Question about Frigidaire Affinity ATF7000E Front Load Washer
Frigidaire washer door catch is stuck, washer won't run
I have a frigidare Frigidaire fwt449gfs1 the latch broke so I order part 131279001 but it doesn't fit in the lock so i ordered part 134456600 which fits in the latch- but now i cannot open the door and while it says the door is locked, the washer will not start. What can I do to get my door back open and get my washer to work?
    New Friend:
  • 4 Answers
After looking at the schematic of this machine it seems that the door AND the control board have to work perfectly together in order for the safety mechanisms to operate correctly. You may have a bad control board or a loose wire. The best thing to do is look closely at a schematic and make sure that everything looks right. here is a blueprint: http://www.pcappliancerepair.com/model/index.php?id=FWT449GFS1
Posted on Jan 03, 2014
Testimonial: "Well I've been over this, and the part that looks like the one in the schematic did not work... however, that is neither here nor there at the moment, as the door is now stuck shut and I cannot open it to make another attempt at fixing it. How do I get the door back open without breaking the door?"
  • 311 Answers
SOURCE: Frigidaire Affinity ATF7000E Front Load
The control is most likely bad. If lights flash on front let me know which ones and how many as it will sometimes tell me what the failure is. Thanks, please leave feedback or contact me again for more info if you need it.
Posted on Nov 29, 2008
  • 1294 Answers
SOURCE: Broken door latch
Why do you want to fish it out, the door might malfunction. I suggest you change the door lock mechansim, can do it your self.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Posted on Mar 22, 2009
erickg
  • 116 Answers
SOURCE: The washer door wont shut or lock on my frigidaire affinity
in the rubber seal around door to washer tub ensure there is nothing inbetween rubber.
Posted on Apr 21, 2009
localwonder
  • 6784 Answers
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
Posted on May 29, 2009
dblred
  • 68 Answers
SOURCE: The door on my washer won't lock!
the door lock has internal relays, if they go bad, the motor control board will not function. Even if you cant physically see anything, and even if the door still locks, the door lock assembly is still the most likely problem and needs replaced. The only way to test it is with a multimeter to know for sure before you buy a new one
Posted on Oct 26, 2009
My Frigidaire washer would not run. When pressed the start button, will immediately goes to Paused. The model #FAFS4474LA0. Thanks.
Thank you for your inquiry!
From what you are describing it sounds like a possible issue with your door latch assembly or control panel. If your latch is not catching the door strike or the strike is not sitting securely inside of the latch it could cause the washer to pause because it is not sensing that the door is locked.
It could also be a sensor within the control panel causing the issue and if that is the problem the control panel would need to be replaced. I recommend reaching out to a professional for further assistance to avoid any unnecessary part purchases. -Matt
Sep 25, 2014 | Frigidaire FAFS4474LA Washer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
I need the small plastic part that allows the door to lock. It broke off
Are you asking about this door strike oldtech2332_33.jpgits part number 131279001 it could be picked up from your local appliance parts store,or online at;
repairclinic.com
searspartsdirect.com
apwagner.com
apdepot.com
midwestapplianceparts.com
Gene
Aug 20, 2011 | Frigidaire ATF6000ES Front Load Washer
GE WSSH300G Front Load Washer drains, but won't spin. Repairman wanted $340 to replace a door latch. ???
Door latch for that model I chrge labor and materials minmum charge is 180 ... its easy to replace ..2 minutes done...
May 25, 2011 | General Electric WSSH300G Front Load...
The locking mechanism latch broke and we replaced it
helps to lift the door a lil when shutting it hinges may be worn and latch is easy to get to just take the clamp loose around the boot and 2 screws hold it
Jul 07, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washing machine fwt449gfs1
Check to see that the switch is actully being activated when door is closed. I wiggled the door upward to notice the machine started working. I then wedged a piece wood or wooden pencil in the botton of the door crack and that caused the switch to activate.
Switch is okay but the door alignment needed to be fixed.
Aug 09, 2008 | Frigidaire FWTBB30DS Front Load Washer
FWT449GFS1 front door buzzing Frigidaire front loading washer
Could be rubber door boot needs replacing. I am in the midst of replacing mine because door won't stay closed and buzzer sounds till I hold in door.
scott
newcastle on.
Jul 30, 2008 | Washing Machines
Frigidaire Affinity ATF7000E Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
