Question about Vehicle Parts & Accessories
0n the 88 caddy 4.5L engine control light on cluster light off whats wrong
    Scholar:
  • 197 Answers
You need to have a place like Auto Zone do a Code Reading on your car. It's free
Posted on Jan 09, 2014
1998 oldsmobile 88 anti-thef system cause no power to fuel pump?
Is the SECURITY light lit on the insturment cluster ? Does the engine spin with key in start position ?
Vehicle Theft Deterrent (VTD) System Check
Attempt to start the vehicle.
NO - The engine cranks and starts.
Refer to Engine Cranks but Does Not Run in Engine Controls.
Note the security indicator while attempting to start the vehicle.
The indicator light is ON and OFF after approximately 5 seconds.
• SECURITY Indicator Always On or Flashing, Engine Does Not Crank
• SECURITY Indicator Always On or Flashing, Engine Starts
* Refer to the appropriate symptom diagnostic table for the applicable abnormal result.
Engine Cranks But Does Not Run !
Feb 18, 2017 | 1998 Oldsmobile 88
97 olds 88 runs rough first few seconds, when you shut it off it will not crank. Had the ignition control module tested and says that it is good. Any ideas?
Will not crank how ? When you turn the key to the start position does the starter engage and spin the engine ? , A crank no start condition . Or nothing happens . A no crank - no start condition . I assume by your statement ( Had ignition control module tested ) That you have a crank no start condition . in which case have you tested input from the crank sensors to the ICM and PCM . What engine does your Old's have ? 3.8 L
Is there spark at the coil's ? Pull plug wires off of the same coil , have someone crank the engine over , Is there a spark jumping from one coil tower to the other ? If so , you don't have an ignition problem , fuel more then likely . Is your SECURITY light lit on the instrument cluster , if it has anti-theft .
Feb 14, 2017 | 1988 Oldsmobile Delta 88
My cadillac escaped is showing the service battery charging system my truck turns on and after i turn it off it doesn't turn on anymore what could it be any help would be good
What year is your caddy ? Given the amount of electronics on these vehicles it could be a lot of thing's ! Are there any lights lit on the instrument cluster ? check engine , security etc.. The charging system on your caddy is computer controlled an if it is showing a service battery charging system warning message there are DTC'S stored . This is one your going to need to take to a dealer , do you have Tech 2 scan tool to hook-up to the vehicle ! It could have an ignition switch problem , power mode miss match ! All the modules on this vehicle communicate on a data bus, serial data communication . class 2 ,C.A.N -controller area network ! When you turn that key to start the vehicle ,the ignition switch sends a discrete voltage input to the BCM -body control module ,which in turn energizes relays that powers up systems on the vehicle ! So do yourself a favor before you make it worst !
Apr 09, 2015 | Cadillac Cars & Trucks
Ignition problem
Lots of things. Bad battery, bad + or - connection at battery of at engine ground, bad fuse link near battery.
Jan 01, 2014 | Cars & Trucks
P1698 0n a 1999 jeep grand cherokee,, reset so the engine light is ,, dont pop back on agin untill u shut it if and start it agin, then it comes back on..p1698
Alot of times, this concern has to do with the solder joints on the Cluster. If you take it out and resolder those joints or have them resoldered by someone else, it might just fix your problem. Especially, if this code is accompanied by intermittent gauges and cluster operation.
Mar 28, 2013 | 1996 Jeep Grand Cherokee
1995 Olds. 88 instrument cluster swap
You need the sensors of those functions, which you don't have installed. I would go back to the correct part.
Jun 22, 2012 | Oldsmobile Eighty Cars & Trucks
WHAT DOES THE INSTRUMENT CLUSTER ON A 2000 BUICK CENTURY CONTROL? WHAT CAN GO WRONG WITH A BAD CLUSTER?
Instrument cluster "controls" nothing. It gives you information from items that are being controlled and it gives you the results of what is going on...speedometer informs you of your speed...flashing light on the left informs you you have selected the turn signal arm to turn left.
What is the problem you are having?
Feb 13, 2010 | 2000 Buick Century
No bu5 light is on
It is "no bus". It means the cluster is unable to communicate with the other controllers through the PCI bus. The engine controller tells the cluster fuel level, engine temp, and oil pressure. The transmission controller and ABS tell the cluster to display speedometer functions, warning lights and such. Air bag communicates when to turn the light on and so on.
Jun 16, 2009 | 2000 Dodge Ram 1500 Truck
Which years/models trannys interchange 1990 olds delta 88 royale
any gm olds , buick caddy, pont, 4speed auto up to 1991 u just got make sure theyre not computer controlled some 91 are n some aint stay away from 84 to 88 they had failures it doesnt really matter about engine size as along its same transmission
Mar 14, 2009 | 1990 Oldsmobile Eighty Eight
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
