Question about Remote Start System
Remote start sends signal but truck just cranks over no start
Truck just cranks, no start
    Problem Solver:
  • 13 Answers
Change the batteries in the remotes. What happens when you press your starter button is it sends signal to the car to crank and then it needs to send another signal to start. The second phase would fail because the battery in the remote was low. Try replacing the and see if that works
Posted on Jan 03, 2014
  • Larry Spears
    Larry Spears Mar 03, 2014
    When the a vehicle is remote started, the remote does NOT send two seperate signals! the reason your vehicle is not starting is because of an immobilizer issue(chip in the key) or, a tachometer signal. You don't mention the year, make and model (which ALWAYS important information when seeking help with that vehicle).
No start no fuel or spark
What about your ignition module? I can't tell if you just replaced coils or ignition module included? Also, before buying anything, check voltage and ground for ignition module. Pink wire is voltage, black wire is ground.
The crank sensor sends ac signal to ignition module, the module converts signal to dc, something the computer can handle, then sends rpm signal to computer.
Dec 16, 2015 | 1999 Chevrolet Cavalier
Trouble code PO335
fuse or fuel filter first! Cam sensor.
Nov 02, 2015 | Cars & Trucks
My 2013 chevy cruze cranks by itself when it's low on gas!!!
Are you there when it starts the car has do receive a signal to start the remote sounds like it's faulty in some cases I've seen remotes from people at my work start mine dose it happen when your near it
Feb 05, 2015 | 2013 Chevrolet Cruze
1991 mitsubishi mighty max 2.4 has no injector pulse why?
It could be that your crank sensor is bad or your ecm. your crank sensor sends a small amount of voltage to your computer telling it that you are trying to start your engine the computer in turn sends a signal to the injectors telling them to pulsate because you are trying to start the engine but if your crank sensor is bad and sends no voltage signal to your computer your computer doesn't know you are trying to start your engine therefore it doesn't send the signal to your injectors telling them to pulsate. If your crank sensor is sending a signal to your computer then your computer is not sending the signal to your injectors more likely a grounding issue through the computer I have seen this before let me know how it goes.
Aug 26, 2014 | Cars & Trucks
I have a cool start remote starter... on the remote starter the blue light goes on when i press the start button, unlock, or lock button....so i kno the battery isnt dead. but it just wont work. my freidn...
The starter need a lot more charge to crank the engine then lights, door lock and other auxiliary equipment. So it could be a battery. Try jump wire your car. If this does not help - check the starter relay in the relay box of engine compartment.
Jul 11, 2011 | Ford Taurus Cars & Trucks
I have a 1996 BMW 318TI and when I turn ignition, the engine dosen't turn, but when i put a remote starter the engine turns, but no spark fire from spark. I need a solution to fix this quick!
Does the key have a alarm on it if it does youll need to replace the battery in the key.When the key is put in the transponder sends a signal to give spark and it does.then it starts. If you say the key doesnt have a alarm try this when the key is turn to the ACC position do you hear the pump. now if you crank it with the remote does the pump turn on? If yes you can do this go to the crank sensor pull on the harness(crank sensor has a tendency to get loose) does the crank move if it does youll need to tighten it up with the proper gap. if it doest solve it do this. close the door with the battery at a proper charge put the key in the door unlock it get in put the key in ignition now does it crank. If no you have a alarm problem.
Apr 23, 2011 | 1996 BMW 318
97ford explore is not getting gas after changing fuel pump
Be sure your fuel filter isnt clogged also check the fueses if both of these are ok check the crank sensor it sends information to the pcm telling it you are trying to start the engine it then sends a signal to the injectors to spray fuel but if the crank sensor is bad then the pcm doesnt know you are trying to start the engine and therefore never sends the signal to the injectors to spray fuel.
Jan 30, 2011 | Ford Explorer Cars & Trucks
Wont start with key in crank poisiton starts after letting key back to run posi
the ignition switch is faulty, not sending signal on crank, replace it
May 08, 2010 | 1994 Dodge Ram 2500
Remote Start System  Logo
500 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
