Question about Home
How to fix a running toilet - Home
How to fix a leaky toilet
    1. Turn off the water at the shutoff valve, flush the toilet and hold down the handle. There may be a little water left in the bottom of the tank, but don't worry about it. Wipe the flapper seat with a clean cloth to make sure it's free of debris, and check it for cracks or splits (Image 1).
      How to Fix a Leaking Toilet ' how-tos ' DIY
      www.diynetwork.com/how-to/.../how-to-fix-a-leaking-toilet DIY Network
    Feedback
  1. How to Fix a Leaky or Runny Toilet - This Old House
    www.thisoldhouse.com > ... > Toilets
    This Old HouseA toilet that leaks or runs is an easy homeowner fix-if you know how to diagnose the trouble. ID parts and problems with this handy guide, and hit the hardware ...
Dec 26, 2015 | American Standard Home
I have a mansfield toilet and after flushing it keeps running, how can I fix that?
Not sure about your brand but many toilets have a flapper valve inside the tank which needs adjusting or replacing. Try this U tube link
How To Repair Mansfield Toilet
Apr 06, 2015 | Home
Fix a running toilet
Faulty flapper sealing. After a flush, the flapper does not seat correctly or completely allowing water to run into the bowl.
Jun 08, 2014 | Home
Water drips from small holes upper sides of toilet
There may be something jamming the shut off control valve This is fully covered if you past this link in your browser; http://www.wikihow.com/Fix-a-Running-Toilet
Mar 08, 2013 | Home
How to fix running toilet
if toilet is running non-stop, check flap in tank. possible handle not returning completely holding flapper fron seating tightly. if toilet runs, then shuts off for awhile then runs again, flapper needs replaced.
Jul 19, 2012 | FLUIDMASTER INC #B1FV16 16" Faucet...
Toilet runs slightly, can minimally depress the handle to release a bit of water, and it will stop. How to fix?
Toilet runs continuously or doesn't flush adequately
Jiggling the handle might work for a while, but if your toilet is always running or doesn't flush adequately, you need to perform these simple fixes that usually can tame a noisy, inefficient toilet.
Check the Chain
The chain attached to the rubber flapper often becomes loose, causing incomplete flushing and/or continuous running. To fix it, remove links from the chain using needle-nosed pliers until it's tight.
Check Water Level
Improper water levels can also cause problems with your toilet. This can be fixed by adjusting the ball ****, which is located next to the overflow pipe, the open tube to the right of the handle. Adjust the ball **** so the water comes to ½ " below the overflow pipe.
Clean the Surface of the Flush Valve
A continuously running toilet can also be the result of a faulty flush valve. Because the valve is made of rubber, it can decompose or warp allowing water to escape from the tank into the bowl. Clean the sealing surface to see if this will improve the seal. If too decomposed or warped the valve may need to be replaced.
Replace the Flapper
Remove old flapper and replace with a suitable replacement. Attach the flapper to the overflow pipe inside the bowl. Then attach the lever chain from the flapper to the handle lever making sure the chain is taut.
This video will help familairaize you with the flushing mechanism and the repair:
Dec 18, 2010 | Toto Drake ADA Compliant Toilet with...
We have a crane toilet that worked perfectly and now it just wont quit running and water is leaking out the side how do i fix this im tired of shutting off the water to the toilet after it fills up
It sounds like it is running constantly because of the leak. Where is the leak, at the bottom, around the plastic nuts underneath or is there a crack in the tank? Let me know.
Fix the leak and will have fixed the running problem
Jul 09, 2010 | Crane Plumbing 3755 Toilet-To-Go Metro...
8950 - Metro Urban Toilet - Two-Piece Toilets: water doesen't stop running...
Either the Fluid-master valve is going bad or your flapper needs to be replaced. Both are an easy fix. To check the flapper run your fingers along the underside of it, if the rubber comes off on your fingers its bad. Otherwise you'll have to try replacing your Fluid-master valve.
May 16, 2010 | Neo Metro 8950 - Metro Urban Toilet -...
My toilet runs constantly
How old is the toilet? Might have lime buildup in the housing that's keeping the float from raising completely. The whole assembly is relatively inexpensive at Wal-Mart, and very easy to change. It would probably be less hassle than trying to fix the old one. I found that out after wasting a lot of time trying to mix my old one. :-)
Aug 30, 2009 | Kohler Toilet - One Piece with Ingenium...
Home Logo
234 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
