Question about InFocus ScreenPlay 5700 Multimedia Projector
Screenplay 5700 green light flashing - InFocus ScreenPlay 5700 Multimedia Projector
3 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: its an Infocus screenplay 5700 projector.it is not powering up
replacing the main board.
Posted on Jan 27, 2010
  • 269 Answers
SOURCE: screenplay 5700one horizontal line across entire screen, comes on
this could be the main board or the dmd board on the light engine. you can try disconnecting, cleaning the connections with an approved board cleaner, blow the connections completely dry and then reseat the connections firmly. This has worked many times for me. If the problem still persists you will have to have the projector tested to find out what needs to be replaced.
Posted on Jun 16, 2010
Need Manoal
I have the manual with me. If you can give your email address then I'll sent the manual of InFocus ScreenPlay 5700 to that email address. Or you can down load the manual from the following link.
http://www.retrevo.com/support/InFocus-SP5700-Projectors-manual/id/1081ag706/t/2/
OK
Oct 10, 2011 | InFocus ScreenPlay 5700 Multimedia...
Screenplay 5700one horizontal line across entire screen, comes on
Jun 16, 2010 | InFocus ScreenPlay 5700 Multimedia...
Hi, it doesn't power up when I plug it in.
Sounds like the power supply has gone bad. If you interested in getting it repaired you can find me on ebay. Gtitubro is my screenname.
May 22, 2010 | InFocus ScreenPlay 5700 Multimedia...
Projector will not power on.
Since you see a the power button light up green there is a chance that the power supply is still good. Try updated the firmware. You can get it from the infocus website. If that doesn't work then something is wrong with the power supply. I can repair it if you'd like. My ebay screen name is gtitubro.
Apr 28, 2010 | InFocus ScreenPlay 5700 Multimedia...
Green Light continually flickers when I switch on and projector does not start
the lamp needs to be replaced and the lamp timer reset. also check the colorwheel.
Mar 12, 2010 | InFocus ScreenPlay 5700 Multimedia...
I have audio and can bring up the menu but no picture
what input are you using? if you are using vga, the cable may be bad. if component, make sure the h and v are not switched around. if rgb, make sure the blue and green are not switched. the green carries the h+v info. if composite, check the video cable. if all else fails, you may need to replace the main board.
Jan 10, 2010 | InFocus ScreenPlay 5700 Multimedia...
The power button light flashing rapidly (white light NOT green)
OK - I had 100% the same problem, and after lots of trial and error, and asking for advice, here it is: The capacitor is "C16" - a small blue electrolytic - 100uf 16v. It is in the center of the power supply board partially hidden by a black heat sink and the large silver chunk of metal.
Swapped for a 25v 100uf I had lying around and she works like a charm now.
Jun 08, 2009 | InFocus ScreenPlay 5700 Multimedia...
Screenplay 5700
Because these units have dangerous high voltages inside, there are a number of safety interlocks throughout. Take out the lamp and reseat it. Also, make sure that the access door is installed correctly and securely. Both have interlocks that will prevent a poiwer up is not installed correctly.
If this is not the case for you, please update this and we'll look for other causes.
Thanks,
Dan
Jan 05, 2009 | InFocus ScreenPlay 5700 Multimedia...
InFocus ScreenPlay 5700 Multimedia Projector Logo
27 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
