Question about LG LMV1630 Convection/Microwave Oven
Plmv169dd touch pad issues - LG LMV1630 Convection/Microwave Oven
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 168 Answers
Remove the cover and clean under the keys to remove accumulated dirt
Posted on Jun 07, 2014
On the touch pad numbers 3, 6, 7 and 0 dont work
sounds like the touch pad control has failed ... there is a touch pad on this unit and also a control board located behind units touch pad... you can gain access to this by unplugging unit and removing console that houses touch pad /clock assembly ... once removed the only test there really is to do would be with power off remove ribbon cable to touch pad and make sure clear of any dust /debri and reconnect there are 2 small holes in ribbon cable that are used when reconnected fir into small slots and firmly connect... if that doesnt fix i would recommend a new touch pad... not sure what area your located... there is a distributor for sharp in dallas ,texas called
global micro parts... reputable company that if you give them your model number they can assist you with the part.... good luck to you
Jan 27, 2011 | Sharp R305KS Microwave Oven
Touch pad inoperaive on one side
about the only thing you could do is to replace the touch pad there are no repairs done to touch pads we basically just install a new one i suppose one could take one apart and try to fix it but there are no schematics that they give to the touch pad make sure before ordering a new touch pad that it is the touch pad and not the control board that has malfunctioned if you are unable to perform these tests please call a repair technician if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Dec 13, 2010 | Microwave Ovens
Touchpad will not work after boiling water underneath it for 12 minutes without fan humidity cause touch pad to stop working , I have a GE mdv 2040 with green display touch pad
you can change the touchpad to help with this but whenever you have a microwave over a range you are going to have issues with this. you have to make sure you use the vent on high whenever broiling anything to prevent the moisture from getting in the touch pad because all your touchpad consists of is two stickers and some flat wire so moisture can easily getting into it cause it to stop working for a period of time. but changing it is the best thing you can do
Jun 02, 2010 | GE JVM1860 Microwave Oven
I have a Magic Chef microwave model mco153sf. The
HI. This is , indeed, an issue within the touch pad circuitry. it is damage, and will require replacement. I have located a replacement touch pad. Use the link below to access the touch pad. You can order the pad on-line, by clicking the link below.
CLICK HERE
Dec 23, 2009 | Magic Chef CMV1000B Microwave Oven
The touch pad does not work. It displays menus
HI. this damaged touch pad board should be replaced asap. the board itself is not repairable.
Replacing the board will fix the issue.
Sep 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave is working but the touchpad is not.So we are not able to start the microwave to use.
The touch pad has failed. you must replace this damaged touch pad board asap. this will correct this issue.
Sep 13, 2009 | Westinghouse Microwave Ovens
Touch pad won't work.
HI, this board is damaged. I recommend replacing the touch-pad board asap. This will fix your issue.
Sep 02, 2009 | GE Spacemaker JVM1540 Microwave Oven
Microwave beeps
HI. the touch pad is defective at this point. you will need to replace this damaged touch pad board asap. this will fix your issue.
Aug 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave shows F2 on display with controls non functional
HI. this is a code that represents a failed key pad or touch pad membrane board. replacing this failed touch pad will fix this issue. This touch pad board is separate from the actual control board.
Aug 13, 2009 | KitchenAid KHMS155L Microwave Oven
Touch pad does not work, clocke does, nothing else works
Hi this will happen when the touch pad circuits become unstable and damaged, due to abundant usage or , old age.
simply replacing the touch pad will fix this issue.
May 30, 2009 | GE JVM2070 Microwave Oven
LG LMV1630 Convection/Microwave Oven Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
