Question about Sony Playstation 3 (PS3) Console
The screen is very blurry on every game but not blurry when watching tv
Hi, when i watch netfliks, my tv screen turn blunk, my internet is good my tv is good so the problem is with the roku ,since i watch nnetflix tru roku box
Hello Dear
Don't suffer through annoying pauses or blurry, low resolution. Here's how to get better streaming from your smart TV, streaming box or game console. Check out here....
For any Help or support visit here: www Roku Com Support
May 13, 2018 | Roku Televison & Video
Blurry picture on my 70" vizio
As previously mentioned, try a known good DVD to the same connection (BE SURE TO USE A DIFFERENT CONNECTING CABLE,as your connect cable may be at fault) Also try any of your other inputs to the TV to eliminate 1 or more input issues.
Mar 21, 2014 | Vizio L32 32 in. LCD HDTV
Screen on all games is blurry. Just started
make sure its not your tv.there might be something wrong with your xbox or you did something in the options menu that messed it up
Jan 20, 2010 | Microsoft Xbox 360 Console
Watching a football game picture is very unclear
The noise reduction option will cause a blur on fast movement. Also, you probably already know this, but a standard definition broadcast will look very blurry on an HD TV, so make sure the channel you're watching is actually an HD channel.
Oh, wow, I just noticed that this is from October. Oh well, maybe you're still having problems.
Oct 18, 2009 | LG 50PS60 50 in. Plasma HDTV
My LCD tv's menu screen keeps popping up and won't stop.
Since it is brand new then should be OK.
Please return it to store and get another TV.
Feb 24, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Blurry tv screen
If you are comfortable on doing adjustment with working TV then take off back cover of TV and check flyback transformer, there you would see 2 control knobs, upper knob if to adjust focus. rotate it CW or CCW to obtain maximum focus on TV screen.
Put back cover and enjoy.
Feb 10, 2009 | GE Televison & Video
Blurry Screen on Panasonic CT-32HL44
I solved my problem. Apparently the RCA cables where missing with the image. So I bought some Component cables and that fixed my problem.
Dec 30, 2008 | Panasonic CT-32HL44 32" TV
Blurry Screen
ok your problem is the RGB section maybe crack soldered at the RGB try to resoldered it! you seen that at the back of the picture tube they have small board attach at the neck... resoldred all small part, and transistor drivers!!!
Nov 13, 2006 | Jensen TS2750J TV
Blurry tv
Sounds like theres a leaky capacitor in the screen drive circuit. I have seen this problem also be a gassy crt but was able to clean off the grids of the CRT with a crt/rejuvinator. It happens because of low emmissions in the tube and when white is on thats a mix of all the colors, so the tube works harder. I bet when you whatch a movie and the scene changes suddenly to a white or brite scene the pic looks a little washed out. If this is not the case then I aggree with the Pravin and try it on another TV just to be sure .. This is not a repair for a consumer to do, though however it is only a three year old set you stated, so there should be life left in the tube, so im kinda thinking a capacitor is bad. Seek out a yechnician to check this out for you as a TV is not a place to see it you can fix it or to exoeeriment with. Good Luck
Jul 26, 2006 | Toshiba 36A40 36" TV
Sony Playstation 3 (PS3) Console Logo
14 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
