Question about Whirlpool AD40U Humidifier
Dehumidifier blowing cold air is that normal - Whirlpool AD40U Humidifier
2 Suggested Answers
  • 10865 Answers
SOURCE: does not dehumidify
Hello. I am here to help. Let me begin by saying that a dehumidifier only needs to be operated if the humidity in your home is too high. If the humidity is low, the humidifier will have to work really hard to try and remove water from it.
Here is an overview of how the dehumidifier is supposed to work:
When the unit runs, the circulating fan and compressor also run. The fan continually draws room air over the evaporator coils, which are cold, and then over the condenser coils, which are warm. Because the evaporator coils are cold, the moisture in the room collects on them--just as the outside of a glass of icy liquid "sweats" on a warm, humid day. When the moisture on the coils increases, it drips off of the coils into the collection container.
The air then flows over the warm condenser coils and out into the room. This process removes water from the air and, because of the heat from the fan motor and compressor motor, the exiting air is somewhat warmer, as well as dryer.
Posted on May 20, 2009
Humidifier blows cool air only not collecting water
a humidifier doesnt collect water only disperses it. a dehumidifier collects water
Jul 05, 2017 | Humidifiers
Is it possible that the de humidifier has soaked up all the water in the room
I doubt that would be possible with a consumer grade dehumidifier even if you sealed off the room so that no more air could get in. In a normal house you constantly have more moisture coming in with the air.
How To Use Dehumidifier To Dry Room
Feb 20, 2017 | Humidifiers
Air blows cold rather than warm --- does not appear to dehumidy
it blows cold air and then it start to blow warm air what is the problem,
thank you
Michelle
Mar 13, 2010 | Whirlpool AD50USR 50 Pint Per Day Ultra...
Mod#BLU100K948A The 2 selenoids on top of gas valve click when they open (normal). Sometimes they work fine, sometimes they have a rapid clicking noise and do not open the gas valves. Furnace just runs and...
The first thing to check would be the filters in the house to make sure they are clean, then check for any blockage. One easy way of seeing if the airflow is good, just put your hands in front of a vent and see how its blowing. Your furnace has what you would call sensors, and if they sense the air flow is inaccurate or to hot inside the unit, the unit will run, but not light. Also, if it tries to relight to many times, the furnace will go into lock out and you have to manually reset it by cutting the power to the furnace. Its kinda hard to diagnose these sometimes over the pc, but I hope it helps.
Nov 02, 2009 | Honeywell Power Humidifier: Furnace...
WHAT SETTING DO NEED MY BASEMENT IS MOLDY %SMELLY I HAVE IT SET AT 35
Hi! is it a humidifier or dehumidifier? if you want to remove mold you need a dehumidifier to absorb the moisture on the air. provided that the unit is capable of absorbing the moisture on your basement floor area. because a typical dehumidifier can only accommodate a 21 square meters floor area.
Sep 01, 2009 | Aprilaire 550 Humidifier
Not pulling moisture from the air
Humidifiers put moisture into the air you want a dehumidifier
Aug 22, 2009 | Humidifiers
Dehumidifier - hot compressor / coils not cold
If the compressor's running and it's getting hot and the coil isn't getting cold, then you are probably low on refrigerant or your txv or metering device isn't working.
Jul 30, 2009 | Whirlpool AD50USR 50 Pint Per Day Ultra...
Does not dehumidify
May 20, 2009 | Whirlpool AD40U Humidifier
Cold air and smell
replace the humidifier pad every season you may also want to install UV lights
Apr 02, 2009 | Aprilaire 550 Humidifier
Humidifiers Logo
24 people viewed this question
Top Whirlpool Humidifiers Experts
Mack Baxter
Dennis
Are you a Whirlpool Humidifier Expert? Answer questions, earn points and help others
