Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
Heats to 72 degrees
My unit will heat the spa to only 72 degree when it is set for 100. There are no error codes. Anybody have any idea what I should check?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Try setting heater all the way to 104 the aqualink should control the heat
Posted on Dec 01, 2014
  • 246 Answers
SOURCE: Spa will not heat more than 85 degrees or so
on the back of the board is the bottom for seting the max temp follow the intruction from the manual or get one at jandy.com
Posted on Sep 01, 2009
  • 990 Answers
SOURCE: My water temp is reading 50 degrees too high.
This is probally your temp sensor. It will be mounted in one of your pipes and held in place with a stanless steel clamp.and have a wire running back to your control box and plugs in on the low voltage side of the control. good luck.
Posted on Dec 19, 2009
  • 990 Answers
SOURCE: My indoor RS4 panel says the spa is heating, and
If the heater is set to 104 then this is probally your Aqualink temp sensor. This is mounted in a pipe with a stanless steel clamp holding it in place. If you follow the wire back to the controler box it just unplugs and the new one goes right back in. Easy to do and the part is inexpensive.
Posted on Dec 21, 2009
  • 990 Answers
SOURCE: JVA 2440 rotates continuously in spa mode
If you remove the handel and open thr top of the actuator you will see a set nut on the center of the shaft that you use to set where the valve stops. If this is tight then you may have a bad micro switch in the unit and you should replace the actuator. Good luck.
Posted on Jan 20, 2010
Daniel S
  • 4323 Answers
SOURCE: The spa heater says the
Hi
1. Turn off the power to both the pool/spa control system and the heater unit.
2. Remove the front panel door from the front of the heater to access the raceway.
3. Run the wires from the pool/spa control system through the opening, Thermostat is located on the lower right or left hand side of the heater.
Please check this link for more details---
Jandy LXI 300 POOL HEATER Manual
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 21, 2010
Heating is limited
The system has one temp but the heater temp should be turned all the way up outside on the unit as well
Jan 03, 2014 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Heats to only 72 degrees
make sure heater is set to 104 degrees aqua link controls temp
Spa keeps overheating
Faulty temperature sensor should do this to.
A floating thermometer should read water temperature within 3-4 degrees of spa controller. If it is greater than that your sensor is bad.
The hi limit is an over heat sensor it does not control the temperature of the water. If the water is heating above 118 degrees and the spa is not shutting down its Hi Limit.
Jan 15, 2012 | Dream Maker Spas Pool & Spa
My minimax nt only heats till 90 degrees. I set it up to 104 which is the highest and it only stays at 90 degrees. Everythig seems to be working well, no errors either. Please advice.
Either the thermostat board is defective, the temperature sensor is defective or not enough heat is being produced by the heater. . I recommend you call the Pentair technicalsupport at 800-693-0971 and they should be able to help you figure this issueout. I hope this helps.
Please vote on this answer. Thank you.
Aug 25, 2011 | Pentair Minimax NT Heater
Everyday the central air unit keeps our house at a comfortable 73 degrees. Every evening, despite the thermostat setting of 72, the house heats up to 77-79. What's the problem?
Is the sun hitting the t-stat during the day? If its a programmable unit check the programming, perhaps its set for energy sving at night
Jun 21, 2011 | Heating & Cooling
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
HI I have my hot tub at 104 but it will only heat up to about 80 degrees. what is my problem
If its set at 104, but only heats to around 80 degrees, then your heater is not working. Either the heating element is bad, or the pressure switch is not closing. The reason why the water heats up to 80 degrees, is from the friction caused by the mechanical shaft seal when the pump is running. Either way, you should really have it checked by a qualified spa technician. It is not something that the average spa owner can normally repair themselves. Sorry.
Sep 27, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
105 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
