Question about Kitchen Appliances - Others
How to clean heller box fan
How do I take the cover off a Heller box cooling fan to clean inside?
SOURCE: i have a Heller CD55
Sounds like a broken drum drive belt.. Ours does this about once every 6 months.. When it was in warranty the first few times we'd wait the 3 weeks for Heller to post the belt (and the second time, a replacement overheat-cutout sensor, as I was getting sick of having to open the back up and reset it) to the local service place.. Then I got sick of that, and we just take teh 15 min drive to our local appliance parts place, and pickup a 'CPD 7 RIB' (part no 0198300011) belt from a fairly new model simpson dryer, which has exactly the same belt..
I probably wouldn't suggest trying it if you're not a home handyman, as it means pulling the back off, and disconnecting a few wires and undoing a few mounting bolts to get the new belt around the drum, but it's only a 10 minute job if you know what you're doing..
If you want to take it to your local service place, just make sure they realise that they don't have to go to the hellar importer to get the replacement belt - a current model simpson belt fits fine :)
PS, they're 192cm long, 1cm wide, 7 'ribs'..
--DG
Posted on Jul 06, 2009
SOURCE: Instruction Manual for HELLER automatic timer
hi can you tell what the cool or the hot pic are
Posted on Dec 02, 2009
SOURCE: fridge heller model fdh21has motor running but does not get cold
i have just purchased a float with a kitchen in it the fridge is a heller bar fridge not sure on model and for the 2nd use it is running but not getting cold or icing up the freezer what do i do to fix it it wouldnt be 10 weeks old
Posted on Dec 20, 2009
SOURCE: heller dishwasher error 004
Hi all, this error (004) means that there is an overflow....To solve it do this:
1) Disconnect the power to the dishwasher
2) Remove the left cover (to do it remove all the screws..2 are located under the top and 3 behind the front lower cover)
3) Dry very well the bottom plates where is the motor and the electrics wires.
4) The overflow switch is a floating contact, so check that there is no water under it. (You can check it pushing gently the contact).
Before reinstall the cover check that the dishwasher is working fine!
IF YES.....WELL DONE MATE YOU SAVED YOUR MONEY!
Cheers....Aldo
Posted on Mar 11, 2010
SOURCE: HELLER MOBILE AIR CONDITIONER
that's the way it should work, after you set temp to 20 degrees, display jump to the inside room temp in your case 25 or 29
Posted on Jun 14, 2010
I see the usual reply is go to Heller Im asking because there is no answer at Heller. I need a manual for a Gusty 10CO portable air con. I have searched Google ALL DAY.I need a better reply please
I did a google search and found only one link (below). I don't know if it is a con or a genuine manual.
In the absence of a dedicated manual you will have little choice but to gather information of a more generic type and apply it to your air-con. I expect most of them use the same working principle and similar component arrangement.
http://dattorrent.com/search/heller+portable+air+conditioner+model+gusty10co+m
Apr 01, 2017 | Heating & Cooling
I don't know what type of heller air con I have but for the second time now it's started dripping water inside does anyone know how I can fix it
The tube that drains water out of the drain pan is plugging up. You have to disassemble the AC unit cabinet to get inside to clean out the drain pan and drain tube. You might as well clean the evaporator and condenser coils too. Spray with Fantastik cleaner and rinse with water. Also put some oil into the small tube for the shaft on the fan motor. If no small tube, then put oil on the shaft where it enters the fan motor.
Sep 22, 2015 | Heating & Cooling
Heller MIST40B instruction manual
I am assuming this is not a dishwasher but a mist fan.
Try contacting awa in Australia who support Heller brand products.
Ph:
1300 366 144
email:
warrantysupport@awa.com.au
Jan 05, 2013 | Dishwashers
Heller Breezy 1500 is it a dehumidify as well as air conditioner
The processes are the same. If you set the fan speed to low, or to a poaition that cycles the fan only when the compressor in the unit is running and cooling controls/humidistat to about mid position, it should dehumidify without making the space too cold. If it is ot dry enough, lower the temperature or adjust to "Colder". If it is too cold, adjust the other way.
This is a generic description, but it should help getting things drier for you. I am only able to find one Heller division with a web page in the US dated 2004, but no portable Air conditioners nor dehumidifiers.
Jan 28, 2012 | Health & Beauty
Need manual for a heller portable air conditioner. Model: GUSTY10CO
I have a Heller Gusty10c0 Portable Air Con. When It hasn't been used for a while. I turn it on and it last about 10 minutes then just stops. Then when ever I turn it on it cuts out after about 30 secs to a minute. Can anybody help me please?
Dec 12, 2010 | Heating & Cooling
Heller fridge keeps freezing up at the rear of the fridge
Model # would help!. The symtoms relating could be of a # of issues depending on the design (model #). Cold control, defrost issues, non or slow moving evaporator fan, slight pressue loss (undercharge), partial restriction, extra ambiant heat.
Ric
Mar 09, 2010 | Refrigerators
Jun 10, 2009 | Haier Heating & Cooling
Fridge heller model fdh21has motor running but does not get cold
Mar 27, 2009 | Refrigerators
Dec 07, 2008 | Hardware & Accessories
Kitchen Appliances - Others Logo
49 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
