Emachine e525 is black. External monitor works fine. Can see icons with flashlight.
    Top Expert:
  • Computers & ... Master
  • 26,713 Answers
The backlight has failed in your laptop screen. It could be a job for a competent technician.
Posted on Jan 03, 2014
  • 1 more comment
  • Tom Lee Jan 07, 2014
    After pressing Fn + F6 a few times, the screen comes on and stays until I reboot.
  • JonSnell Electronic
    JonSnell Electronic Jan 07, 2014
    I assume you run Win7. In that case, the screen and backlight are fine. Theissue may be cured by right clicking on the battery icon, select mobility and switch the screen with Connect Display. Other platforms may have to be accessed through control panel. Hope that helps.
    According to the manual, Fn + F6 toggles the backlight on and off to save power. When the screen first comes up it is black but toggling this function tries to turn it on. It flickers at first, then comes on and goes off. After several toggles, it finally comes on and stays on until I turn it off.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 29 Answers
If you can hold a flashlight on an angle and somewhat see what's on the screen it means the back-light of the display is dead. LCD actually don't light up on their own, so the back-light is what provides the brightness so you can actually see what's on the LCD screen.
The back-light will have to be ordered specifically for your screen, as they greatly vary in size and shape. You can either replace the back-light yourself, which is a very technical job, or have almost any computer repair store do it for you. If your computer is still under warranty this would be classified as a manufacturer defect.
Geekman
  • 32281 Answers
SOURCE: lcd screen black on laptop. External monitor works.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 31, 2009
  • 72 Answers
SOURCE: Bought new E525, cant get wireless networking to work
Some laptops have switches that you have to turn on manually in order ffor it to work look for a switch usually on bottom of the laptop under or near touchpad
Posted on Jun 17, 2009
  • 85 Answers
SOURCE: How do I get my webcam to work. I have e525
Hi
Might be worth checking if your device drivers are installed correctly.
Link for drivers is here: http://support.emachines.com/em/driver/nb/e525.html
If you are using MSN you may have to use the Audio and Video setup wizard to configure it to work correctly. Pretty straight forward as long as you just follow the steps.
Taz
Posted on Oct 24, 2009
  • 76 Answers
SOURCE: open the computer box laptop emachine e525
with your hands.
Posted on Feb 03, 2010
SOURCE: I have a emachine E525 and can't seem to find how
click on start and go to all programs locate the folder that says video web camera the click on it and click video web camera with the gray and blue icon next to it ur webcam should load after that
Posted on Jul 06, 2010
Latitude B130 screen works great then cuts out to complete black, works with external monitor
Are you sure that the display is not set for external monitor only? Also take bright flashlight and shine on the display. If you can see the images then the problem is with the back light and usually caused by a bad inverter. Some times you can get the back light or inverter bu most times it is easier and cheaper to replace the entire display.
Aug 20, 2012 | Dell LATITUDE Computers & Internet
Gateway m280 notebook black screen.
Why did you replace the lcd inverter? Were you able to barely see icons on the desktop which is an indication that the lcd inverter is bad? If not, then you need to replace the lcd screen. If you could barely see the icons and you replaced the lcd inverter, then the inverter is bad. Just because the inverter is new does not mean it works. If the video shows on the external monitor, but you can't see anything on the laptop's screen even when you shine a flashlight on it then the lcd screen is bad.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad.
If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 24, 2012 | Gateway Computers & Internet
Charging and monitor issues
If your AC Adapter and Power Cord is working fine, then your new battery has a problem if it will not charge. Just because it is new does not mean it will work.
As for your Monitor, try the steps below. Because it works with an external monitor, we know your Video Card is working fine, so the problem is either the LCD Inverter or the Lcd Screen itself is bad.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 16, 2012 | Dell XPS 1530-146P (X1530-146P) PC...
My acer aspire laptop 5336-2524 worked fine until today when i turned it on everything works fine except the screen stays black. What can i do to fix this
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 01, 2012 | Computers & Internet
Gateway 5150 - computer screen stays black, screen works fine, just very very dark - can't seem to adjust luminosity?
Apr 09, 2012 | Computers & Internet
Laptop starts up then the screen stays black
Apr 08, 2012 | Computers & Internet
Cannt get my mini hp 1151nr to boot up only get black screen cannt get to windows
Black screen? So does it look like it booted up fine or did it shut down? Does it look like the computer is running, but the screen is black? If so, then:
Apr 02, 2012 | HP Computers & Internet
My acer is black screan how to back normal
Mar 30, 2012 | Acer Computers & Internet
I have a emachine E525 and can't seem to find how to use the webcam. I have been in the control panel under cameras but it doesn't seem to find it. Do all Emachine E525's have a webcam?
Jun 01, 2010 | Acer Computers & Internet
Don't know what to do !
connect external monitor to see if adapter is ok. If external monitor comes on OK,(check to see if the FN+F5 or another key has to be toggled for external display) then shine flashlight on screen to see if Icons are visible. If the Icons are visible LCD inverter would have to be replaced. If external monitor works and Icons are not visible lcd is probably no good, If external monitor does not work then Video adapter is bad.
Apr 05, 2008 | Compaq Armada 1750 Notebook
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
