Underline text - Computers & Internet
Wants to know how to underline name, title etc using my pc
Not much information here, but I assume you are using a word processor such as Microsoft Word or similar. To underline text you simply select the text with your mouse by pointing top the start of the text then holding down the left mouse button and moving the mouse pointer to the end of the text. The selected text should be white on a black background. Then you can press "ctrl-u" - hold down the 'ctrl' key in the bottom left of the keyboard whilst pressing the 'u' key.
This approach work in most applications on Windows that support underlining.
Mar 09, 2013 | Computers & Internet
Corel Draw 8 - Can the color of the underline below the text be changed, a different color than the text?
yes right click any color u r chose any color right click for underline and left click for text color
Jan 28, 2013 | Corel Draw 8
How to underline the text
which program ?
Underline Text in HTML b> Find or enter the text you want to underline. Place the text within a SPAN element, by adding an opening tag before the text and closing tag after. Specify underlining of the text within the SPAN by adding a STYLE attribute to it as follows:
STYLE="text-decoration; underline; " Add a CLASS attribute to the SPAN, giving the name of a CSS class which defines text underlining. This is an alternative to using the STYLE attribute as described in the preceding step. The format of the CSS class declaration is as follows:
.my-underlined-class { text-decoration: underline; } b> Underline Text Using HTML b> Find or enter the text you want to underline. Enclose the text within a U element, by placing an opening and closing tag before and after the text.
Underline Text in PowerPoint
PowerPoint includes shortcuts for adding font effects, such as strike-through, italics or subscript, to any text in your presentation. Like other products in the Microsoft Office Suite, PowerPoint also allows you to underline important words or phrases on a slide to help empha important aspects of your presentation. Microsoft's use of hot-keys makes it possible to underline text identically in all versions of PowerPoint.
View the slide that has the text you want to underline. Highlight the text you want to underline. Press "Ctrl" and "U" simultaneously to underline the highlighted text.
Underline Text In Word 2007
b> Microsoft Word 2007 makes it possible to create and edit documents for email or printed use. This word processing application allows you to add a number of formatting options that enhance your document. One of many features included in Word 2007 is the ability to underline words or sentences. You can make certain words stand out using either basic or decorative lines.
Open your Microsoft Word document and highlight the word or sentence you want to underline. Click the "Underline" icon located on the Home tab to underline the text. Select the text you want to underline, if you want to underline words, but not the spaces between them. Click the "Font" button on the "Home" tab and click the "Font" tab. Click "Words only" in the "Underline style" box. Select the text or sentence you want to underline, if you want to double underline. Click the "Home" tab and click "Font." Click the "Font" tab. Select "Double Underline" in the "Underline style" box. Select the text you want to underline, if you want to add a decorative underline. Click the "Home" tab and click "Font." Click the "Font" tab. Select the decorative underline you want to use in the " Underline style" box. Click "Underline color" and select the color you want to use for your decorative line. Click "Paragraph group" on the "Home" tab if you want to underline spaces. Click "Show/Hide" and press the "TAB" key. Select the tab characters that you want to underline. The tab character looks like an arrow. Press "CTRL," and "U" together for a basic line. Click "Font" on the "Home" tab if you want to add a decorative line to the space. Click "Underline style" and select the style you want to use. Hope this helps.
Jan 02, 2013 | Computers & Internet
How do I underline text in an E.Mail
If you write your email in plain text, you can still underline as much as you like, and everything remains perfectly legible.
Sep 21, 2012 | Microsoft Windows XP Home Edition English...
How do I amend the underlining of my text when writing a message?
Welcome to Fixya. The underlining of text when writing happens when the Predictive Text option is Enabled. When in text mode you can use the Hash Key (#) under number 9 Key to change the case of letters or prediction.
Thanks for using Fixya.
Mar 06, 2011 | Nokia Cell Phones
How do I stop my text from being underlined everytime I type a text message on my Droid X. I know How to clear the underline, but I don't want it underlined in the first place.
I am having the same problem with Droid 2. It is underlining everything I type in an app or text, and I can't make it stop. I know how to lock and unlock caps and alt, but this is not the problem. Already tried removing the battery, but the problem remains. It didn't start doing this until I accidentally pushed several buttons on the bottom left side of the slide out keyboard when I was opening it.
Oct 08, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
I can't download a video
Normal 0 false false false MicrosoftInternetExplorer4 have a look from this articles, maybe you will get a satisfied answer.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://onlinevideodownloader.net/download-facebook-videos.html
Sep 06, 2010 | Facebook Social Network
Panasonic DMR-E85H unit 1 - powers up then goes to ''Please Wait'' and no further unit 2 - the picture output color is all wrong..very dark and very redspan.jajahWrapper { font-size:1em; color:#B11196;...
This is a hard drive failure and is expensive to fix, and not worthwhile in my opinion.  Mine packed in with a disc stuck in the disc drive. It was difficult to retrieve. If you have no disc trapped in the tray, I would suggest dismantling anyway and removing the hard drive if you have a load of unwatched content recorded. You can buy a cable to hook it up to a PC - Although I have not done this yet.
DMR-E85H - Rest In Peace.
Mar 03, 2009 | Panasonic DMR-E85H DVD Recorder
Plastic Gear
call royal spare parts department at 1800-222-2310 they will
ship you a gear for about $6 + shipping
Aug 09, 2008 | Royal Orca ASF5000X Shredder
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
