Question about Konica Minolta Magicolor 1600W Printer
Hi! On our Magicolor 1600W, I replaced the cyan, magenta & yellow toners and now I am getting an error. Slow blinking light. Also, the machine turns on but only when either the top or front door is open. If they are both closed, the machine powers off.
  • Tina Brumleve
    Tina Brumleve Jan 03, 2014
    I didn' have any luck with service manuals. Any other suggestions?
  •  John
    John Jan 05, 2014
    http://kmbs.konicaminolta.us/wps/portal/... on the "Find Support" banner, a drop down menu will appear with 3 columns: 1) for self care, 2) downloads 3) Customer Care & Support phone number.
  • 794 Answers
Http://www.manualslib.com/manual/288265/Konica-Minolta-Magicolor-1600w.html
Posted on Jan 03, 2014
  • 186 Answers
SOURCE: toner problems
A couple of suggestions. 1. make sure there is not any plastic shipping tabs that need to be removed from the cartridge. 2. try reseating the cartridge. 3. Try replacing that cyan cartridge. It may be defective. Also make sure you use Minolta brand toners!
Posted on Jun 29, 2007
SOURCE: Minolta 2300DL Magicolor printer
EAch cartridge has a small ( about 1/4 inch square) stainless steel color metal tab at the end of the cartridge opposite the refill cap end. The surface of this little tab is visible when the cartridge is "low" on toner and this causes the machine to give the message to change the cartridge. As the cartridge gets older I've noticed that this tab moves to the exposed position more readily, which causes the message to appear. If you google how to reset the position of this tab, then the message will not appear. EVerytime I refill the toner of a cartridge I check to make sure to reset the position of this little metal tab.
It is difficult to describe how to reset the position of the tab. You have to stick a small regular screw driver into the slot below where the metal tab appears and find the lever which can be pushed to reset the position of the tab. You can likely find photos of this procedure on google.
Posted on Sep 28, 2008
SOURCE: Magicolor 5430dl, "No Toner Magenta" error
Hi this might work, have you tried to remove the toner and re-seat it??
If this doesnt work very carefully take the toner somewhere well ventelated preferablly outside and give it a good shake for about 15-20 seconds, this frees any clogged toner there may be.
Failing all of that you would want to try outting a new toner in and see what happens.
Posted on Mar 23, 2009
  • 10406 Answers
SOURCE: minolta 2430dl, cyan, magenta, and yellow toner
Some printers will refuse to print _anything_, until you replace/refill _all_ of the empty toner cartridges. So, replace/refill.
Posted on Dec 30, 2009
SOURCE: how can u resolve all lights blinking on minolta
Unplug from PC, unplug from wall, leave unplugged for say 5 mins, and then plug back into the Wall, then, reboot PC, then plug into PC. Now should be OK. If NOT please use the manual below to troubleshoot whats wrong.
http://kmbs.konicaminolta.us/content/products/models/magicolor1600W.html
Posted on Apr 28, 2010
My C-M magicolor 5570 says toner missing C both with the old and new toner. What to do?
Are you sure you it is toner?. May be the image units. There is a toner for each color, Yellow, Magenta, Cyan and black. There is also a drum (Image Unit) for each color. Do not use third party toners and I/U they cause issues sometime with the machine software.
Sep 26, 2014 | Konica Minolta magicolor 5570 Laser...
UNIT DISPLAYS 1 UNIT END RELACE YMC
replace the image units Yellow, Magenta, and Cyan Image units NOT TONER
Jan 14, 2014 | Konica Minolta Magicolor 1600W Printer
Drums won't rotate
Open the front, leave it open. Open the top, pull out your drum. Put the drum back in, close the top. Close the front, let it rotate, and power off. Power back on and your drums should rotate automatically.
May 21, 2012 | Konica Minolta Magicolor 1600W Printer
My new Magicolor 1600w Printer hasthe toner light
Probably. Most color images have some black in them as well.
Aug 09, 2009 | Office Equipment & Supplies
Error message imaging unit is out
Hi rmcday: Here your problem. The imaging unit creates the image using an electro-photo process. The imaging unit consists of the following: ■ An OPC Drum ■ Waste Toner Assembly ■ Charge Roller Assembly 9.0 Consumables, Routine Maintenance Items and Options Item Life based on 5% coverage Part No. Replaceable by Black Standard Toner Cartridge Black High capacity 3,000 7,000 106R00679 106R00684 User replaceable Cyan Standard Toner Cartridge Cyan High capacity 2,000 5,000 106R00676 106R00680 User replaceable Yellow Standard Toner Cartridge Yellow High capacity 2,000 5,000 106R00678 106R00682 User replaceable Magenta Standard Toner Cartridge Magenta High capacity 2,000 5,000 106R00677 106R00681 User replaceable Imaging Unit 50,000 images 108R00593 User replaceable Transfer Belt 50,000 images 108R00594 User replaceable 500-Sheet Feeder N/A 119650600 Waste Toner Cartridge 3,000 to 5,000 pages (color 5%) 106R00683 User replaceable. Your imaging unit may have exeeded it life of 50,000 pages and will need to be replaced. Hope this helps
Jun 10, 2009 | Xerox Phaser 6120/YN Laser Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Minolta CMS magicolor printer 2300W
there should be a light flashing on the printer. try pressing the button nearest to it to see if that will move the print head out in order that you can replace the cartridge
Jul 18, 2007 | HP Printer Cartridges (Complete List): ,...
Toner problems
Apr 07, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta Magicolor 1600W Printer Logo
354 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
