Question about MotoBatt 2003-2009 suzuki an650 burgman 650 cc battery
Squeaky sound from engine
It squeaks when the engine is turned on, sounds like a bird chirping
What causes a squeaky sound from the engine of an 2000 Isuzu rodeo when engine is running?
it could be one of the belts. if you put a little wax or brake fluid on the belt in a couple of places and the squeak goes away then you either have a loose belt/s or the belts/s need replacing. if no change it could be the timing belt making the noise.
Sep 14, 2014 | 2000 Isuzu Rodeo
My 2005 trailblazer makes a bird chirping noise. Exactly like birds. My mechanic replaced the belt but it is still making the noise.
If is a serpentine belt, take it out and check the belt tensioner. some of them have a screw that allows for tightening/loosing the belt. Sometimes it looses some bearings and it could chirp.
May 20, 2014 | 2005 Chevrolet Trailblazer Ext
Fix chirping
Chirping sounds could be a bird stuck inside. If you are not missing any birds then I would suspect you need a drop of oil on the pin behind the bobbin case.
Nov 17, 2013 | Husqvarna Sewing Machines
ENGINE SOUNDS LIKE A BIRD CHIRPING
I had the same till i replace all my belts
May 23, 2013 | 2002 GMC Yukon Denali
Makes a chirping sound when the car is initially started
Have you checked the engine bay for a bird's nest ? LOL
Seriously now, I think it is one or more of your drive belts, just when starting to turn all your engine bits. Have those tightened or replaced as needed and you should be OK.
May 21, 2013 | 1997 Toyota Camry
2002 chrysler sebring chirping noise under the dash
Speedometer cable may have a broken stran of wire causing it to squeak when it turns.
Feb 03, 2013 | 2002 Chrysler Sebring
I am getting a squeaking noise that almost sounds like a bird chirp coming from the right rear area. Could this be a seal or bearing problem?
Are you sure it's from the right rear area? I had something similar happen, and it turned out to be the bearing that joins the front and rear drive shafts at midship. Replaced the bearing, and the noise is gone.
Dec 12, 2010 | 2003 Ford F350 Super Duty DRW SuperCab
Conection from trany to rear wheel driver is squeeking
  1. sounds like a loudly chirping bird?
  2. ujoints should be lubed or replaced
Aug 19, 2010 | 2000 Chevrolet 2500
MotoBatt 2003-2009 suzuki an650 burgman 650 cc battery Logo
Top MotoBatt Electronics - Others Experts
Robert McCall
Robert McCall
Are you a MotoBatt Electronics - Other Expert? Answer questions, earn points and help others
