Question about Technics Audio Players & Recorders
Technics sa-ex110 av control stereo recevier. has a overlaod display on the screen when you turn on the unit and a relay clieks.
You turn on the unit technics sa-ex110 av control stereo receiver and on the display states that there a overload and a relay is clicking
    Genius:
  • 1,175 Answers
It has a power amp module failure
and these cost more to repair than normal
Buy a replacement
Posted on May 27, 2014
4 Suggested Answers
Sparky2012
  • 102 Answers
SOURCE: My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Posted on Dec 04, 2009
dunnbiker
  • 8546 Answers
SOURCE: My Technics SA-AX540 AV Control
Heat?
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Posted on Feb 21, 2011
dunnbiker
  • 8546 Answers
SOURCE: HOW TO HOOK UP A
http://service.us.panasonic.com/OPERMANPDF/SAEX110.PDF
Posted on Apr 19, 2011
The volume gets noisy, cracking sounds and fades out
Your volume control is dirty. Apply some deoxit or wd40 directly onto the module.
Mar 22, 2014 | Panasonic Technics SA-G76 AV Control...
Technices ex110 recevier is displaying overlaod on the screen
It has an output power amplifier failure ( if all speakers are connected properly)
Time to buy a new one , it appears
Jan 03, 2014 | Technics Audio Players & Recorders
Can i hook up my technics sa-g76 to my tv
yes, using the the rca outs of your tv, and they will connect to an input on your reciever that may already be marked for a tv, or cable box
Jul 28, 2013 | Panasonic Technics SA-G76 AV Control...
Dec 04, 2009 | Technics SA-AX530 Receiver
Overload signal
The overload is the same as protect mode. Remove the speaker wires and turn the unit back on. If the message remains, there is a problem internal to the unit in the final stage of the amp.
Please let me know the results of the test above.
Thanks,
Dan
Mar 02, 2009 | Technics Audio Players & Recorders
Probleme with my home theatre...technics..av control stereo receiver- model SA-G76
just an idea maybe check the position of speaker select switch some models have
a or b
or a+b
Apr 24, 2008 | Audio Players & Recorders
154 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
