Question about McCall Refrigerators
Freezer wiring diagram
Need a diagram showing how all the wiring is connected to a potential relay
5 Suggested Answers
  • 102 Answers
SOURCE: Headlight/turn signal problem
RELAY, NOISE SUPPRESION/is 1323592 its black and mounted under the hood on the shock tower, check page 4 and page 16 under LHB230FT in your book(item 464) ? why are you messing with this relay if you have a light problem ? does left turn signal stay on with key off /with parks only /with head lights /both front and back turns or front only? have you removed both frt and back bulbs together and ck voltage in sockets ?/wrong bulbs? i would need more info
Posted on Sep 02, 2008
  • 1253 Answers
SOURCE: Need wiring diagram for GE model CA15DRN upright
http://genet.geappliances.com/DocSearch/pdf/49-6545.PDF
The best I could come up with is this site for the user manual. Not able to find wiring diagram on this GE site. Hope this helps ya.
Posted on Nov 29, 2009
SOURCE: Starter relay connections
if your starter engages but wont spin check to make sure the starter housing is making good contact on the bell housing or it wont ground out
Posted on Mar 09, 2010
bobicehouse
  • 1524 Answers
SOURCE: need wire diagram how to install 3 N 1 start relay
The two stripped black wires connect to power.
Black tabbed wire to common.
Red tabbed wire to run.
White tabbed wire to start.
Looking at pins on compressor, read like a clock. Common clockwise to Start clockwise to Run
Posted on May 07, 2010
2005 odyssey wiring diagram. Need to discover what 40A fuse BackUp Circuits is
I show a 40A fuse 20 in the underhood fuse relay box that connects to 15A fuse 12 in the driver's underdash fuse/relay box (perhaps as a backup?)
Oct 09, 2016 | 2005 Honda Odyssey
A "potential" relay is a voltage controlled start component for the compressor. If your sure the potential relay is bad, not the start capacitor or a seized compressor, Order one from G.E. and replace it.
Dec 07, 2013 | GE Freezers
How to connect the wires from my central air unit to the capacitor it's a 440 vac
bobicehouse_0.gifThis diagram shows a potential Relay and start capacitor.
You only need them if you have a "Hard Starting" problem.
Jul 12, 2011 | Ruud UAMB Air Conditioner
I need to replace my thermostat on my ge chest freezer model #fcm7sudww, I lost the wiring diagram and I need help to rewire. Thanks
Wiring diagram of the chest freezer turned into chest fridge. The junction box is not required if all connections are made inside the fridge service compartment. Active (A) connection passes via latching relay terminals
inside the thermostat.
Additional information can find HERE.
Hope helps; tell us news.
Aug 05, 2010 | General Electric Chest Freezer FCM5SU
Need wire diagram how to install 3 N 1 start relay on a true t12f freezer
Apr 29, 2010 | True 12 cu. ft. / 340 liter Commercial...
Need wiring diagram for GE model CA15DRN upright freezer-compressor relay busted & not sure which wires go to which terminal on compressor.
Nov 24, 2009 | Freezers
I have a toro 8-25 rear engine rider model 56172 serial # 8008773, I need a wiring diagram for my mower. It is messed up,and some *@#$%+&* mess it up before I got it. I received a diagram for a 7-25 and it...
None of the numbers you supplied match any info on the toro.com web site. Check the numbers and then see if toro has any info for you.
That said, it sounds like you connected to the wrong relay terminal. Here is how you want it connected:
The battery (and alternator) connect to one of the large terminals on the relay. The starter connects to the other large terminal. The start switch connects to the small terminal on the relay. The idea being that the small current connected to the small terminal turns on the relay which connects the large battery current to the starter.
Obviously there is more to the wiring than just that, but you didn't ask about the rest...
May 05, 2009 | Garden
Circuit diagram of refrigerator
i went to the store an bought a two in one relay-overload the diagram on the box shows me how to connect the the compressor but there is two black wire which is the power i want to know how to find the power wire so i can connect them
Feb 20, 2009 | Hoover HCA454FK Bottom Freezer...
Refrigerators Logo
221 people viewed this question
Top McCall Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a McCall Refrigerator Expert? Answer questions, earn points and help others
