 2008 | Nikon COOLPIX S9 Digital Camera
Lens error with a slight twist
See my posts on this problem.. This may be that the lens is off track. You can try to force it in and out as you turn it on and off. You can damage the camera, but if you know that it is already damaged, may be worth a try.
Apr 25, 2008 | Nikon COOLPIX L3 Digital Camera
Everytime I take a picture it turns out blurry
Inside the lens their is a focus motor that has to be perfectly set if it get out of ajustment this will cause a blurry image it you try to zoom some times you may get a lens error this is because the lens has been obstructed from the inside by the focus lens. the lens eather needs to be replaced or rebuilt.you may find a broke one off ebay with a good lens pretty cheap if you are going to try and repair it your self.
Mar 20, 2008 | Mercury Electronics CyberPix S-555V...
Nikon Coolpix S2600 Digital Camera Accessory Kit. Includes: 16GB Memory Card, Memory Card Reader, Extended Life Replacement Battery, Hard Case, Rapid Travel Charger, Gripster Tripod, LCD Screen Protectors, Cleaning Kit, Table Top Tripod Logo
56 people viewed this question
Top Nikon Video Cameras Experts
David Payne
David Payne
ray gallant
Tony Parsons
Tony Parsons
Are you a Nikon Video Camera Expert? Answer questions, earn points and help others
