I disconnected my printer from the pc, now I cant get the printer to work again. I get printer is not responding. I downloaded from on online the software, it still does not respond. What else do I need to be aware of.
  • 13,433 Answers
This is mostly caused by a problem with the computers drivers / software.
First open printers and faxes
  1. click start
  2. select printers and faxes, if you don't see it there, then click on control panel
  3. on control panel, on the left side click on classic view. you can skip this step if you already see all the icons
  4. open printers and faxes or just printers
  5. right click on your printer and select delete
  6. repeat the step 5 if you have the printer more than ones.
Uninstall the current drivers and software
  1. click start
  2. click control panel
  3. double click add or remove programs
  4. find epson drivers and other epson products and click on uninstall
  5. close the add or remove programs when you have removed all the epson related software.
unplug the printer from your computer.
restart the computer, and use the cd that came with the printer or download the drivers and software from the makers website or if you already have them then use them
Plug in the printer when asked or when drivers and software is installed, You may need to restart the computer.
The printer should print normally from the computer again.
Posted on May 21, 2009
Printer not responding
Hi
Turn the printer off and on.
Try disconnecting the printer completely from power and from PC and re-connect again.
Mar 30, 2012 | Canon Pixma MX410 All-In-One Printer
My Lexmark x4850 has stopped prin?t the computer. What is wrongting . Sometimes it will print when I restar
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/lY7NTO. Select your operating system, download and execute the file. After the install process, try to print a document again to verify that the problem is fixed.
Oct 23, 2011 | Lexmark Wireless X4850 All-In-One Inkjet...
Print document system responds document is printing system responds that document is printed but no document is printed. Used troubleshooting for alignment and that works with printer?
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark Z816 InkJet Printer
MY LEXMARK 1270 CANT PRINT NOR SCAN BUT ITS STATUS IS READY
2. Unplug and re-plug the printer into the power source to reset it.
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aKlcOJ. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 15, 2011 | Lexmark X1270 All-In-One InkJet Printer
Cant use my printer, i dont have my driver anymore, due to computer virus, i have to reformat my desktop and i need to install again my printer
If you purchased the printer new you probably got an installation CD. Load your CD and follow prompts. If not you may be able to find your model online and download software.
Mar 04, 2011 | Computers & Internet
Printer communication error
check the network cable... disconnect the network cable and ping the copier... if you can get the copier IP address to respond... then you have an IP conflict... if you plug the network cable back in... turn the copier off and on and still cann't print from any pc... then reset the copier... if you still cannt print from any pc then you need to try changing the IP address... and try again... still doesn't work... change the network cable and try again... still doesn't work... plug a laptop into the network cable and ping the laptop... if the laptop works... the print card is bad...
Dec 12, 2009 | Canon imageRUNNER 7200 Copier
Printer is offline and will not respond with i use control pan/printer/use printer online
check the connection ....if its not working reinstall the printer driver .... ...you can try this ...open printer and faxses ....right click on the printer there u can find a options like use printer online.......
Oct 07, 2009 | Brother HL-5370DWT Laser Printer
Cant load my printer
Go to the Printers and Faxes window to see if any printers are installed. If there are no printer icons then disconnect the printer, use the installation cd for the printer then connect the printer and you should get a "New hardware found" message. Then it should automatically load the drivers.
If there is a printer icon already then right click on it and ensure that the "Use printer online" "Set as default" options have a check mark.
If you do not have the cd for the printer it can be downloaded for free from hp.com. Post back if you need further help. Steve
Sep 13, 2008 | Acer Aspire RC500 PC Desktop
Trying to download
how can i get my scan to work my printer work it set as
dfailt but i cant work my scan please help
Feb 20, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
22 people viewed this question
k24674
jasbo
jasbo
