Question about Rheem Pool & Spa
Indicator lights mean
Is there a problem when the green light and red light stay on up by the temperature control
    Top Expert:
  • Rheem Master
  • 8,143 Answers
Red is calling for heat check safety circuit gas and ignitor
Posted on Sep 15, 2017
reddevil6
  • 1673 Answers
SOURCE: RED LIGHT INDICATOR
You either have a problem with the sensor or the circuit board. Most times it is with the sensor. Take the hose off, look inside of the part that the hose hooks to, you will see a disc, it may be clogged with dirt, try cleaning it, if that doesn't work, then the sensor may be bad.
Posted on Dec 29, 2008
SOURCE: the power indicator light on the router is red
Red - Power light / Green - Wireless light?
I was told By AT&T the modem was bad and I needed to buy a new one.
My girlfriend had the same model and was not using it.
So I tried hers with my power cord and got the same thing.
I called AT&T back and they said her's was bad too!
Then I changed to her power cord and it now works. It is the power adapter!
Posted on Feb 14, 2009
  • 1861 Answers
SOURCE: 1994 Camry Red dash warning light stuck on
This is most likely the security system light.
Posted on Mar 15, 2009
  • 1779 Answers
SOURCE: Brake light, oil temperature light and battery light are on
Wow, 3 problems, did the lights come on one at a time or all at once? How long has each been on? 1st thing is to check fluid levels-brake, & oil. You may damage the vehicle if you continue to drive it. The brake light means a malfunction in the system, or low brake fluid. If the level is low, adding should turn the light off. You then need to check to see where the system is leaking. Oil temp light, or is it just oil light? This will go on when you basically have no oil in the engine, or the oil pump has failed, both very bad. Battery light indicates the vehicle is not charging the battery. Check the drive belt, did it break? This could cause a bunch of lights to go on. Let me know the answers to the above, so I can help to refine my answer.
Posted on Apr 16, 2009
cnavarro
  • 2460 Answers
SOURCE: The red light indicator will not shut off
Press the MESSAGES button and look at the display. The light can be lit from another source. One of the soft keys under the display will let you CLEAR the message.
Carl
Posted on Dec 23, 2009
When connecting the charger the light indicator is suppose to turn red but instead it stays green, I've already replaced both batteries and the electric controller ...any idea's
When you say electric controller, what do you mean? There is over charge protection on the battery that is a separate sensor and it is bad.
Mar 09, 2016 | Electric Health & Beauty
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
The operating instructions say that after 16 hours the red power/charge indicator light would go out, indicating the batteries are fully charged. After 3 days the red light on my unit is still on. The...
If it is new, send it back, but make sure you carefully read the instructions first. If is says the indicator light is red on charging and green when fully charged and it doesn't do that then the batteries or the charger are defective.
In future make and model are useful. And you posted to electric drills, but I recategorised it.
Jul 02, 2017 | Audio Players & Recorders
I have a green light and a red. what do they mean?
Red means that it has power. Green means the heating element is on. The green light will cycle on and off as the thermostat controls the temperature. Allow the iron to heat til the green light goes off before adding batter. Watch for steam coming from the iron. When the steam stops the waffle should be done. Keep track of the time that it takes to cook. Experiment with cooking time for the best results.
May 09, 2014 | Toastmaster 277 Belgian Waffle Maker
What do the red and green indicator lights mean located at the temperature setting
there are two sensors 1 on the (water)inlet and one on the outlet behind the metal plate covering them on the side , they have 2 wires on each of each sensor . the sensors check the water temperature and stops the unit from getting too hot, sometimes a wire comes off one of them/gets rusted and falls off or the sessor fails, (to test just join the 2 wires on 1 sensor together (bridge them) and 'Wa-La'!) problem fixed!!) (then order a new sensor or two!) cheers!
Jan 03, 2014 | Rheem Pool & Spa
There are 3 lights on the front of the Zanussi Freezone. The green one on the left doesn't light up. What does that indicate? The red light on the right is on constantly. Does this mean that the freezer is...
Starting the Appliance
Insert the plug into the wall socket. The green pilot light will illuminate to show that the appliance is switched on. The red alarm light will also illuminate until the freezer reaches the correct temperature.
Alarm Light
The red alarm light will illuminate when the temperature in the freezer is higher than the thermostat setting. This alarm light will illuminate if:
- The appliance has just been started.
- Fresh food has been put in the freezer.
- The lid has been left open, opened frequently or open for too long.
The red light will go out when the freezer has returned to the correct temperature
Dado
Oct 14, 2013 | Zanussi 14.62 cu. ft. / 414 liter Chest...
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
What does a red light for powerline activity mean?
It indicates your line quality for the Homeplug - Green: Best, Amber: Better, Red: Good
Details here http://www.zyxel.com/uk/en/products_services/pla_401_series.shtml
Jul 16, 2012 | Zyxel PLA-401 v3 - Bridge - Ethernet, Fast...
On a vector jump start system, does the green light have to stay on to indicate that is charged> what if only the 2-3 red light go on when i press the test button?, when the green is flashing while...
2 - 3 red lights indicate not fully charged. Green light = fully charged.
Not fully charged does not mean it will not function. For best results, your device should be fully charged. If you have an emergency and are not fully charged, it will not hurt to try to help with a partial charged device IMHO
Thanks for posting at FixYa.com
Dec 13, 2009 | JUMP START SYSTEM
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Pool & Spa Logo
69 people viewed this question
Top Rheem Pool & Spa Experts
Steve Slater
Gene Haynes
Tom Chichester
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
