Question about DeLonghi EAM3400 Espresso Machine
Will not water
The machine is not drawing water through to completion. No water will come through steaming wand either. I believe either pump not working or valve on top of pump plugged?
  • 452 Answers
Hi as you turn the machine on turn the steam knob fully ..this will bleed your system ... if it dont bleed through replace your pump or check filter inline right side of machine ... [turn machine off befor removing main covers } 07779933829
Posted on Jan 03, 2014
  • Teresa Brodman
    Teresa Brodman Mar 27, 2014
    I have the same problem. It brews slow and not a full cup. But it bleeds out.
4 Suggested Answers
  • 4 Answers
SOURCE: No water ever makes it through the pump
I just got mine working again. There was scale in the outlet port for the coffee basket.
Try cleaning by running through a solution of CLR and water (1 to 4 parts) and keep running until the blockage dissolves and flow is restored. Then run another solution again just to clean it for good.
MAKE SURE TO RINSE OUT THE RESERVIOUR VERY WELL. Should run clear without foam after about a gallon of clean water.
Posted on Mar 26, 2008
SOURCE: DeLonghi Magnifica Super Automatic Espresso
I read the manuel and was taking the wrong part off to steam. oops
Posted on Dec 29, 2009
e-Guru
  • 3917 Answers
SOURCE: When the steam knob is turned I can hear the pump
Hi
The steam nozzle is clogged up. Clean the holes in the cappuccino maker and the steam nozzle and see if it works.
Before cleaning the holes in the steam nozzle, make sure that there that it is not hot and there is no pressure on the machine.
Please get back to us if you have further query or else please accept this "particular" solution.
Thanks for contacting fixya.com
Posted on Sep 21, 2011
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
I have decalcified my Gaggia Synccrony twice using a product from the grocery store called dip-it and it is still saying to decalcify the machine
First of all - Dip-it is a detergent to remove rancid oils from coffee cups and coffee makers. That is not the same thing as a decalcifier or descaler. Dip-it was never meant to go through your boiler and pump and valves and all the other parts inside your Gaggia.
I'm quite sure that if you read the Gaggia manual it will tell you to use a special descaler such as Dezcal or Durgol.
Some people say use white vinegar - the manual specifically says not to use vinegar.
The machine is pretty expensive - it's worth buying the right product to descale it.
The manual should walk you through the steps to descale which will clear the error message once all the steps have been completed. I don't own that specific model, but typically you add the dezcal powder to very warm water in the water tank. Then start the descale process which will prompt you to open the steam valve and pump some water through the steam valve (into a container you place under the steam wand to catch it). Typically it will cycle a little water then pause for several minutes while the descaler disolves the calcium build up in the boiler - then it will pump a little more though and then wait etc. etc. Depending on your machine it may pump water out the coffee spout as well as out the steam wand. If so, the machine should prompt you to tell you to open and close the steam valve.
After it has run all the chemical through the machine (usually after it has emptied the tank) it should then prompt you to rinse. You remove the tank and wash it out and fill it with clean drinking water and then let the machine continue on the rinse cycle which will pump all the clean water through the unit. So you need to be on hand to catch all that water and dump it in the sink. When you are all done, run a few blank shots and make sure the water tastes like clean drinking water. The descaler is mostly citrix acid (like lemon juice) so if the water tastes sour like lemons then it isn't completly rinsed yet and you may want to pump more fresh water through the machine (pull blank shots or pump hot water through the steam wand) until it is fully rinsed.
Once the machine completes the rinse cycle it should stop prompting you that you need to descale.
Oct 11, 2010 | Gaggia Titanium Espresso Machine
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Solis pallazo rapid steam. I can't remember how to clean the system
Descaling the Palazzo: The Palazzo is programmed to descale the boilers on its own, when set in the correct mode. You program the machine to descale it's self, do the following. With the machine turned on, push and hold the left 2 buttons (clean and pre-ground). This should light the top right red indicator light. Mix your descaling crystals in 32 to 48 oz in your water tank. Stir until they are completely dissolved in the water. Next, have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz's. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the bottom will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, and then close, and then open the steam knob again and let the water just flow through the boilers until it is emptied by the machine. Don't turn off anything until the machine stops on its own. This will clear the descale light. Refill the water tank again with fresh water and your ready to go.
Sep 10, 2010 | Solis Palazzo Espresso Machine
Hot water come out from steam wand when pumping Saeco Classico
Gasket on steam valve is worn. Replace gasket and or steam valve.
Mar 05, 2009 | Saeco Classico Espresso Machine
Water leaking from steam wand when brewing shots
Try this from another post. It should help.
The steam wand began to seriously leak but a call to Starbucks Customer Service line and I was talked through how to adjust it so that the leaking stopped. It requires taking off the top/back panel of the machine (6 philips screws) then using a small allen key (1.5 mm I believe) to loosen and adjust a plastic oblong donut-shaped thing (a "cam" actually) on the shaft of the steam knob... no more drips.
The key to prevent dripping is to open the steam knob without putting pressure on it when it gets to the full-open stop position. Cranking it too hard when it comes to a stop in the full-open position will slowly move the cam out of position. Then the shaft doesn't fully seat inside the machine anymore and won't fully shut off the water to the steam wand. Then, no matter how hard you crank the knob in the shut-off position it will still drip. The purpose of the cam is to stop the knob from complete unscrewing and it also turns the pump on and off for the steam wand. The cam adjustment is very small but completely solves the dripping problem. Seeing inside the machine made me realize how easy it would be to repair problems as long as I can get the parts from Starbucks or perhaps Saeco.
Dec 21, 2008 | Starbucks Saeco Italia Digital Barista...
Miele steam wand doesn't work
hi i have the same problem as listed no steam . pump make the noise but no steam some time a drip of water thans 07764308535
May 13, 2008 | Miele Coffee System
Francis!Francis!3X overheating
Your thermostat has failed. The middle button is the pump. The bottom button is for the steam mode. If you are getting steam instead of hot water when using the pump, then the boiler is way too hot. Either adjust the thermostat or try descaling the boiler.
Feb 13, 2008 | FrancisFrancis! X3 Espresso Machine
No steam, just hot water.
The steam wand has to be removed to be cleaned properly. Unfortunately, this procedure is not outlined in the manual. Just cleaning the wand on the outside or using a clip to clean the tip is not enough.
The other end of steam wand where it connects to the pressuring cabin actually swivels around a fitting. It is this fitting that you need to thoroughly clean. Years of using the machine can cause calcification around this fitting.
If you look under this end of hte steam wand, you should see a philllip-headed screw. Before you loosen this screw, you have to remove the grey trim so that the entire wand can be remove.
Once the entire wand is removed, what I just described will be much clearer.
Nov 10, 2007 | Breville ESP8XL Espresso Machine
Open Questions:
See all DeLonghi EAM3400 Espresso Machine Questions
DeLonghi EAM3400 Espresso Machine Logo
301 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
