Question about Big Boss Oil-Less Fryer 8605
Light will not come on and the fan just runs.
How do i rewire my ceiling fan/ light so the fan will run when the light is off?
Go to home depot or lowes and get a different switch,tell the salesman what kind you want and he will show it to you.
Dec 22, 2012 | Dryers
Bathroom fan is on the same circuit with the light. Is there a switch that I can install on the fan so that I can control it from the light switch without running an additional wire?
It depends in part on the fan. Many but not all give you the option to run seperate feeds for the fan and the light, which is necessary to do what you want. If you are experienced with electrical work, you will be able to tell because the feeds for the fan and light will be pigtailed together in the small junction box built into the fan housing. You will need to run a new cable to the location where you plan to mount the 2 switches also... hope this helps
Jun 01, 2011 | Cooper Wiring Devices ACE DUAL CONTROL...
I need help hooking up my bathroom fan and light i have three wires going to the bathroom fan and light white black and ground i want a swith to turn off the bathroom light one to run the light to the fan...
Right now a single switch turns on both light and fan.
You want to put in a double switch to control light and fan separately.
But the problem is there is not a separate wire to each the light and fan.
You need a separate wire to each, but the circuit wasn't wired that way.
Usually when the circuit is wired for separate control, there is a red wire that also goes to ceiling box.
Unless you run another wire to the ceiling box, it won't be possible to control light and fan separately.
Electrician can do this pretty easily if there is attic space above bathroom.
Oct 17, 2010 | Broan-NuTone Broan 68W White Decorator...
Ceiling fan won't run but the light does work. Fan has worked in the past but now just the light works. Why would the fan not work? This is a Hampton Bay Northport III ceiling fan ( product of Home Depot)
mcdevito75 here, You say fan worked in the past, That tells me the fan has not run in over 1 month if so, try this. First, the fan motor is a sealed unit, without running the fan in over 1 month it may be a little stiuck, put the fan lights on, and pull the fan chain just once and turn the fan blades themselves just a little to get thm started. also verify fan switch itself is good, Chain switch should have the familiar click click to it. If not the fan swich could be bad.
Jul 20, 2010 | Hampton Bay 52 In. Northport II Fan, BN
Hey i just took a pot light out of the roof of my bathroom to install a fan and light combo in the whiring for the pot light the whiring is on a normal switch and is whired into another light over top my...
yes, maybe- if there is power in the switch then you can steal power from it.. Take off the coverplate and remove the switch. If there are two seperate cables in there with a black and white or a black white and red then there is power there.. You will however need to run one more single wire to the fan, and another switch. You can get a double switch that will fit in the single box..There is one other way to turn the fan on and off, but the light has to be on for the fan to be on, without running new wires. Get a simple pull cord switch and mount it in the face of the fan housing. Then find the black wire running to the fan and seperate it where it ties into the power. Connect the black wire from the fan to one of the wires on the pull switch (either one) and connect the power wire to the other wire on the switch.
Dec 06, 2009 | Broan-NuTone Broan Ultra Silent, Bathroom...
I tried to install a fan light control switch for
The reason the fan and light are running together is because the are both running on one power wire. The three wires you have in the wall are probably white black and bare copper. You need to run a four wire cable which has a white red black and bare copper in order for you to separate the light and fan and for the circuit to run properly. A DIY electrical book from lowes or the home depot would help you alot with your situation.
Jul 12, 2009 | Casablanca Fan (3845T) Brushed Nickel...
Error code of 6 flashing light on circuit board,
There appears to be a short in the unit. Not sure where. The power to the fan is not interrupted completly when the fan shuts down, still feeding voltage to the fan, keeping it running slow. Before checking the wiring, please turn off power first.
Nov 19, 2008 | Heating & Cooling
Ok i have a problem. we are add a fan and a light kit t the ceiling. the builder olny put one light in a corner. the light switch is a sing. and we are putting in a duble. we have to run a wire from fan to...
home run and rec wire together with a jumper to one side of each switch. black wire to corner light goes to other side of switch 1, black wire of fan goes to other side of switch 2
Aug 09, 2008 | Hunter Ceiling Fan Light Switch Control
Lights on in frig and freezer but no compressor or fan running
Remove and test the fan. If it has failed the Compressor may not run.
May 03, 2008 | Amana ABB1921DE Bottom Freezer...
Big Boss Oil-Less Fryer 8605 Logo
22 people viewed this question
Top Big Boss Kitchen Appliances - Others Experts
Danny Kuhlmann
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Big Boss Kitchen Appliances - Other Expert? Answer questions, earn points and help others
