Not updating my windows vista home premium is not installing the security updates...it says that "the update does not apply to your system"....pls help
  • Chris
    Chris May 11, 2010
    Are you using windows update or trying to manually install the update?
    Sniper:
  • 68 Answers
These are a few different things that could be causing this issue, it is normally caused by a failed windows validation
First try to go here: http://www.microsoft.com/genuine/downloads/faq.aspx?displaylang=en&sGuid=19dc02ac-6b2d-4fce-a2b2-00ed7160f812 and try to validate your windows. Then try the updates again, if this doesn’t fix your problem try the next steps below.
Try repairing your windows update agent here:
http://support.microsoft.com/kb/946928
Try following the steps found in this article:
http://support.microsoft.com/kb/900936
it’s for a different error code but has been known to fix some of the issues that you are running into.
Let us know if you’re still experiencing this problem after these steps.
Posted on May 21, 2009
Windows Vista Home Premium update error Code 643
You will find a solution here:
(you can change language by changing "/en" to your language code!)
http://support.microsoft.com/kb/976982/en
Nov 21, 2013 | Microsoft Windows Vista Home Premium for...
Adobe Photoshop Elements 4.0. Unable to install this programme on Windows 7 Home Premium system due to 'known compatibility issues'. Is there a solution to this problem?
Windows Vista Application Compatibility Updates are software updates that address common application compatibility issues in Windows Vista. Microsoft releases Windows Vista Application Compatibility Updates regularly.
If you want to immediately install this update, follow these steps:
  1. Click Start Collapse this imageExpand this imagevistastartbutton.jpg, click All Programs, and then click Windows Update.
  2. In the navigation pane, click Check for updates, and then follow the steps to install all recommended updates.
Sep 22, 2011 | Adobe Computers & Internet
Window vista home premium stop working after installing updates??
You can restore your system to an earlier point to avoid the updated vista.
To do so: 1.Type "restore" in the search field of your START MENU, 2.Click on SYSTEM RESTORE 3.Chose a suitable restore point , before your vista got updated. 4.successfully complete the system restore and restart.
When you restore your pc to an earlier point, updates are cancelled and in this way you can avoid the updates.
Click this for more information
Dec 11, 2010 | Microsoft Windows Vista Home Premium...
How to fix error code 646 microsoft windows vista home premium software
* The solution, in a nutshell, is to disable your firewall. If you’re using McAfee Personal Firewall Plus, F-Secure Internet Security, Norton Internet Security or another Firewall vendor, see its respective support page for assistance in disabling it (temporarily). If you’re using the built-in Vista Firewall, keep reading.
* Open the Control Panel and select Security.
* Select Turn Windows Firewall on or off.
* Select Off (not recommended), click Apply and then OK.
* Back at the Windows Update screen, click the Try again button.
* The download(s) and installation should start…
* and this time successfully install. If a restart is required, make sure to re-enable your Firewall once your PC restarts.
* Though this solution will work for most Vista Update errors
Jun 24, 2010 | Microsoft Windows? Vista Home Premium...
I cannot download the new windows updates-I get an error message 646 and cannot find out what that means
Try the following steps to install the update successfully.
Stop the services pertaining to Windows Update.
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2. If you receive a notification from User Account Control simply click Continue.
3. At the command prompt, type the following commands and then press ENTER after each command.
net stop wuauserv
net stop bits
net stop cryptsvc
4. Please do not close the Command Prompt window.
Rename folders pertaining to Windows Update
At the command prompt, type the following commands and then press Enter after each command:
ren %systemroot%\System32\Catroot2 Catroot2.old
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
Start services pertaining to Windows Update.
net start wuauserv
net start bits
net start cryptsvc
Close the Command Prompt window.
Download the standalone package file of the update “KB967043”
and install it.
Visit the following link to download the update:
http://www.microsoft.com/downloads/details.aspx?familyid=628280fe-e035-4274-85f2-393d9bad543c&displaylang=en
Restart the computer once the update is installed.
Let me know if this worked.
Oct 15, 2009 | Microsoft Windows Vista Home Premium with...
Pro tools m-powered problem
You may need to check to see which "service pack" you are currently on.
See below requirements:
System Software — Windows XP & Vista
  • Windows Vista Business or Ultimate Edition
    • 32-bit OS Installation Only
  • Windows XP Professional or Home Edition
    • With Windows XP Service Pack 2 or Service Pack 3
  • Not Supported:
    • Windows Vista 64-bit (any version)
    • Windows XP Professional x64 Edition
    • Windows XP Media Center Edition
    • Windows 98, Me, 2000, NT, 95, 3.1, DOS
  • Not Tested:
    • Windows Vista Home and Home Premium Edition
    • Although Windows Vista Home and Home Premium Edition have not been tested or qualified by Digidesign, there are currently no known issues with Vista Home and Home Premium 32-bit operating systems and Pro Tools M-Powered 7.4 compared to the supported Windows Vista Business or Ultimate Edition operating systems.
Windows Vista SP1
There are currently no known issues with Service Pack 1 for Windows Vista based on our initial limited testing and customer feedback. Although full qualification with all Digidesign products has not been completed, we do not recommend against updating to SP1, given the number of important overall system fixes in SP1. We do recommend that you backup your system and create a restore point before updating to SP1, should you encounter any problems after installing the update.
Sep 21, 2009 | Computers & Internet
Cannot download updates
are you using a genuine vista software? Did you turned on the automatic updates?
Aug 23, 2009 | Microsoft Windows Vista Home Premium with...
Vista: No internet after update
Perhaps your gateway has changed? Look in your network connections, or perhaps a proxy has been entered into the browser?
Jun 21, 2009 | Microsoft Windows Vista Home Premium with...
WINDOWS UPDATE WILL NOT WORK IN WINDOWS VISTA HOME PREMIUM
Hey try to do this now
1: Open up "Control Panel" and navigate your way to "Programs and Features".
2: Click "View installed updates" on the left hand side.
3: Find the update KB929777 and uninstall it.
4: Attempt to install the update again in Windows Update
5: Once successful, restart your PC.
and if it works thats good but if it ddnt let me know plz
Dec 02, 2008 | Microsoft Windows Vista Home Premium with...
I can't apply vista themes which i have download from internat as i have window vista home premium
hi there,
update your vista to microsoft it can help a lot like SP2 and SP3 updates. Direct X, and others, and also it will smooth your PC operations. but some update need to specify if it is a 32 bit or 64 bit OS.
God Bless
Nov 29, 2008 | Microsoft Windows Vista Home Premium with...
Computers & Internet Logo
David Payne
David Payne
