Question about Tools & Hardware - Others
My 5+ year old furnace sporadically won't start. After changing the drain hoses to rigid pipe to eliminate traps, blowing out the sensor tubes and checking the exhaust / supply pipe for blockage, the last two times I opened and closed the access panel it worked fine for a week, and then for two days. This time I removed one screw from the panel and it started. Any ideas?..Kevin
  • 899 Answers
Is the module or a sensor , wire near the panel ? Check for loose wire connections , wires on sensors and check the module for bad connections and let me know what you find , sometimes the module can act up too from a bad transformer or just a failing module
Posted on Jan 03, 2014
  • jason Jan 03, 2014
    sorry meant to add , also a failing sensor can cause failure to start up
  • 582 Answers
SOURCE: I have a Trane Xe-60 furnace about 19 years old.
THIS IS A COMMON PROBLEM WITH THE DOOR SWITCHES, MY FIRST ANSWER WOULD BE REPLACE THE SWITCH SECOND WOULD BE OPEN THE DOOR AND PUSH THE BUTTON IN AND SEE IF THE FURNACE WILL WORK. THIS SWITCH IS JUST A DOOR SAFTEY IF THIS WORKS. I HAVE TAPED A PIECE ON THE INSIDE OF THE DOOR WHERE THE SWITCH WILL HIT THE DOOR ABOUT A 1/4 INCH THICK AND SEE IF THIS WILL GET YOU RUNNING UNTILL YOU CAN GET A SWITCH
Posted on Oct 12, 2009
SOURCE: York 92 % eff. furnace shuts down on # 3 error (pressure switch)
i have fixed almost every one of pc9 -----we have installed in our company,code three{flashes} at first new presure switches installed, same thing,york knows about this,induction motor bearings,could be bad.our local york dist, has boards,inducer, ***.motor, dual press.switch,free.as is known as the only way to fix.after all else is ruled out.one local competator called us if we wanted to join class action suit . good luck.furnaces work good at first, season or two then bam
Posted on Dec 04, 2009
Testimonial: "Believe have now pin pointed it to weak inducer motor.Removed outside exhaust vent apparatus with three elbows in it. Put one elbow back on .no more "
  • 221 Answers
SOURCE: furnace wont light. have replaced heat rod and
Have your gas supplier verify delivery pressure. Too high or low, the valve will lock up. Should be a free service.
Posted on Dec 30, 2009
  • 9 Answers
SOURCE: i have a trane furnace that is between 10-20 years
dodgy relay possibly
Posted on Mar 06, 2010
heatman101
  • 43501 Answers
SOURCE: Furnace won't go on.
The pressure switch is not working or there is a bit of water in one of the hoses.
What is happening is that the pressure switch will not close when the inducer fan satrts up. This gives the stuck open reading....
Check all of the hoses and the vent piping for water inside and if that all checks out then replace the pressure switch...these do go bad way to often, but they are a saftey device so they make to to be very sensitive...
Here is a tip that wrote about how to buy heating and air conditioning parts online.
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
Posted on Oct 07, 2010
RC 92+ Upflow Condensing Tappan Furance: we have sewer smell in basement that is strongest in furnace room. No floor drain. We have a pvc pipe with condensation hose from furnace in it. The trap continues...
the switch is a service or emergency switch if the condensation hose / line is not a sealed connection and the trap is empty the sewer smell will be constant either make it a sealed connection or close off the trap and reroute the condensation line --during heat season not condensation so heat will cause water in to evaporate
May 17, 2017 | Heating & Cooling
Goodman furnace has 3 blinking lights, indicating pressure switch stuck open. Any help?
The flame sensor needs to be cleaned. This video might help you understand how to clean the flame sensor.
Oct 05, 2012 | Goodman Manufacturing Goodman GMH950704CX...
I have a goodman high efficiency furnace, model gms9/gcs9. I've had several furnace techs look at it scratching thier heads. It won't fire up, the ignitor comes on but won't flame the unit. I...
check to see that your condensate line is not plugged. next check the p-trap where your line goes in. also check your flue abs flue pipe see as it comes out of roof is it open or does it have an elbow coming off of it i usually install with elbow preferably less water goes in the units resevoir hope that helps u
Apr 04, 2012 | Goodman Heating & Cooling
I have a 5-year old Goodman furnace/AC. It has a drain trap on the side which looks like a cup with 2 hoses coming into it from and a drainage pipe coming out into the sump pump. Recently I noticed a...
