Question about All Star Linear 8833 318MHz Remote Transmitter model BA8833T
Changing the battery
Hope do I open the remote to replace the battery? There is no obvious way to do this.
2003 saturn vue doors stick in lock position can not get them to unlock or open
this may sound a silly question as your are locked out obviously , have you tried the key in the lock, drivers door ? if there is a fob for remote control ,the battery may need changing .If none of these work call a mechanic who should be able to get one door open and take it from there
May 13, 2015 | 2003 Saturn VUE
My remote will not release my doors lock
Try changing your key fob battery. look for a indentation on the remote.Take a small prying tool or screw driver Very carefully go around the remote with light pressure to open.Once inside the remote you see a button type battery or a coin size battery. Remover and replace with exact replacement battery.This should release your door locks.
Jun 28, 2014 | Lexus 2005 LS 430 Base
Changed batteries in remote now remote not working
Was your remote working before changing the new batteries?.
If yes, try another pair of batteries.
Nov 04, 2013 | Hunter 52" Ceiling Fan With Light And...
I have a Suzuki Swift '06. The keyless entry remote has stopped working and I suspect the battery needs changing. I tried opening the key case but stopped after finding the mechanism unfamiliar. Can...
some remotes are not repairable,when the battery dies you have to replace the whole unit,yours may be one of this type, you may have to go to a SUZUKI dealer & get another one & have it coded.......hope this helps......cheers.
Jul 08, 2011 | Suzuki Swift Cars & Trucks
Have gold star tv can not get remote to work lost manual
Hello, Have you tried changing the batteries? Easiest and most obvious fix. If that doesn't work and its actually the circuitry of the remote you're pretty much out of luck. You could try looking up a cheap universal remote that has a code for your brand. You could grab a RCA one for example from wal-mart for around 10 bucks
http://www.walmart.com/search/search-ng.do?search_query=universal+remote&ic=48_0&Find=Find&search_constraint=0
Hope it helps! -Joe
Jun 07, 2011 | Televison & Video
Remote won't work
marybsaxton
If changing the batteries did not resolve your issue with your remote, we may need to replace the remote. You might check to see if all batteries have the positive side facing down on the remote. If so, then call 1-800-333-3474, speak with Tech support. I hope this helps.
Ray Calo
DISH Network
Apr 18, 2010 | DISH Network IR Remote Control
2006 Malibu Maxx remotes stopped working. Replace
sometimes after replacing dead batteries in remotes the remote resets itself to a different code to that of the vehicle, ie the last time you used the remote it sent a signal to the system, lets say for argument sake, 123456, then the system would open when you pressed the button again as this would clarify the 123456 and close, but when you remove the battery or it stays dead for a certain period of time ( different modles vary) it will reset to factory code it might be 000000, and your vehicle is waiting for 123456 to open it, so what you have to do is reprogram the remotes to the system, you will have to ask the dealership in what sequence you have to do it, they will tell you how to reset the remotes, sorry its long winded but better explain why first so you understand the reason behind the remote, the numbers are just indications on how it works, no numbers are seen obviously this is just an example on how the system comunicates with the remotes hope this helps, most of all hope you get it lol
Feb 03, 2010 | 2006 Chevrolet Malibu Maxx
Samsung TV remote. I noticed today my TV remote wasn't working. I changed the batteries and noticed there had been some leakage from the AAA batteries. Since changing the batteries the 8 buttons on the top...
Giving you some hints. Battery leakage is one enemy of tv control and other remote control. They can corrode your battery spring contact, give contact bridges with neighboring tracks that can cause erratic behavior of your remote.
Some repairs can be done but doesn't guarantee success. First is try to clean the corrosion on battery contact = no power usually. Erratic behavior cause by contact bridging = battery leak residues.
Opening a remote control. Some have screws on its small foot. Covered by a rubber or sticker. Some are notch clip in strategic location you have to fry that one by one, opening first on its weakest side. In some don't want to be open.
Cleaning the board by a soft eraser is one way. After you open the remote. Commonly the button area where contact takes place.
If the first procedure and cleaning doesn't work. Buy new remote or use universal remote controller.
Aug 23, 2009 | Samsung TV Remote Control
Cant find where to change the batteries in the remote... There is no obvious place to put them unless we try to bust it open. Help!
Heya Harvey,
On the panasonic remotes the batteries are under the slide down part of your remote. Where you slide the face down to expose more buttons keep sliding it down abit more and you should find two aa batts.
If this dosent make sense or you would like me to send a link for the remote let me know.
If you have any other problems please feel free to contact me
Thankyou for using fixya
Apr 21, 2009 | Heating & Cooling
Opener keeps losing code
YOU MAY HAVE A LOOSE BATTERY CONECTION IN YOUR REMOTE.
ANYTIME THE BATTERY CONNECTION IS LOST (EVEN MOMENTARILY) YOU WILL NEED TO REPROGRAM IT.
IF YOU CAN'T FIND AN OBVIOUS PROBLEM WITH THE BATTERY, I WOULD REPLACE THE REMOTE.
HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
All Star Linear 8833 318MHz Remote Transmitter model BA8833T Logo
52 people viewed this question
Top All Star Home Security Experts
Lawrence Oravetz
Are you an All Star Home Security Expert? Answer questions, earn points and help others
