Question about Rheem Pool & Spa
What do the red and green indicator lights mean located at the temperature setting
A green light over a red light stays on while running up by the temperature control. Is this a problem
  • 22 Answers
There are two sensors 1 on the (water)inlet and one on the outlet behind the metal plate covering them on the side , they have 2 wires on each of each sensor . the sensors check the water temperature and stops the unit from getting too hot, sometimes a wire comes off one of them/gets rusted and falls off or the sessor fails, (to test just join the 2 wires on 1 sensor together (bridge them) and 'Wa-La'!) problem fixed!!) (then order a new sensor or two!) cheers!
Posted on Jan 03, 2014
Green light flashing on bosch no frost freezer
The green light usually indicates the operating temperature. If flashing , the freezer should be running and cooling. Once it gets to temperature, the light should stay on. Is the food still frozen or is it thawed out?
Mar 01, 2015 | Bosch Refrigerators
Re lights lit on freezer
Red light lit on freezer means that is not reaches operating temperature.
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees
- orange light : pressing the so-called SUPER-switch which means that the compressor is running continuously. The SUPER-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Sep 02, 2014 | Electrolux Freezers
Indicator lights mean
red is calling for heat check safety circuit gas and ignitor
Jan 03, 2014 | Rheem Pool & Spa
There are 3 lights on the front of the Zanussi Freezone. The green one on the left doesn't light up. What does that indicate? The red light on the right is on constantly. Does this mean that the freezer is...
Starting the Appliance
Insert the plug into the wall socket. The green pilot light will illuminate to show that the appliance is switched on. The red alarm light will also illuminate until the freezer reaches the correct temperature.
Alarm Light
The red alarm light will illuminate when the temperature in the freezer is higher than the thermostat setting. This alarm light will illuminate if:
- The appliance has just been started.
- Fresh food has been put in the freezer.
- The lid has been left open, opened frequently or open for too long.
The red light will go out when the freezer has returned to the correct temperature
Dado
Oct 14, 2013 | Zanussi 14.62 cu. ft. / 414 liter Chest...
The light is on but the freezer is not cooling
You did not specify which lights are on?
  • The green pilot light will illuminate to show that the appliance is switched on.
  • The red alarm light will also illuminate until the freezer
  • If you press the SUPER button than you start fast freeze function and yellow light will illuminate.
I assume that the freezer is on and the green light is illuminated. This means that the freezer is on and energized.
Also, if freezer does not cooling, means that did not achieve the set temperature should be illuminated the red light (alarm).
Set the thermostat for example in position 4th and after that compressor should be start.
If compressor running but not cooling, defective is the system which circulates gas.
If compressor does not start, then is faulty thermostat, compressor or the wiring.
Dado
Apr 04, 2013 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    May 04, 2012 | 1994 Nissan Maxima
    On a vector jump start system, does the green light have to stay on to indicate that is charged> what if only the 2-3 red light go on when i press the test button?, when the green is flashing while...
    2 - 3 red lights indicate not fully charged. Green light = fully charged.
    Not fully charged does not mean it will not function. For best results, your device should be fully charged. If you have an emergency and are not fully charged, it will not hurt to try to help with a partial charged device IMHO
    Thanks for posting at FixYa.com
    Dec 13, 2009 | JUMP START SYSTEM
    Red light stays on after changing the water filter and running about 2 gallons through it
    Water Filter Status Indicator
    Light (select models)
    The Water Filter Status Indicator Light serves as a
    reminder to replace the water filter. A green light
    indicates that the filter is in good condition. A red light
    indicates the filter should be changed. Once light turns
    red, it will remain red until function is reset.
    To Reset Indicator:
    • Press and hold both the Lock and Water
    buttons simultaneously for four seconds. The
    green filter status indicator light will flash
    three times when the function has
    successfully reset.
    Nov 27, 2009 | Maytag MZD2665HE Side by Side Refrigerator
    Norelco Advantage red light meaning and source of manual
    the steady red light showing when in charger shows that
    it is charging. the blinking red light when taken out of
    charger or turned on and off means it is not fully charged.
    leave it in charger till red light turns green.
    Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
    Pool & Spa Logo
    119 people viewed this question
    Top Rheem Pool & Spa Experts
    Steve Slater
    Gene Haynes
    Tom Chichester
    Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
