Question about Mach Speed Trio Mach Speed 7" Trio Stealth Pro Tablet
My Trio Stealth Pro wont charge properly
Everytime I try to carge my tablet it either wont charge at all or says its charging but the battery slowly drains or doesn't charge at all.
  • 3 Answers
Graphic driver download
Posted on Jan 05, 2014
Can I replace the battery? It will not charge fully like it used to. Charger appears to be OK (5.46V)
Try cleaning the connector on the tablet first with contact cleaner. Also the connector on the cable.
Jun 05, 2015 | Mach Speed Trio Stealth Pro 9.7CM 4.0 Trio...
Trio stealth tablet will not go past logo
This may be unrelated, but if you let the tablet go to sleep it will drain the battery. I found this out with my Stealth Pro about three months ago, I imagine it is more of an Android issue. It would not startup or go past the opening logo until I had charged it enough. This may also be the case if the battery is damaged or will not take a charge, in theory.
Aug 21, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
My trio stealth 10 MST10-21 won't stay turned on
This may not be the problem, but worth checking. I ran into this the other day with my Trio Stealth pro tablet. I had left it on while unplugged and it drained the battery completely in sleep mode. It would only show the startup icon and shut right off. After a complete charge it is back to normal operation. You might try making sure the charge is full, maybe the battery has gone bad and that would also affect operation. Also try starting it up without the SD card in. If it doesn't mount properly or a file is corrupt, it may act strangely. I believe it scans the SD card first and may be trying to startup on it. Other than the above mentioned, it could still be hardware related with Ram or CPU problems. Good luck in finding the problem, tablets can be fun but frustrating sometimes.
Jul 06, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
Trio stealth pro wont connect to pc
trio tablet ge wram when chargeing and want power up
Feb 26, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
Charge trio g2
Hi Jennifer,
Battery error or charger error.try with new charger or usb cable.
if you have warranty you have no problem and go for warranty.
regards.
nuwan
Jan 10, 2014 | Mach Speed Trio Tablets & eReaders
My trio stealth g2 7" tablet wont turn on
Check for a bad battery, charger in that order.
Each can be gotten inexpensively on ebay. eBayeBay
Sep 04, 2017 | Trio Stealth G2 7 inch Tablet with 8GB...
What number do u do if ur trio stealth pro is not working
More then likely you powered the unit on before it had enough of a charge to operate, Chargers for these types of tablets are way to little power for these things, will hold the charge when you use it but will not charge the unit when you use it, needs to go into standby to charge. Hold the power button and see if you can get a reboot screen or a turn unit off screen. Turn the unit off fully let it charge up alll the way then powere the unit back on. Should reset it. If not look for a small hole in the unit that says reset. push this and see what happens.
Nov 28, 2013 | Mach Speed Trio Stealth Pro Trio Stealth...
Mach Speed Trio Mach Speed 7" Trio Stealth Pro Tablet Logo
280 people viewed this question
Top Mach Speed Trio Computers & Internet Experts
juanmireles1
Tom Chichester
Mister Danger
Are you a Mach Speed Trio Computer and Internet Expert? Answer questions, earn points and help others
