Question about Garden
Toro problems drive and steerig on right hand side stop working after about 2 hours use,if you turn mower off for a short time it will drive again,i have a toro z5020 time cutter about 5years old
SOURCE: toro personal pace mower 5 yrs old only runs 10-15 seconds.
Was gasoline left in the tank during off season? Sometimes gas will break down and clog the jets in the carb. The priming bypasses the carb so when you put fuel in by pumping the bulb it runs, but dies becasue no additional fuel is coming through the carb after the primed fuel is burned off. Sounds like you need to clean the jets in the carb and in the future, use Stabil in gasoline to keep it from breaking down.
Posted on Jun 30, 2009
SOURCE: Toro 22in Lawn mower. Loud gear noise when try to engage drive.
Problem is in the rear pinion gears on rear axle and the design of the axle itself. I have a 2005 model 20041 had the same problem. I found a Toro dealer that had the fix.The problem is creadted by the fact that there is too much "play" in the rear axle. You have to limit that play by installing shims, or washers First, but the 2 new rear pinion gears for the rear axle. While you're at it, you may as well buy 2 new rear wheels because the "grinding" has worn the sprockets on the reas r wheels.Next, get 2 "fender washers", 1/2" ID and about 1" OD. I found it easier to turn the mower over and set it on saw horses to work on it.( drain the gas and oil first). Remove both rear wheels, pinion gears and all the washers etc. (caution - keep all parts from one side together - do not pile all parts together - keep them seperated by wheel - the reason is I believe there is one more washer/shim on the right side than on the left). Now to put everything back together, find a spot on the axle where the washer will fit in between the standard stuff.Install new pinion gears and replace the rest of the washers/shims just as they came off. INstall new wheels and you'll be good as new!
Posted on Aug 02, 2009
  • 64 Answers
SOURCE: TORO Z5000 zero turn mower. right side
it should hold hydralic fluid there should be a resirvour somewhere on the back along with the pump you should be able to check the level there and if you don't get the leak stopped it will lock up the whole drive system.
Posted on Aug 23, 2009
  • 4 Answers
SOURCE: Toro Personal Pace Mower won't start w/ electric starter
There are a couple of things you can check;
First, check to make sure the bendix is engaging. It is the gear that meshes with the fly wheel.
If it is, then try and see how fast the motor is spinning. Don't look at the blade though. It could be a faulty starter motor.
Make sure to also check the battery voltage with a volt meter. It should read at 12.0 or higher.
Posted on Mar 03, 2010
  • 4961 Answers
SOURCE: cant turn toro time cutter to the right
You might want to post this question in the lawnmower section so that the proper expert sees it.
Posted on Sep 03, 2012
Mower will not drive to the right I changed the o-rings and filters on both drive motors and re-filled unit with oil but now unit will only drive with left hand no right hand action.
Sou.d like the hydrostatic transmission completly failed upon right hand drive the main gear is not engaging right drive
A knew transmission unit should fix the problem but part is pricey
Jun 20, 2016 | Toro Titan ZX5450 (54") 25HP Zero Turning...
Cant turn toro time cutter to the right
Sep 02, 2012 | Toro Mowers - Time Cutter SS4235 42""...
My toro zero turn seems to overheat and stops moving from left side about half hour it runs fine.?
First check to see if you have any leaks especially on the problem let side. This includes the wheel motor. where hydro oil comes out, air can go in. either way it sounds like you need to take your pump out and open it up and check for metal inside. If you do not have any metal inside check the 5 pistons to see if they are stuck. What series hydro pump do you have?
10L 10A etc.
Jul 28, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro choke doesn't work
try cleaning out the carburator.
May 23, 2017 | Toro Lawn Mower With Toro Power Tools
Hello I have a toro zero turn rider z4220 I think I bought it new about 2 to 3yrs ago when I was putting it up last winter the left drive would not go forward or reverse then shortly there after the right...
Hello, W/D here.
Look for a transmission disconnect rod, usually at the back of the tractor, about even with the top of the gearbox. If it has been moved to the out position, the transmission will not operate from the seat, but you can push it.
Good luck, --W/D--
Mar 17, 2011 | Toro Zero Turn Rider 74366 Lawn Mower...
I have a Toro 6.5 HPTecumseh .The pull cord is difficult to pull and will actually **** the cord back to the engine.The engine sounds as though it would start,but does not. Joe W
Have you tried lubricating the drive shaft? If you turn the mower on its side and try to manually turn the blade by hand and it's difficult to turn, you just need to lubricate the shaft where it slides into the body of the mower. Several shots of WD-40 or oil should lube it up and then it should turn easily again.
Hope that helps!
Jun 11, 2010 | Toro Lawn Mower With Toro Power Tools
I have a Toro Proline walk behind . Problems with the self propel
I suspect the drive belt, not the Hydro. Especially if the drive belt was never replaced. The belts are known to stretch and wear out over time. It's a cheap part.
Jun 04, 2010 | Toro Lawn Mower With Toro Power Tools
Aug 23, 2009 | Garden
Garden Logo
424 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
