Question about Samsung (SP0411N) 40 GB Hard Drive
Samsung SP0411N HDD, error message while booting shows "Pri Slave Drive - ATAPI Incompatible" "Press F1 to resume" thakurbs@hotmail.com
Null
  • 4 Answers
Hi guies ,
                   you haven't specify which kind of error message displayed on screen ,please  do same
Posted on Oct 24, 2007
  • Dan Buonagurio Oct 14, 2011
    Error message A S.M.A.R.T error has been dectected.
I have a new Samsung SP0411N hard drive , I want to replace the hard drive but the bios say Pri Master Hard disk S.M.A.R.T . Command failed . Any help Please .
check your cables, if its ok,
check the jumper, if theres any,
try boot with only one hdd.
else, try consult to the manufacture for firmware update. there might a compatibility problem.
Oct 16, 2013 | Samsung (SP0411N) 40 GB Hard Drive
Ai got an old computer and it it work but it show me an error with American Megatrends
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure the CPU central processing unit has thermal paste and dust free and is securely seated
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
hope this helps you
Jan 07, 2012 | Computers & Internet
S.smith1@hotmail.co.uk How do I slave HDT721050SLA360 500GB 7200rpm
if you want to set a master / slave on you computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
note the plastic jumper is
Aug 26, 2011 | Hitachi Deskstar 7K1000B HDT721050SLA360...
I have 2 hard drives i want to make one master and 1 slave model HDSJ oth 7200 rpm
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
if you need more help with this post a reply
Hope this helps
Aug 18, 2011 | Samsung Spinpoint F1 HD102UJ 1TB 7200 RPM...
Hello, my name is nike. i have a problem with my hdd. when i turn on my pc it's always "primary master system disk fail" can you help me with my problem. and when i press f1 it's always...
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they are probably old and faulty ?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
Apr 20, 2011 | Samsung (SP0411N) 40 GB Hard Drive
Pri master hard disk: S.M.A.R.T. command failed
there is problem with hard drive kindly replace it.
have a nice day dont forget to rate pls.
May 11, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Whenever I boot I get the followoing msgs- pri master atapi cd rom primary slave ide hdd primary salave hd smart command failed no 1de master hdddetected press f1 to continue-- then okay But sometimes...
please change the wire connection in your pc from CD rom to HDD so that HDD become primary master and cd rom become primary slave, check after this, and if still get error check your IDE cable, and for the smart command fail may be your HDD didnt support smart feature, so disable this from advance setup
Aug 21, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Can't enter Setup.
This may be an obvious question, but did you check the jumpers on the Hard drives? Make sure the master is set to master or to CS (cable select) then try again.
Jan 28, 2009 | Computers & Internet
Cd drive changing
Your computer cannot find The Hard-drive Or operating System.
Your Primary Hard Drive, is reporting an error.
Try changing the Jumper setting on this From Master To slave.
( jumper is amall plastic Block ) on back of drive.
Then set your CD/DVD To Master.
Mike @ Compurepair.
Mar 14, 2008 | Audio Players & Recorders
Samsung (SP0411N) 40 GB Hard Drive Logo
262 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
