How to change password on 2wire 828 - Computers & Internet
Hi i want to chang my net password how to chang?
Hello
I got the information from the user manual on page 31:
http://www.2wire.com/pages/pdfs/2701HG_user_guide.pdf
Open a Web browser and access the 2Wire gateway user interface by entering
http://gateway.2Wire.net.
Click the Home Network tab.
Click the Wireless Settings link to open the Configure the Wireless Network page.
On the Wireless Security section select custom key ,enter new key and then click on Save at the bottom of the page.
By the way the default /current password is underneath the router.
hope this helps
Feb 17, 2012 | 2wire (2701HG-B) Wireless Router
3600hgv lost password
-How to Change the Settings on a 2Wire Router
Instructions
    • 1
      Open your "Start" menu and go to the "All Programs" section. Open the Command Prompt program in your "Accessories" menu.
    • 2
      Type "ipconfig" in the Command Prompt and press the "Enter" key. Make note of the default gateway address that is displayed here.
    • 3
      Open Internet Explorer and type the default gateway in the address bar to load the 2Wire router's interface.
    • 4
      Click on the "System Password" link if you do not know your password for the 2Wire router. You will be asked to reset it with the system key printed on the router. Or call 2Wire support to get a temporary password.
    • 5
      Navigate to the "Broadband Link" icon to edit the authentication settings used to connect to the Internet. Use the "Home Network" icon to get to the wireless settings. Click on the "Firewall" icon for settings such as port forwarding.
Dec 14, 2011 | 2wire Computers & Internet
I have a at&t router but changed providers, can i still use it?
YES as long as your service provider authentication with the username and password:
Try this links:
2wire installation guide: http://support.2wire.com/?page=view&article=765
changing wireless settings: http://support.2wire.com/?page=view&article=60
wireless configuration guide for windows XP: http://support.2wire.com/?page=view&article=224
wireless quick reference guide: http://support.2wire.com/?page=view&article=47
this are some articles that may help...
just message me back if you still are encountering some problem - provide some error message as well and any info that may help us configure your 2wire
Sep 01, 2011 | 2wire 2700HG-B Router (2700HGB)
When asked for password on iphone it will not take password. how do i change password
if your referring with the wireless password
check the links out
and if referring about the network key:
2wire wireless network key
The network key is located at the side of the router you will see a barcode on it. It indicated the wireless network key.
If you have questions please let me know. Thanks
Aug 23, 2011 | 2wire.net
Connecting to a "2WIRE" wifi connection. Says the
I understand that you are having trouble connecting your Nintendo DS wirelessly to your 2Wire router. The solution is simple, your Nintendo DS only supports WEP (Wireless Encription Passkey) security. It is highly possible that your 2Wire router's wireless security is set to WPA. That means you will need to reconfigure your router so that it will be utilizing WEP as a security for your wireless connection. To be able to do this, you need a couple of information from the one who setup your router. 1. User name of your router 2. Password or your router.
Once you have gotten this information, you will need to access your router configuration page through one of the computers that is linked to your 2Wire router by typing http://gateway.2wire.net on the address bar of your browser.
It will be asking you for the username and password. If nobody had setup or changes the username and password of the router, use this default username and password of a 2Wire router. Username: (none) Password: Wireless or Username: 2Wire and Password: (none). Try any of the two. If it does not work, try admin and the word password for the password or any other combinations of the two.
Once you have entered the router's configuration page click the Home Network Tab and then click on Wireless Settings. You will see there a portion that says Wireless security. In that area, you will see a drop down where you can choose what kind of wireless security you want on your system. As I have said, the Nintedo DS does not support any other wireless security setting but WEP. That means you will need to change the drop down to WEP. That also means after changing this, you will need to reconfigure your other wireless devices (like your laptop) to use WEP as well.
Jul 21, 2011 | Nintendo DS Lite Console
Im trying to get on the internet with my psp go but the wep for 2wire 173 is lock for my computer and i dont know the key
check the links out
Apr 26, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
What is the default password to my 2wire password. i need it so i can change my IP address.
Leave the Username blank and the password is
Wireless
If that does NOT work, try this
Username = Admin
Password = Wireless
Hope this helps!
Dec 16, 2010 | 2wire (1000-400108-001) Router
Set a master password for 2WIRE router
In order for you to reset your 2wire to default, you can press the reset button on the bottom part of your modem. Once you access you modem interface it will set to default.
Or you can also type 192.168.1.254 on the address bar of your browser to change the password.
Jan 19, 2009 | 2wire 2700HG-B Router (2700HGB)
I need my 2wire password reset
Make sure your computer is hardwired to the 2wire.
Type http://192.168.1.1
Username and Password = admin
Go to Advance wireless and look for wireless security
You can simply disable it or change the key.
Save or Apply.
Oct 22, 2008 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
David Payne
David Payne
