Question about Lexmark X83 All-In-One InkJet Printer
Paper will not feed
X83-Paper will not feed past the "loading" area.
    Sergeant:
    Champion:
  • 240 Answers
Its a software issue for me..
I suggest that you will load compatible firmware to your printer...
that's why the printing performance of your printer is very slow..
thanks for using FIXYA.
good luck.
Posted on May 21, 2009
If I schedule a print for my Lexmark X83 it feeds one sheet of paper straight through to the tray but does not print anything. No alarms anywhere on system. Same thing occurs if I ask for test print or...
Sounds like a clogged print head. In the lexmark printer software there should be a maintenance tool where you can try and clean the print heads.
By the same token the X83 is about 10 years old and well past the life cycle of most ink jet printers so if the troubleshooting tools don't get it back in order, it will be cheaper to replace than to repair.
http://www.lexmark.com/AP/service/info/multifunction/4403.pdf
Jul 09, 2011 | Lexmark X83 All-In-One InkJet Printer
My lexmark x83 is making a clicking noise and will not pull paper through.
hello, the problem with your machine is a gear that drives the paper feed section, not the paper feed roller but the platen roller, well its cracked, unless you have an identical machine, you will not be able to repair this printer, i have tried. so, this machine has performed for you extremely well, but now it time to look for another one. sorry
Oct 07, 2010 | Lexmark X83 All-In-One InkJet Printer
Lexmark x83 paper feed problem
If your not qualified to do this I would not sugges you do it, tho here is a solution for you. See if its snapped in place instead of being bolted down. you can also access underneath the unit hope this helps.
Apr 22, 2009 | Lexmark X83 All-In-One InkJet Printer
Paper will not feed
There is a gear that normally breaks, or cracks and it does not finish feeding past the print head, no parts are available for it unless you find one for sale with a different problem, you are stuck
Jan 13, 2009 | Lexmark X83 All-In-One InkJet Printer
X83 lexmark A06 error (paper jam)
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 31, 2008 | Lexmark X83 All-In-One InkJet Printer
Paper jam Lexmark X5470
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Nov 18, 2008 | Lexmark X5470 All-In-One InkJet Printer
Paper jam
Try bellow steps to resolve paper jam.......
Have any other queries.. please let me know..
Thank you....
Oct 11, 2008 | Lexmark X83 All-In-One InkJet Printer
Won't feed paper while printing
I just obtained a printer with the same problem. When I opened it up I discovered a plastic gear that had cracked and was not turning the main paper roller as it was slipping. It looks like the solution is to replace the roller if you can find one or to repair the gear and epoxy back onto the roller. I am trying the later.
Apr 22, 2008 | Lexmark X83 All-In-One InkJet Printer
Paper will not feed into printer
Oct 17, 2007 | Lexmark X83 All-In-One InkJet Printer
LEXMARK X83 PRINTER 1) A few times papers jammed too far back to pull out from the front so i pulled them out the back. Now when the paper feeds there is a clicking noise and the papers feed only...
Oct 10, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
166 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
