Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
Heating is limited
With the system set on 104 the unit will only heat the spa to 72 degrees. There are no error codes on the system. What should I check?
    Top Expert:
  • Jandy Master
  • 8,500 Answers
If using control system turn heater all the way up the controller governs heat
Posted on Feb 13, 2018
    Problem Solver:
  • 7 Answers
The system has one temp but the heater temp should be turned all the way up outside on the unit as well
Posted on Jan 03, 2014
4 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: can you heat the pool and spa at the same time?
Here is a link to the owners manual and users guide.
Aqualink RS24
Posted on Mar 04, 2009
  • 61 Answers
SOURCE: Spa only gets to about 90 deg
For a quick fix you could swap out the air and water temp sensors. They should be exactly the same.
Posted on Apr 12, 2009
  • 990 Answers
SOURCE: I have a Jandy Lite
This sounds very much like spider webs in the gas orfaces. If you shut the power off and remove the wires to the gas valve then shut the gas down and remove the fed pipe from the gas valve you should be able to pull the burner tray out of the heater. Now if you remove the burners you should be able to remove the brass orfaces connected to the main gas feed pipe. If you use an air hose or a can of compressed air you can blow this out now. Now take the orfaces you removed and clean them with a tooth pick or a small piece of wire. The webs will look like small cotton balls or lint. They don't stop the gas they just slow it or disperse it and keep it from firing clean and evenly.
At this point you can reassemble the tray and install. This should fix your problem.
Posted on Nov 14, 2010
Spa was below temp, now it heats and won't shut off.
Is your spa overheating, heating up past 104 degrees?
If so, you have a contactor (or relay) stuck shut and the spa should go into OH at 108 degrees.
d
If your hot tub is only heating to 104 or what ever temp you have it set at and the motor runs 24 hours a day there are a couple of things you'll want to check.
First, make sure that you do not have the pump set to run 24 hours a day.
Second, you'll want to see if the pump icon is lit up on the control panel. You will want to check to see if the icon is on while the spa is supposed to be resting. During filter cycles the icon will be lit. If you are not in a filter cycle and the pump is on while the icon light is off, you have a stuck contactor (relay). The relays can be found online for less then a couple of dollars.
If you have any more questions feel free to ask.
Feb 23, 2015 | Dream Maker Spas Dream Maker Spa - X500...
Our hot tub temp keeps dropping daily into the 90's temp when it is set at 104 degrees. When we turn the high speed blower on, it seems this is the only way we can get the temp back up to the
calcium will stick to heating element 1st and make it less able to heat water , eventually it will consume the entire surface and insulate the water from touching it and warming it and finally overheat it and cause burnout , high calcium (limestone) is usually a condition that occurs when filling via a well or stream , consider getting a load of pre softened water from a municipal water system , there should be a list of haulers in your area that can provide this service
Jan 08, 2015 | Pool & Spa
Heats to only 72 degrees
make sure heater is set to 104 degrees aqua link controls temp
Jan 03, 2014 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Heats to 72 degrees
try setting heater all the way to 104 the aqualink should control the heat
My apollo spa galaxy II D20Nj will not heat past 85 can you tell me what I should do or part to get to fix this serial #BSJLJEG
make sure spa setting is at 104 degrees if at 104 degrees see control system if ok change temp sensor either in heater or control unit
Dec 07, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Leisure Bay spa will not heat past 86 degrees. Element and sensors are new. Spa has excellent flow and correct voltage at terminals.
if the spa does not heat up to 104 degrees then the temp sensor is what you are going to need.
Are there error codes showing on the screen of the topside?
You will need to know the model number of the control box or the model number of the heater tube in order to get the proper sensor.
Rod
US Parts Center
888-521-6183
Feb 09, 2013 | Pool & Spa
I have an Aqualink system, spa set to 104, it will heat to 94 and stay there, temp sensor is working, took water sensor out of line, plugged line, assumed heater would just keep heating, it did heat a
The heater may be wired just fine. The aqualink uses its water temp sensor to call for heat based on what you've set the thermostat to on the aqualink. However, most heaters have built in thermostats that over-ride the aqualink. Those thermostats come factory defaulted not to go over 94. Check your heaters manual on how to adjust the thermostat on the heater. Your heater should have its thermostats set to 104 and the aqualink will control the actual temp of the water by calling for heat based on what you've set the thermostat on the aqualink for. Hope this helps.
Oct 16, 2012 | Jandy Aqualink Rs4 One Touch Control...
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
129 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
