Error code 040 Philips CRT
I have an old Philips Pixel Plus 9617 CRT TV it has a sort of tinge of blue-ish over the screen, so whites are no longer white, they are still white but not as bright. There are also very, very faint diagonal lines, you cant notice them when you are watching a program, but if you just switch of the sky box to the blue screen they can be seen. I have changed the scart, tried different scart sockets, and unplugged every thing else, so that its just the sky box, it also shows if i just have the DVD player plugged in, so its not any peripheral at fault. I have gone into the engineers menu, and there is an error code showing 040. does anyone have any ideas ?
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
It sounds that the fault is with excess blue on display. There have tw reasons for this. As you see diagonal lines (thin white lines, all over the screen, displays horizontally, at about an inch or so apart each other); the screen voltage should be suspected. If the screen voltage is more than normal, this kind of fault can occur. The second one, is related to its video output card. If there is any loose solder terminals, especially to its blue color output transistor, or related part/s. If this happens, the voltage at the blue cathode will go less than normal related to the other two [Red & Green] cathodes of the CRT. if this happens or the output transistor itself is leaky, this kind of fault can occur. You have to check by adjusting the screen voltage to a little less first. The screen voltage pot-meter can be located at the EHT transformer itself; marked as 'Screen'. Try this first. If it do not help you, replace the blue output transistor at the video output card [the card that can be located at the neck of the picture tube itself, will directly plugged on to its back]. Check all the soldering there first. Re-solder all the suspected solder terminals, by applying a little more solder. I hereby type in this details, assuming that, you're somewhat handy to repair this set, as per your descriptions.
If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
If you need any more assistance, please come over by FixYa comment.
http://google.com/+GopakumarGopalan
Posted on Jan 03, 2014
Testimonial: "many thanks :-)"
3 Suggested Answers
wyoed1
  • 211 Answers
SOURCE: White lines & inverted picture at top of CRT TV image
This problem is normally the Vertical filter capacitors. You need to have them changed before it burns out the Vertical Chip.
Good Luck
Ed
NC Electronic
Mills Wyoming
Posted on Jan 07, 2008
CLARKPINK55
  • 71 Answers
SOURCE: why is my bush tv black and white when i watch a dvd
you are using the svhs scart if it has another scart swap the plug over
Posted on Dec 08, 2008
Mitsubishi TV input's shot/dead?
tried to use other cable wire.if still the same problem it could be a problem in the board. check first a loose or cold solder joints and replaced the crt socket in the picture tube.
Aug 18, 2012 | Mitsubishi Televison & Video
Yellow tinge to whole tv screen
if a crt type set a bad solder connection or connections are present at end of the crt on that board there.
Jun 11, 2012 | Philips Televison & Video
I have an old 36 inch widescreen Philips CRT TV which has been working fine for 7 years until yesterday when the whole screen just went blue with a series of white horizontal lines. The audio is still OK...
Hello
Since there is a blue screen atleast, I don't think that the picture tube is gone. The fault may be either to its chroma IC or video output section. In both sections fault cases, this type of horizontal lines [parellel to each other at about 1 inch or so apart the entire screen] will be seen. Just check the voltages at the three cathode, ie, red, blue and green of the piclture tube. This can be measured at the picrture tube neck card. If you have through knoledge in electronics, have patience and enough tools to do the work, inform me through Fixya. Without these, you can't work on a tv, especially in Philips.
Otherwise, get it checked by any expereinced service technician. OK.
Feb 21, 2011 | Philips Televison & Video
This TV is about 8 years old. Everything works,
Replace the CRT coolant if its a phillips. Or if a sony it may need to have the CRT drive adjusted for the Blue
Jun 19, 2010 | Televison & Video
A gree speck on the screen
It's an "open" pixel. It is unable to close to block the light, so it appears as a dot. The color white is made up of red, green and blue. So, a single open pixel will have just a single color. If you have had the TV for just a short time (< 30 days), many retailers will exchange the TV. However, if you have had the TV longer, you should contact the manufacture. The pixel specifications will vary from manufacture to manufacture... but some manufactures have a zero dead pixel specification and they will repair the TV at no cost to you. I hope this was helpful, best wishes.
Apr 17, 2010 | LG 42LC2D 42 in. LCD HDTV
60" Projection Tv - Approx 6 yrs old
Your CRT fluid needs to be replaced. After many years the crt cooling fluid gets a ton of alage built up in the tubes.  This will cause the screen to get a halo effect or get darker.
You only need to replace the fluid in the blue and green tubes.
Dec 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Pixel damage
Those small pixels are now damaged not much u can do with it. Some people say you can press on the screen the pixels affected and possiblilty get them to make contact and light back up ( I honestly highly doubt it) If u can live with and not very distracting keep watching it. But if you want to order a replacement, more than likely it will cost more than the TV did when u bought it. If its still under warranty get it replaced if possible.
Jan 28, 2008 | Philips 42MF531D 42 in. LCD Television
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
