Question about Protocol Manta 4-Channel Radio-Controlled Quad-Copter
Trim problem. Won't hover ,just crash
How do you know what to trim when it's justcrashing
    Problem Solver:
  • 17 Answers
Try to operate while holding it... Or have someone else holding it, if you can feel where it's want to go while sticks are in neutral, trim it the opposit way. Good lock Have you look at gyro gain? Try to lower it as too fast makes it instable.
Posted on Jan 03, 2014
Suntracker pontoon won't start and trim won't work
Trim want work ,,want start,, no power
Jul 04, 2013 | Cars & Trucks
How to correct trimming problems did what the insteuctions said and keep having the same spinning counterclockwise problem
Just bought the air hogs helicopter with the crane. Had the aircraft constantly spinning clockwise, no matter how much I turned the trim control counter clockwise the aircraft still rotated. I then turned the trim control in the opposite direction until I noticed the aircraft had stopped spinning, and used the rudder control to fine tune forward flight. So, get the aircraft to hover and turn the trim button in the opposite direction until you see that the aircraft spinning slows right down. If you continue to turn the trim control in the same direction the aircraft will increase its spin, so just dial back the trim.
Dec 29, 2012 | Air Hogs Havoc Heli Helicopters
Mini phantom helicopter operating problems
Throttle slowly push on, until you fly the plane slowly so far (oneself fumble balance hovering position. But the movement wants slow, after all, the air force and reaction force have a reaction time)
Trimming is your plane total 360 degree turn the regulation has two screw rotation speed, let autobiography speed equal, also will not autobiography, how to adjust to the half empty when hovering in the opposite direction to the plane of the autobiography twist
The direction of the plane is you another joystick control and control is go around and control is to adjust the direction
Dec 07, 2012 | Toys
How do you finish the top row of vinyl siding.
I use Dual Undersill Trim
Secures trimmed siding panels under windows and eaves
regardless of the profile or where in the panel face the panel
has been trimmed
I also would suggest purchasing a Vinyl Siding Snap Lock Punch
is a hand held crimper that puts a crimp into the upper cut edge of a vinyl siding panel. When the panel is inserted into a vinyl sill trim it locks in and won't fall out
dennis675_5.jpgThey cost about 18-24 dollars.
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 04, 2011 | Hardware & Accessories
My S018 aurora is un-controllable, can barely mantain stability, All we can do is hover, have adjusted trim and spent hours trying to gain control. Frustrated, is there an adjustent screw on the aircraft...
If you mean it is spinning then: Adjust the trim so that you can hover and maintain stability at ALL altitudes and climb rates then i think you mean that once you push some forward on it will now spin. DONT WORRY or HOLD BACK. The craft will now spin but hopefully it will stop and begin moving forward you can now adjust its spin by using the right control stick (or a little trim). After practice it should beome easy.
Also Drafts can effect the craft quite violently so check your area for open doors etc...
hope this helps
Dec 26, 2010 | Toys
Heli wont go up very much and turns to the left
If thi is a Reflex with two opposing rotors and two directional fans then use the "trim wheel" on the top of the rotor assembly to counteract the spin. If you crashed it often enough the shaft for the top rotor may have come loose. I'm not sure how this actually works with the trim wheel but mine crashed a bit and the shaft came out. I re-inserted it and it worked OK for a while but eventually the gear inside stoppped grabbing the shaft and the top rotor would not spin. I took it apart and tried gluing the gear to the shaft and that got the rotor to spin at the same rate as the lower rotor but I could not trim to get rid of the spin on the body. I would advise not buying the Reflex becuse it does not hold up very well. I went out and purchased a Sharpshooter which is easier to fly and seems more durable
Jan 12, 2010 | Spinmaster Air Hogs RC Reflex Micro...
Iv got a 2002 laguna thats had a frunt end crash
fuel pump cutoff circuit breakers[crash switches] are usually located behind the fabric lining in the trunk,or behind a trim panel,on or above the inner rear wheel well.
Oct 11, 2009 | 2001 Renault Sportwagon
My heli wont hover, takes a large spiral downward, always to left
You either need to charge the battery, or just keep tapping the r trim button.
Mar 06, 2009 | Air Hogs Havoc Heli Helicopters
1995 jeep grand cherokee,i want to bypass the factory alarm.
the security module is located behind the dash trim at the glove box. remove glove box door, and top crash pad, and trim around glove box door. The security module is mounted behind the trim panel. Unplug it and it bypassed.
Jan 31, 2009 | 1995 Jeep Grand Cherokee
Protocol Manta 4-Channel Radio-Controlled Quad-Copter Logo
508 people viewed this question
Top Protocol Toys Experts
 Mikey
Mikey
gmduvall
 Russ Hill
Russ Hill
Are you a Protocol Toy Expert? Answer questions, earn points and help others
