Question about Ubisoft Just Dance 4
We recently bought a Just Dance 4 move pack. We are unable to connect the second module for calibration. It does not matter which module we use first - they both will work. When we try to connect the second one the red light flashes, but the "bulb" does not light up for calibration. Suggestions? Thanks.
    Problem Solver:
  • 9 Answers
I dont know much about the motion controllers but I'll give you my insight. After setting up the first one, switch it to be the second player and calibrate the other one as the first player.
Posted on Jan 03, 2014
Konami DDR Hottest Party Arrow Sync Problem
I have the same. I don't think you can fix this - those games were made for older televisions, and the calibration doesn't accommodate for today's technology. Hottest Party 3, 4 and 5 go up to +/-20, I currently have mine set to +18 for my Samsung flat screen.
Dec 02, 2012 | Konami Dance Dance Revolution Hottest...
Cannot seem to get my sub woofer working I have bose speakers, this was working fine until i moved house now unable to get anything working
Mice may have made it a home for a while. In whcih case they make reasonable doorstops.
Otherwise if they are clean and rodent free- it might simply be a matter of oxide on a power connecter, or switch or controls. The fundamental assumption being they are hooked up correctly. Usually pressing the push button switched a few times will clean them enough to function to tell you they need cleaning with contact cleaner, the same with pots, linear or rotary, and toggle switches too. I have seen instances where power connections or earphone/headphone jacks had corroded at the contact point that opens or closes when the jack is plugged in- corroded enough to prevent operation.
Dec 20, 2011 | Sony Audio Players & Recorders
Just bought an led tv .my wii was fine with tube tv now its controls are delayed.can it be fixed
The lag comes fr0m the digital picture processing.
Most televisions have a video game mode which can adjust the delay in rendering video from games. See if your television has a video game mode.
If not, a number of games that depends heavily on timing have a "Calibrate" mode to adjust to the delay on the TV. This is most common in rhythm games like Rock Band or Dance Dance Revolution. Look for the calibrate mode.
You can Google "Wii lag " for more info.
Aug 09, 2011 | Nintendo Wii Console
DCS T70 LCD does work properly .I mean to say if i try to use one function another function gets started instead of desired function
Based on the information you've provided, it seems that the touch screen panel is not aligned. You can try Calibrating the touch screen to resolve the issue.
Calibration option is in the Main Settings 1 Menu of the Camera. Calibration option enables you to perform calibration when the touch panel buttons do not react at the appropriate points where you touch. You can use the paint pen, touch the X mark displayed on the screen. The X mark moves on the screen. Once the calibration option is finished successfully, the touch screen should work.
The Calibration option can be done only if the Menu is accessible.
You can also perform a power reset before performing the Calibration.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
This should resolve the issue.
Thanks for using Fixya.
Jan 10, 2011 | Sony DSC-T70 Digital Camera
Connection for Konami Dance Revolution DDR Original Dance Pad for Wii Problem?
If you cant connect in it is probably because you need to sync it. Take off the battery cover for the pad. Now there should be a tiny red button in front of the wii console next to the sd card slots. Press for 2 seconds. now look in the battery compartment for the dance pad. there should be a similar button. press for 2 seconds. now your pad should work as the controller.
Please rate even if bad.
Jan 02, 2011 | Konami Dance Revolution DDR Original Dance...
Malfunction indicator light
if you receive a code indicating ignitial coil c secondary circuit this means a plug wire that connects your ignition coil pack module to a spark plug in the motor has come loose OR has become worn out
(not likely on '05 odel) or one of the coil pack modules has gone bad. If you recently had muffler repair work done, then suspect a wire has come loose and attempt to remove and reconnect each wire to the coil pack. If not, I would recommend replacing the coil pack module that's easiest to get to and testing the vehicle after replacing it. If that doesn't do it you will have to keep replacing until it starts running properly or you will need a shop manual to indicate which one is "COIL C". It's not very likely that a wire will be worn out based on the age of your vehicle, but heat from a motor will destroy a coil pack over a matter of several years especially if the coil pack is near an exhaust pipe or exhaust manifold.
Jul 24, 2010 | 2005 Dodge Caravan
I just bought Dance Dance Revolustion 3 for my WII and when i am in between picking songs my cursor keeps skipping or moving up and down and does not stop so i have no control over what i can pick for a...
There are 3 possible reasons you're experiencing this. 1.) A component on your motherboard has went bad, causing the system calibration to jump. To fix this problem, your board would need that component replaced. If you're currently under warranty, you would send this in to be repaired. 2.) Your Wii Sensor bar is currently bad. Though, this would be my second guess, since your controllers are showing up on the screen, they're just jumping around. 3.) Your controller(s) are bad. Like option #2 , this would not be my first or second choice, however I've seen customers bring a number of bad controllers to me at the same time. It really does happen.
I would say try whichever is the cheapest and easiest stress free method for you.
If you're under warranty you could go ahead and send it in, or purchase an extended warranty to get your system repaired.
You could also try your Wii hooked up to another owner's sensor bar using their controllers to pinpoint what your problem is.
I wish you luck and hope I helped!
- Great
Apr 14, 2010 | Video Game Consoles & Games
1988 Oldsmobile Delta 88' car stalls out. Coil pack might need to be replaced
Check the spark on each plug wire with a calibrated spark tester.One can be bought at most parts stores.If two plug wires that are next to each other are bad then replace coil pack.There may also be a bad ignition module.Also check the crankshaft position sensor.
Aug 03, 2009 | 1988 Oldsmobile Delta 88
I have a 2003 jimmy that blows very little heat at level 4
It sounds like it could be the control panel or the A/C And Heater Control Calibration you can give this info to your mechanic... but if i were you i would go to gm dealer.replacing the wrong part will get expensive fast..... hopes this helps you..........................................A/C And Heater Control Calibration
Re-Calibrating Actuators (Primary)
When replacing the HVAC control module it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC control module be sure to perform the following:Important: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted, improper HVAC performance will result.
  1. Place the ignition switch to the OFF position.
  2. Disconnect the scan tool.
  3. Install the HVAC control module.
  4. Connect all previously disconnected components.
  5. Start the vehicle.
  6. Wait 40 seconds for the HVAC control module to self-calibrate.
  7. Verify that no DTCs have set as current DTCs.
When replacing the HVAC actuator it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC actuator be sure to perform one of the following:Important: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted improper HVAC performance will result.
Alternate Method (W/O Scan Tool)
  1. Clear all DTCs.
  2. Place the ignition switch to the OFF position.
  3. Install the HVAC actuator.
  5. Remove the HVAC B fuse for a minimum of 10 seconds.
  6. Install the HVAC B fuse.
  7. Start the vehicle.
  8. Wait 40 seconds for the HVAC control module to self-calibrate.
  9. Verify that no DTCs have set as current DTCs.
Preferred Method (W/ Scan Tool)
  1. Clear all DTCs.
  2. Place the ignition switch in the OFF position.
  6. With the scan tool, initiate the Motor Re-calibration feature of the Heating and Air Conditioning Special Functions menu.
Dec 29, 2008 | 2001 GMC Jimmy
Ubisoft Just Dance 4 Logo
125 people viewed this question
Top Ubisoft Video Game Consoles & Games Experts
Mishan Kasiparsad
Josh Hannegan
Josh Hannegan
Level 1 Expert
Are you an Ubisoft Video Game Console and Game Expert? Answer questions, earn points and help others
