Question about Amr Racing Arctic Cat Firecat F5,F6,F7 2003-2006 Snowmobile - Guns - Red Sled Graphic Kit
Arctic cat 2012 m800 HCR
Key switch will shut off motor, but handlebar kill switch and safety kill tether won't.
Pulled the plug wire off the right cylinder and it killed the engine
Electrical Diagnosis for Arctic Cats - YouTube
? 9:58
https://www.youtube.com/watch?v=iwwl4LPyOCY
Dec 29, 2009 - Uploaded by BlaineDP
When in the "OFF" position the switch will ground the ignition wireto the chassis effectively "grounding out" the ignition systemkilling the spark. ... becomes disconnected or if a wire gets cut then the switch will no longer turn off the engine. ... Testing a stator in a snowmobile Arctic cat - Duration: 3:25.
CAT AS NO SPARK!! - American Snowmobiler Magazine ...
cs.amsnow.com > ... > Forums > Manufacturers > Arctic Cat snowmobiles
If the connection to any switch; key, kill, tether, throttle safety switch, etc.. is ... Some older model Arctic Cats have the ground up closer to the handle bars on ... Here is a general rule of thumb for putting spark plug wires on which cylinder for Cats: ... Pulledthe ECU cover off and found some corrosion; I had a 580 that did not ...
Jan 16, 2016 | ATVs
2006 attic cat 400 runs great in 4x4 but when you hit the switch to 2x4 runs bad like it's booging down
'03 400 backfiring/bogging under throttle - ArcticChat.com ...
www.arcticchat.com > ... > ATV's > General ATV Discussion
Apr 3, 2007 - 7 posts - ‎7 authors The engine would only sputter and bog down, kinda like the choke was hung. ... I didn't remember the fan running, so I checked the fan fuse, but it was ... of the windings and cause a misfire, so bad that it would kill the bike. '07 F8 intermittent start and bog issue - ArcticChat.com
Dec 23, 2012
Arctic cat suzuki 700 efi wont start - ArcticChat.com ...
Apr 28, 2012
400 4x4 idles but bogs out when throttle pressed ...
Jun 29, 2011
cat is slowly dying
Oct 10, 2008
More results from www.arcticchat.com
Oct 21, 2015 | ATVs
2012 arctic cat idles fine but cuts out when given throttle... any ideas?
are the fuel lines clear? also check the float in the carbureter. if it has a hole it will sink causing fuel starvation
Nov 30, 2014 | Arctic Cat 2013 Prowler 700 HDX
I have a 1990 Arctic Cat Cheetah Touring and everything runs well except when you turn the key to start the motor, it won't start. Turn the key to run position and short out the two power terminal
Well, I can probably help you but you will need a Voltmeter and know how to use it. Shouldn't be too much of a diagnostic problem but the VM is first. Do you have one and know how to use it?
Aug 02, 2017 | Toys
I have no spark on my 94 ext and it has a new stator and cdi box and igntion coil
Bypass your ignition switch , kill switch, and carburetor safety switches(on the side of the carburetors). All common problems for older sleds (stopping spark). In the carburetors the magnets inside the slides come off killing the spark. There is a kill switch bypass wire in most arctic tool kits. Ignition switches are notorious for going bad and are easily bypassed by simply unplugging them.
Jan 16, 2011 | Interactive Toy Concepts Crossfire Arctic...
Amr Racing Arctic Cat Firecat F5,F6,F7 2003-2006 Snowmobile - Guns - Red Sled Graphic Kit Logo
Top Amr Racing Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you an Amr Racing Craft and Hobby Expert? Answer questions, earn points and help others