Hello, it sounds like your condensate line is clogged and not be able to drain into the condensate pump or your condensate pan is cracked and leaking. Best thing to do is clean the condensate line with a shop vac and see if the water will start to drain, if not looks like the pan is cracked.
Jul 13, 2011 | Goodman GMS90703BXA Heater
My furnace will not start the ignition process unless I disconnect the pressure switch (combustion tube not blower tube). What could be the cause? It's a new pressure switch. The vent pipe is clean.
I assume when you say you disconnect the pressure switch you mean you jump the wiring terminals? You say your vent is clean,but what about your combustion air inlet piping? Is it clear. It is not unusual for a furnace to sit over the summer and have the condensate drain trap dry out. This drain will drain the condensation from the blower and discharge to drain. If there is no water in the trap, it can allow air to flow up through the drain, which will cause a drop in the negative pressure. Try "priming" the trap by pouring enough water down drain hose until water comes out by the drain. If that doesn't work check to be sure motor is going full speed and that there are no creatures that have crawled into your inlet piping over the summer.
Oct 28, 2010 | York Furnace Draft Inducer Blower Fasco #...
Furnace not blowing hot air but cold, gurgling sound from the unit, likely condensation lines.
It sounds like a vent pipe sagged or the condensate drain trap is plugged.
You did not say what make and model furnace you have so I'll have to give you some generic intructions.
(1) Find the condensate trap and pull a plastic hose off of it and blow it out as best you can. Also you can pull the bigger hose that most furnaces have at the bottom of the heat exchanger off and blow through it.
Check all of the hoses to make sure that they are not plugged or filled with water. Methodically go through each one carefully pulling and replaceing exactly where they came from. Do not just pull all the hoses and expect to remember where they came from.
(2) Check the intake and exhaust pipes, assuming that this is a two pipe furnace. If there is water build up in the exhaust pipes the furnace will not operate.
Check for places that the pipe could be sagged or trapped. Even a sag will allow enough water to pool in the pipe and stop it.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 10, 2009 | Heating & Cooling
Itseems as though the condensation trap on Lennox G26 not working
Hi!
Take of both access covers on your furnace. In the bottom compartment (where the indoor blower fan is) there is a condensate trap, It will be black, gray, or white. Disconnect the rubber tubing that is connected to it (these tubes run up to the collector box in the top compartment. Remove the condensate trap and wash it out until it is clean inside. You will have to shake it some to get all the dirt out of it. Reinstall it and you should be good to go. Hope I was of help to you!! Good Luck!!
Dec 06, 2009 | Heating & Cooling
The draft inducer comes on and the furnace lites as normanl Goes thru its cycle and kicks off. The problems is the draft may not kick on the next time and sticks and the motor gets hot, If I go remove the...
When a furnace is replaced with a newer style unit like yours with an inducer motor, they sometimes use the old vent pipe. These old style vent pipes are transite (light weight cement), the moisture created from your furnace exhaust is caught on the cool transite surface and runs back down into the blower blades or wheel bringing a white mineral deposit with it which causes your problem. The vent should nave been replaced with the heater using a metal vent material. You will need to replace your inducer motor assembly and vent pipe to prevent a recurrence.
Dec 04, 2009 | Omega Trane Furnace Draft Inducer Blower...
I have a Goodman GMS9/GCS9 Gas-Fired Warm Air furnace and it's no
For anyone who finds this question in the future - It's the condensate drain hose for the heat exchanger.
Get a bucket and some towels handy and unplug the lowermost flexible rubber hose - if you do this right after the furnace has stopped, water will come gushing out. Mine was continually plugging up causing my furnace to stop, like yours - the L shaped plastic tube that dips into the drain trap on the outside of the unit (the thing filled with water) was too close to the bottom of the trap. I took it out, shortened it by 1/2 an inch (keep the same bevel that's on there!) and I haven't had a problem since. Blowing out the line would only hold things off for a few weeks before it started acting up again.
Cost me $90 for a service call the first time since visually it looks fine and I checked the upper hoses that go to the pressure switch :)
Learn from my service call!
Feb 23, 2009 | Goodman GMS90703BXA Heater
GMPN goodman furnace: Water leaks from the base.
Check the drain tubes inside the furnace. There may be a loose connection or a split tube.
The unit could also leak from the gasket between the secondary heat exchanger and the vent fan housing. The secondary heat exchanger ould also be leaking or cracked.
Hope this helps.
Matt
Jan 08, 2009 | Heating & Cooling
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
