Question about Kenmore Elite 45986 Front Load Washer
Tank fills when not in use
The tank fills with water when not in use. I have opened the door not realizing it has filled with water and have water spilled all over my floor.
  • 10,865 Answers
So sorry to hear of your trouble. It sounds like your water-inlet valve is defective:
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Posted on May 21, 2009
We added anti freeze into our water hold tank. There is a pink film on the bottom of the tank. How do we clean the film out of the tank?
problem is there is an RV for your system. you will need to do the following.
Drain all holding tanks, fresh water and sewage
  1. Attach garden hose to fresh water fill and fill tank.
  2. Turn on pump switch and open cold water side of all faucet/ shower fixtures. Leave open until water runs clear. Repeat for hot water side.
  3. Flush toilet until clear water runs into bowl.
  4. Dump tanks again.
  5. Sanitize water system. use a water sanitizer
  6. If a water filter is installed, drain lines, remove filter assembly, clean and reinstall with new filter.
  7. When ready to use the water heater, turn by-pass valve to open position to allow water to enter and fill the hot water heater tank.
May 10, 2017 | RVs
Why is fresh water tank filling up when hooked up to city water?
Many RVs have the plumbing to fill the fresh water tank from the city water hook up. This valve is usually near the city water hook up and labeling is similar to "city water" and "tank fill". Another anomaly from leaving the valve in the "tank fill" position is that, when not connected to city water, the on board pump may run continuously and the water volume is very low.
Jan 25, 2016 | RVs
Fuel filler door want open how do I get it to open?
Ford Escape Questions - Gas tank door - CarGurus
www.cargurus.com > Questions > Ford > Escape
CarGurusApr 17, 2014 - If you have to use a gas can (from running out of gas), the car will come with a ... If it's not big enough, the metal door won't release. ... ford 2009 escape cap less fuel tank I cannot get the flap door open go fill the tank 1 answer.
Opening gas tank - Ford Explorer and Ranger Forums "Serious ...
www.explorerforum.com/forums/showthread.php?t=312717
Apr 6, 2011 - 12 posts - ‎10 authors
Opening gas tank Stock 2011 - 2016 Ford Explorer Discussion. ... open the fueldoor. I am out of town so I was trying to get some feed back to let her know tonight when I talk to her. ... Push on the gas door and it will pop open for you. ... Your fuel tank is equipped with an Easy Fuel "no cap" fuel filler system.
Cap-less fuel fill stuck shut!!! - F150 Ecoboost Forum
www.f150ecoboost.net/forum/.../8119-cap-less-fuel-fill-stuck-shut.html
Oct 30, 2014 - 10 posts - ‎6 authors
So this morning I stop to fill up with fuel and I can't put the nozzle in the tank! ... station where their fuel nozzle didn't "fit" the capless thing so the door didn't open. ... You need the Ford funnel. ... Like they're saying, if the pump end isn't big enough it won't hit the latch. ... You'll get the nozzle stuck in the filler.
Jan 24, 2016 | 2013 Ford Explorer Limited
Is there a valve to open on the fresh water tank when using it?
Yes. Open the outside panel, usually located close to or beside the city water inlet. Should be a diagram showing "normal", "tank fill" and "winterize." Use "fill" to fill the tank. Water will run out the underneath drain when full. I recommend a water pressure limiter just in case the city water pressure is excessive. You can rupture a line or the tank if too high. Rare, but it does happen.
Flip the valves to "normal" to use the city water. If boondocking, the pump will pull from the fresh water tank directly. No need ot change anything.
Oct 08, 2014 | RVs
Water supply to toilet fills up tank too slowly
Valve fully open on inlet going into toilet if it is then fill valve needs to be replaced check water line for any abstructions that might interfere with water going into tank.
Apr 02, 2014 | Kohler Home
Fill-trol what does do on the heating system?
How the Amtrol FILL-TROL(c) Expansion Tank System Works:
Water enters the FILL-TROL valve, pushing open the check valve, and flows into the heating system. The automatic shut-off valve is kept open by the diaphragm pressing against the pressure plate, raising the stem of the fill gate, which compresses the automatic shut-off valve spring. When the heating system reaches fill pressure, the tank's diaphragm depresses, and the automatic shut-off valve is closed.
Whenever system pressure falls below 12 psig, the automatic shut-off valve is pressed open by the diaphragm. Make-up water flows into the system to restore pressure.
http://www.plumbersurplus.com/Prod/Amtrol-110-FILL-TROL-Expansion-Tank-4-4-Gallon-110-1/7938/Cat/219
The AMTROL FILL-TROL(c) system consists of a specially adapted EXTROL pre-pressurized, diaphragm-type expansion tank, and the FILL-TROL, a specially designed, automatic, fill valve.
  • Provides accurate system make up
  • Eliminates need for a separate, automatic fill valve
  • Fully adjustable up to a maximum working pressure of 100 psig
  • Factory pre-charged; tank pressure controls system fill
http://www.amtrol.com/filltrol.html
Nov 08, 2013 | google.com
I fill the tank up, but it seems too light to be full, so I drain it and it only has about 1 gallon if that in it. Whats wrong?
How are you filling the tank, and is this in an RV or what? Open pressure relief valve when filling and when water comes out pressure relief valve, you know your close to full. If it doesn't come out there when valve is open, check for by-pass valve(s) in wrong position and not filling the tank.
Aug 11, 2011 | RTO Atwood Water Heater - 6 Gal LP
The machine will say Fill water tank. So, we will take the container out of the machine fill it to or just a little above the recommended line and then put it back into the machine. It will be full and it...
After filling the water tank, can you see if a grey plastic piece, in the back of the water tank, is floating?. If no, then that part needs to be replaced. If it does float, then the integrity of the water sensor, (located in the back of where the water tank is housed into), will need to be tested. Testing this sensor requires, tricking the coffee maker... that the door is closed. With Coffee Maker in the "ON" position, you will need to hold door switch in (located top right corner of unit, with door opened). As switched is held in, you will need to use a magnet and place it around the rear of where the water tank is housed into (Rear-left middle height area)... just around where the water tank float would be, if it were filled with water and inserted into the coffee maker. This sensor isn't visible, but is activated when a magnet is placed around it. If "FILL WATERTANK" message goes away, then replace plastic float or water tank itself.
Nov 16, 2010 | Miele CVA615 Espresso Machine
No ice or water from in-door dispenser
When you first hook water up to the refrigerator you have to fill a tank in the fridge. Open the water supply behind the ref. turn the control on the front of the ref to water and hold a glass under the spout as if you are filling a glass . You may have to wait 3-4 minutes forthe tank and lines to fill with water before you get any to come out into the glass. The water my be discolored at first so run a few glass full through before drinking . hope this helps
Bobalix
Apr 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Sep 22, 2008 | Sunbeam Ultrasonic Humidifier
Kenmore Elite 45986 Front Load Washer Logo
124 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
