Question about Mitsubishi VS-45605 50" Rear Projection Television
The picture scrolls on my mitsubishi vs 50707 tv
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
This can be a very using these TV models. Usually it does not take Image in image modual. you will find surface installed capacitors which have to become changed. You will have to purchase the actual Mitsubishi pip capacitor package from HERE You also will require a stable head the actual the knowledge approach modify surface installed capacitors. This is simply not employment for your unskilled. Best of luck and enable us understand how the two of you made away with these maintenance.
Check more on http://4k.com/tv/
Posted on May 04, 2015
Http://lsm-video.en.alibaba.com/
3DHDMI Splitter, 4k HDTV SPLITTER
3DHDMI Switcher, 4k HDTV SPLITTER
3DHDMI Converter,Audio
Splitter,Audio Converter,Audio
Matrix and others AV Products.
You are welcome to contact us today.
Duke Chu
Posted on Jan 03, 2014
MikeNJ1964
  • 398 Answers
SOURCE: Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Posted on Jul 09, 2007
SOURCE: Mitsubishi VS-50707 shuts down sporadically
what if the pic doesnt stay on long enough to run the test? Mine doesn't stay on more then 15 seconds before it powers off. This happens everytime now.
HELP and THANKS
Posted on Apr 07, 2008
SOURCE: mitsubishi model vs-5043
I just had this same exact problem. I looked for an answer on here and could not find one. So I took the back off, vacuumed and cleaned everything out with the hose on my house vacuum, cleaned the bulbs and wiggled them around some. Voila !!!! lights on and all is working fine and better then ever. I hope this helps someone fix their problem. Just saved me tons of money and a morning of hassle.
Posted on May 06, 2008
  • 3 Answers
SOURCE: tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
Posted on Oct 31, 2008
SOURCE: My mitsubishi VS-50707 won't turn on
is it a projection
Posted on Mar 15, 2009
I have a Mitsubishi 50" Big Screen Model VS-50707. When trying to turn it on, it blinks once and clicks, then doesn't turn on. It has been doing this for a while, but eventually would come on and need some...
The picture tubes are warn out or the deflection circuit is failing. The power supply is struggling to fire them up. Takes a lot of power.
Some TV shops have the know how to replace the tubes. About $1000 parts and labor.
Dec 30, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Tracking on my tv Mitsubishi 50707 50in
i have the same tv cant fix the tracking .model 50707 mitsibishi
Dec 26, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
Mitsubishi TV
run from it bring to shop you would not sit in front of atrain blowing its horn
Feb 27, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi vs 50707 50 inch projection tv problem
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Dec 15, 2007 | Mitsubishi VS-50707 50" Rear Projection...
VS 50707 turns on, then off immediately
Dec 10, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707 - Scrambled picture
Nov 08, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
93 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
