Question about HP LaserJet 4 plus Printer
Service error (01E4)
When I turn on my computer and the printer starts up, it gives me the error message (01E4). It will not print anything.
  • 53 Answers
You have a bad MIO card. If you remove the card the message should go away.
Card is in the back, held in by 2 screws. If you don't have a cable plugged into it, just remove it. Printer will work fine without it.
Char S.
Posted on May 21, 2009
How to fix lexmark s400 error messages
Please make sure that the Print Spooler service on your computer is running and enabled. Go to Start menu > Control Panel > Administrative Tools > Services. Select Print Spooler in the items. Right-click on Print Spooler > click Properties. In the General tab, select Automatic for Startup Type. Click Start for Service Status. Hit Apply, and then hit OK to save the settings.
Try to print a document again to verify that the problem is fixed.
Should the problem continue, maybe it would be best to contact Lexmark Technical Support Center to further diagnose the problem.
Jan 22, 2012 | Lexmark X2600 InkJet Printer
My canon has an error b200 and it doesn't print or do anything I command.
Well every advice is the same except a little altered (use a warm cotton swab to clean inside machine and on print head channels) but then it says if possible replace print head but honestly this has become a primitive Machine for turning humans into corpses - buy a new one.
Nov 02, 2010 | Canon PIXMA MP620 All-In-One InkJet...
49.00F service error
From the service manual:
A critical firmware error has occurred that caused the processor on the formatter to abort the operation.
This type of error can be caused by invalid print commands, corrupt data, or invalid operations.
In some instances, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or specific software programs.
Sometimes, the formatter itself is at fault, which is usually indicated by a 79 Service Error.
Recommended action:
1 Press CANCEL JOB to clear the print job from the printer memory.
2 Turn the printer off and then on.
3 Go to www.hp.com/go/lj4300_software, Select Download Drivers and Software. Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the one installed on the printer and the printer can receive a firmware update, download the newer firmware
upgrade. Not all HP LaserJet 4200/4300 printers can receive firmware upgrades.
4 Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
5 If the message persists when using different software programs and attempting specific print jobs,
disconnect all cables that connect the printer to the network or a computer.
6 Turn the printer off.
7 Remove all memory DIMMs or thirdparty DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
8 Remove all of the EIO devices from the printer.
After performing the actions above, procede with the following:
1 Turn the printer on.
2 If the error message disappears, reinstall each DIMM and EIO device individually, making sure to turn the printer power off and then on again as you install each device.
3 Replace the DIMM or EIO device that caused the error message.
4 Remember to reconnect all of the cables that connect the printer to the network or computer.
5 If this error message persists, replace the firmware DIMM.
6 Replace the formatter assembly.
Jun 16, 2009 | HP LaserJet 4300dtn Printer
Printer won't print anything.
Try to uninstall the drivers and turn off the printer. Then install the drivers back on and turn the printer back on. And then make sure this printer is set as default.
Mar 27, 2009 | Canon Pixma MP480 All-In-One InkJet...
Ricoh AP2600 printer gives an error message of SC322
1st Laser synchronization error signal error. The 1st Laser that turns on inside of the printer can't synchronize properly to print out documents which is why this message comes up and nothing is printing. Probably is going to need to be replaced but a qualified service tech is going to need to look at it further.
Feb 10, 2009 | Ricoh Aficio AP2600 Laser Printer
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
DISPLAY READS: 80 SERVICE (01E4)
If you keep getting 80 service, first recycle the power to the printer (try a few times if the error doesn't go). If that doesn't work replace the MIO card (the bit the network cable goes in)
Jun 16, 2008 | HP LaserJet 4 plus Printer
Scaner Epson CX-5400 error message
What is the error message? SCANNER ERROR?
If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
Feb 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Printer message: Unable to Print
5A: encoder disc or encoder strip or main circuit board or printhead circuit board or power supply defective!
Sorry, cant be fixed by yourself!
Feb 20, 2008 | Brother MFC-440CN InkJet Printer
Printer refuses to print anything
Rerun the CD that came with the printer.
Jan 11, 2008 | Epson CX4200 All-In-One PSC Printer
HP LaserJet 4 plus Printer Logo
183 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
