Question about Samsung Un46d6000 46 1080p Led Tv un46d6000sf / Un46d6000
My Samsung smart 46" only sound by no picture, change main board, t-com and power supply and nothing only audio
  • Samsung Master
  • 9,783 Answers
Only thing left is the back light control board.
Posted on Jan 09, 2014
SOURCE: sound no picture, which component is tcon board? where all audio/video/cable/hdmi plug in to?
I have LNS4692D. Returned from vacation, turned tv on - no picture. Tried turning tv off for 4 hours- nothing. Symptoms are: tv is on - no picture , just sound; menu doesn't show, volume bar doesn't show;E.Saving is working - the backlight is changing from lighter to darker.
Found this website and ordered T-con, otherwise known as the LCD panel driver board, p/n# Bn8101286a ( thanks premtech) from partstore.com for $124. Part number BN81-01286A A/S T-CON Board.
Installation:
1.Remove plastic cover. There is an arrow for each screw that needs to be removed. Make sure to unscrew pins next to VGA port. I've spent some time trying to figure out what else is holding the plastic panel until I found this pins.
2. Remove big metal shield in the middle of tv that is covering main components. This shield is being held by small black screws all around it.
At this point you will see cover of T-CON. Here is the picture
http://www.avsforum.com/avs-vb/attachment.php?attachmentid=118863&d=1220531321 (thanks ldac9). Do not attempt to remove that cover yet. Proceed with a next step
3.Remove metal panel that holds main components. Locate big chrome screws that have arrows pointing to them and unscrew them. Remove 2 more screws on the bottom of the panel that holds it together with a box for cables. At this point the main panel will be lose
4. Carefully start lifting the panel. You will see that there are connectors going from components on the panel to components on the lower panel and T-CON. Carefully unplug these components and raise the main panel.
5. Remove 4 screws that holds T-CON cover. Pull the cover so that T-CON is completely exposed. The cover is connected by thin alluminum , don't hesitate to pull it , but don't rip it out.
6. Once T-CON is exposed you will see 2 red ribbons. I've spent some time to figure out how unplug those from old T-CON board. Here is the suggestion. Don't try to pull it out. All you need to do is to lift small plastic lever that is part of a connector. Then ribbon can be slided out. If not sure what to do, see how this is done on the new T-CON. It has a principle of buckle on airplain safety belts.
7. Remove old T-CON and install new you.
8. Follow reverse order.
I've never fixed TV before , but this was totally successful project.
Posted on Nov 19, 2008
zjut
  • 106 Answers
SOURCE: picture is not coming on samsung spn4235
Remove the Power Supply cable to Y Main board and check the Vs voltage in Power Supply board.
1. Vs voltage is OK, replace the Logic board or Y Main board.
2. Vs voltage is NG, replace the Power Supply board.
Posted on Jan 01, 2008
  • 718 Answers
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Posted on Mar 30, 2009
Cool_dud 09
  • 206 Answers
SOURCE: power supply board
Hai,
Please check on here....you will find it out!
Posted on Aug 23, 2009
  • 6 Answers
SOURCE: HPT5054 50 in. HDTV-Ready Plasma Television: Samsung HPT5054X/XAA - No picture, Sound OK, Have ...
It's not the x main. 90% of the time it's a y buffer that goes out. It's usually the top buffer. 3/4 of the time the buffer takes out the y main board too. You cannot just replace the y-main or buffer because it will just burn out the other within seconds. Also about 1/4 of the time it'll take out the top transformer on the power supply too. The solution? First disconnect the power to the y main board. turn on the television and check the voltages coming off of it. Careful it's high voltage 208V! Remember it's DC too. Then disconnect the buffers from the y main board. You can try powering the y-main up to see if the little LED lights up. This does not indicate it's working though but it'll tell you if it is possible to fix. The fixes for these boards is only for electronics guys. It usually involves replacing 1-3 capacitors and 1-4 FET's. Since a bad buffer can take out a good y main in seconds it's usually recommended that one replace all 3 boards at the same time. It's a $250 fix. How do I know all this? I've now repaired 5 of these televisions. I owned one and spent close to 600 repairing it. I bought misc parts and broken sets online for months before I had 2 different repair guys walk me through the process of repairing them. I had so much cash tied up in parts that I bought 3 more dead sets and repaired them to justify all my spending. I've never had an x board fail. I've had EVERY top buffer fail. I've had all but 1 y-mains fail. and 1 lower buffer fail. I've also had the y buffer fry it's top chip, blow a capacitor and FET on the y-main, and fry the top transformer on the power supply before my eyes. It only took 5 seconds. Replacement of the 3 y boards will almost always fix the sound but no picture problem. Hope this helps!
Posted on May 26, 2010
Samsung smart tv no picture and sound. Replaced T-CON and Main Board. Same result. Any ideas?
did you change power supply? how many times does light flash (red) you didnt change the power supply did you use a vom on connections?
We Are Here To Help !!!
Donal Deane MCSE,ASE,CPO
Aug 18, 2017 | Samsung Televison & Video
Samsung LED tv 46". There is no picture. We have audio and can see the images with the flashlight test. We changed all 3 boards and still don't have a picture. We are not sure what to do next.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 22, 2016 | Samsung Televison & Video
Samsung 46 Inches LCD TV Model#LN46C630 Black Screen with Sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 23, 2016 | Samsung LN46C630 TV
SAMSUNG 42" TV screen/picture fades to dark. Only comes back if I press volume control!? First noticed image darkens shortly after turning on the tv, now its constant.
like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Repair/service assistance to electronic equipment
The author of the site http://electronicshelponline.blogspot.com/ is now to provide online repair/service assistance to electronic equipments. With more than 50,000 of service manuals and user manuals to different type of electronic equipments; Students and service professionals in electronics can now make the benefit of it. Contact: gopalan.gopakumar327@gmail.com
Aug 27, 2016 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Hi. I have a Samsung LED 46" model #UN46EH5000FXZA, with no picture but has sound.I replaced the power supply board & T-Con board & still no picture but have sound. What can I do next??
Do flashlight test to see if y0ou can see an image - if so replace the inverter board that powers backlights. If no image then go for the main board.
Aug 12, 2016 | Samsung Televison & Video
My Samsung smart tv has sound but no picture
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jul 25, 2016 | Samsung 5500 Series UN32F5500AF 32" LED...
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Replaced main power board and t con board. Picture now works, but horizontal white lines moving upward.
Sounds like fault with its main power supply bard too. Check all the wiring connections from the main board to SMPS board for any loose connection. Improper wiring too can cause this fault, due to AC line interference. Check these well, before replace the SMPS [power supply] board.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 25, 2015 | Samsung LN46A650 46 in. LCD HDTV
Have a samsung lcd 46"....turns on fine and picture looks good but no sound. I have checked the mute and also have checked that sound is turned on from the menu. Also checked to make sure no head phon
the main board will need replacement. Audio signal are produced on the main board so replacing the main board should solve the issue. You can get replacement main boards from www.tvcircuitboards.com
Dec 10, 2012 | Samsung LN46A530 46 in. LCD HDTV
Samsung LN-S4692D with no picture no sound.....does the Tcon board effect the sound as well as the picture?
T-Con board provides video signal to lcd panel (basically t-con board is part of lcd panel) and has nothing to do with sound in tv.
Please check power supply board is providing required volts to main board and if volt supplies are correct then main board could be defective because it has video and audio processors.
Hope this will help.
Thanks.
Mar 05, 2011 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung Un46d6000 46 1080p Led Tv un46d6000sf / Un46d6000 Logo
178 people viewed this question
Henry  Thomas
Henry Thomas
