Question about RCA 32la30rq 32 Black Tv 720p - Lcd - RCA
My RCA 32la30rq hd tv takes 5 hours to turn on. I checked the power board and all the capacitors seem fine. I am wondering what is wrong with it.
The power will come on, but the screen does not. I have tried connecting to a signal, but it still wont work. How do I fix the problem?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • RCA Master
  • 848 Answers
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
CQC08001026140 RE46LK1300 Leke LK PI320402A Power Supply Backlight Inverter
Posted on Nov 18, 2014
    Top Expert:
  • RCA Master
  • 35,790 Answers
Fixing the problem requires more than "checking" the power board. It will be necessary to make voltage checks and use test equipment to locate defective components - including capacitors.
Posted on Jan 03, 2014
SOURCE: help rca 46inch
I have the same problem using HDMI cable, I was able to get it working using composite or RCA
cables. I still cant get it working on none of the 3 hdmi inputs
Posted on Nov 07, 2008
  • 8457 Answers
SOURCE: 42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Posted on Dec 05, 2009
yammy_alf
  • 666 Answers
SOURCE: RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Posted on Mar 26, 2010
pjhislay1
  • 822 Answers
SOURCE: My RCA 42" HD flat
sounds like it needs new caps on the power supply board..............easy fix if you can use a soldering iron........
cheers
Posted on Apr 07, 2011
SOURCE: "weak signal" on my RCA scenium
Hi, I got the same problem and unplugging fixed it but I just want to add that only my 4 REGULAR Video inputs (Vid1 to Vid3 + Front) are affected. The Component input, using 3 cables for Video input is not affected by this problem. Stephane
Posted on Oct 08, 2012
Rca picture turns off
Rca picture turns off? This trouble maybe power supply or inverter boards is defective.
May 08, 2014 | Televison & Video
32LA30RQ rca tv faded white picture need help
May 05, 2014 | RCA 32la30rq 32 Tv Black 720p Lcd - - RCA
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
RCA 32LA30RQ TV color distorted from all inputs
Dec 30, 2013 | RCA 32la30rq 32 Black Tv 720p - Lcd - RCA
I have a brand new RCA 32LA30RQ - I came home to it only receiving 'analog' channels. i have re-bboted the cable box, the TV, re-done auto search several times. It makes no sense...
I have a brand new RCA 32LA30RQ - I came home to it only receiving 'analog' channels. i have re-bboted the cable box, the TV, re-done auto search several times? This trouble maybe power supply or inverter boards is defective.
Jan 27, 2012 | RCA Televison & Video
Tv turned off by itself now TV button goes on but immediately turns off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Aug 24, 2010 | RCA HD52W59 HDTV Projection Television
Tv turns itself off . you could turn it on & immediately turns itself off or you could have it on for a while before it shuts itself off.
Solutions?
Hope this helps
Aug 12, 2009 | RCA TruFlat 27F520T 27" TV
My 52 inch RCA HD/TV Does not turn on
Replace CP150 on the deflection board and that should take care of the problem since it starts once in a wnile if it didnt start ever then you would need the 259296 flyback and the CP150 Capacitor.
May 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blinking light on 37" Dynex LCD
Solutions?
Hope this helps
Dec 22, 2008 | Dynex DX-LCD37 TV
Rca l26wd26d does not stay on
Solutions?
Hope this helps
Nov 30, 2008 | RCA L26WD26D 26 in. LCD TV
RCA 32la30rq 32 Black Tv 720p - Lcd - RCA Logo
88 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
