Question about Breville Coffee Makers & Espresso Machines
800c pump not working
When you turn machine on , pump does not start
    New Friend:
    Problem Solver:
  • 6 Answers
The 3 second run of the pump on start up is controlled by the microprocessor.Could be the pulsator pump or the SCR on the control PCB or the board itself. CAUTION ! Internally all parts are live .Franko
Posted on Jan 03, 2014
No water coming out from the machine at all, but the spine cycle work. is this fixable?
The water pump is not working. Older machines use a belt driven pump where the newer machines use an electrical pump. Unplug the machine from the wall socket. Open up the front panel. The pumps for both types are installed in the front right lower corner. If it is a belt driven type check if the belt is still in one piece - if not replace with new one. Get fingers out of the way and start the machine and look to see if the pump pulley turns will the machine is working. If not - replace the pump as it is worn and can not be repaired. With a electrical pump check wire connector connections to the motor only when the machine is unplugged at the wall socket. Start the machine and set it to a spin cycle. The pump should start running. If not replace the pump.
Sep 28, 2014 | Speed Queen Washing Machines
C50 800c 2009 Wont Start
check the kill switch plus side stand switch.
Feb 01, 2014 | 2009 Suzuki Boulevard C50
New Nokia lumia 800c need code
Hi, What kind of code are you asking for your Nokia Lumia 800C?
If you are seeking for a network unlock code, You can visit www.TheUnlockSpot.com and get the unlock code for a Nokia Lumia 800C at affordable cost with easy unlocking guide. Good luck mate.
May 31, 2013 | Cell Phones
I need to replace the F6M 1.2 rechargeable batteries in my CPen 800C. Do you have them in stock and are you in a position to supply them. I am prepared to pay the charge only if you can supply them.
I have just replaced the battery on my C-Pen 800c with one from ESP Special Batteries. They did not have a suitable plug, so I had to remove the wires from the old battery and solder to the new. http://www.espspecialbatteries.co.uk/battery/ESP-1-69-125A This cost 9 pounds 80 including postage.
Jul 26, 2011 | C-Technologies C-Pen 800C Handheld Scanner
I DON'T HAVE A CD INSTALLER FOR MY PRINTER EPSON
Oddly the epson website does not seem to provide any search results for your printers model number. you can try this driver : http://xpdrivers.com/printer/epson/other-epson/mj-800c/_5_2061.cfm
Jun 26, 2011 | Epson Office Equipment & Supplies
C-PEN dead battery
If the charger is connected to C-Pen and the recharging
process does not start, follow these instructions.
1. Disconnect the charger from your C-Pen.
2. Insert something thin (like an unfolded paperclip) into
the reset hole and press gently.
3. Reconnect the charger to C-Pen.
4. C-Pen should begin recharging the battery within 10
seconds. If recharging does not start (the battery power
level icon is not moving in the status field) please
repeat steps 1-3 above. Remember to make sure that
the charger is not connected to C-Pen while pressing
the reset button.
There is no way to access the battery since it is built in. To replace it you would have to open it up, if you would like to attempt this the battery type is Rechargeable, NiMH.
Jan 05, 2010 | C-Technologies C-Pen 800C Handheld Scanner
I need a electrical circuit diagram of maruti 800
i have maruti 800c 2002 model my car fac is always run when car start i want automatcaly on off this problen some days
Oct 22, 2009 | 1994 Suzuki Samurai
Hello, My vcr tape will not eject and it was working fine an hour ago. Do you know what the problem is?
Have looked through the manual Sylvania DVC-800C DVD Player / VCR Combo and there is no mention of a tape not ejecting. if its under warranty give the dealer a ring. If dvd`s stick and nothing more can be done then have tried the belo. http://www.ehow.com/how_2036282_remove-dvd-player.html
Oct 18, 2009 | Sylvania DVC-800C DVD Player / VCR Combo
Printer is installed and connected properly but after giving print command it is giving a message cant complete printing at taskbar
try pressing on file print and change the icon from printer...... to the printer you inistalled as example turn it from hp 800c to mfc-7340
Jul 03, 2009 | HP LaserJet 2420 Printer
VHS side eats my tapes and spits them out
Hi
Sorry but you may need some repairman to look at the machine.There could be a problem with the transport, winding around head, pinch rollers dirty,belts gone bad and other faults-electronic components gone bad.Take an estimate from the repairman and see if worth to repair the machine.
Did you try another tape?How old is it ?
Hope this helps
jay
Nov 17, 2007 | Sylvania DVC-800C DVD Player / VCR Combo
Coffee Makers & Espresso Machines Logo
52 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
