Question about Konica Minolta bizhub C450P Laser Printer
Bizhub C450: After replacing the image transfer roller & ozone
Filter, how do I reset the message to replace same?
  • 210 Answers
In Service Mode -> Counter -> Life -> Select the one you want to reset and press 'C'
Posted on Aug 23, 2009
Color printing is printed with a yellow background in bizhub c450
have you replace the Transfer belt.??? It also has a transfer roller for yellow. (Called First Transfer) since it is transferring yellow off the drum. You have replaced the yellow image unit???? 2nd transfer is to the paper!!!
May 18, 2016 | Konica Minolta bizhub C450P Laser Printer
Fuser unit
can you explain more the functions of each are as followed fuser melts the toner to the paper so it dosnt rub off ozone filter filters out the ozone so you don't get headaches and turn al the rollers to bubble gum transfer roller pushes the paper onto the transfer belt applying the image to the paper and imagine unit is where thetransfer belt gets the image from
Aug 16, 2014 | Konica Minolta bizhub Office Equipment &...
How I can reset counter imaging unit bizhub c450?
u cant reset those , u have to change the counter chips .These are available in market
Apr 19, 2012 | Konica Minolta Office Equipment & Supplies
The machine says "replace ozone filter" i did that but the message won't reset itself. is there something i can do to reset it?
On most models of Color Bizhub machines, to reset the ozone filter message you must go into service mode. Press the Utility/Counter button on your operation panel, select meter count, then detail, press stop,0,0,stop,0,1. This will put you in service mode. Find and press counter button, Locate life counters, and clear ozone filter. You will not be able to clear some of the counters in this menu. They are automatically cleared when the items are replaced.
Apr 23, 2010 | Konica Minolta bizhub C351 All-In-One...
I have a Konica Minolta Bizhub C350 which is now indicating that it needs to have the image transfer roller unite and paper dust/ozone filter replaced. Where are these located in the machine and is it...
I would advise having a copier technician replace those items it is not that hard to do but if you dont get the roller seated in the holder properly it can destroy the transfer belt and that could get expensive
Nov 29, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Jan 17, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub c351
you have to clear the counters in tech rep mode.
Utility - counter - details- then the following sequence....
stop-0-0-stop-0-1 then press counter - life - then highlight the parts you changed and press the C button, then exit .
Jul 23, 2008 | Konica Minolta bizhub C351 All-In-One...
Need a reset code
hey.
You have to go to service menu ---> stop -> 0 -> 0 -> stop -> 0 -> 1 ---- and choose counter -> maintance/parts counter find these parts on the list, make them blue/touch them and touch C.
then exit to normal mode
good luck
May 05, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Need to know how to reset codes
To reset the life counters for the transfer roller & ozone filter you will need to enter the service mode.
To do this press utilty, meter count,details(if available), then stop, 0, 0, stop , 0, 1.
You should now be in tech rep mode, select counters then life.
Select the transfer roller/ozone filter button and press the C key on the keypad.
It should zero the life count.
Now press end, exit etc until you back at the copy screen.
Warning: Please do not reset or clear any other data within tech rep mode or you may inadvertantly affect the performance of you machine.
Hope this Helps.
Konica Minolta bizhub C450P Laser Printer Logo
1,707 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
